West Wings Hawker Hunter - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-09-2005, 06:11 PM
easytiger
Banned Permanently
Default West Wings Hawker Hunter
Anybody built one? About to start in on mine. Takes the 480 fan. Will go brushless/lipoly. Thinking of adding landing gear, I don't like to bungee...
easytiger is offline
Old 10-12-2005, 05:49 PM
easytiger
Banned Permanently
Started in on it last night. Three hours later, most of the fuselage is done.
I have to say, I have built a lot of balsa kits, this may be the BEST one I have ever done. Parts fit, instructions, plans, engineering, all dynamite.
Old 10-12-2005, 05:54 PM
easytiger
Banned Permanently
I have more pics, but they are too large to post here.
What's the most powerful lipoly-480fan setup? I have a wattage fan already, waste of time to use that?
Old 10-13-2005, 02:50 AM
termite
termite's Avatar
Hey tiger,
Try the Mega EDF 16 or for a little more the 16/20/2
Go 4s with either in the minifan and ya won't be dissapointed!!!
Light set up use the 16/15/2 on 3s
Randy
Dynamo Electrics
termite is offline
Old 10-13-2005, 02:55 AM
easytiger
Banned Permanently
What kind of thrust, what kind of weight?
Not sure which way I want to go, depends on landing gear. I may go light and hand-launch...
Old 10-13-2005, 04:40 AM
termite
termite's Avatar
Thrust, not sure.
Weight, That's up to you!!!!!!
16/15/2 = 450 watts
EDF 16 = 500 to 600 watts
16/20/2 = 600 to around 700
I've got the 16/20/2 Kyosho T-33 Stock fan on 4s - 40oz with PolyQuest
4400N 4s and it allmost flies out of your hand - 735 watts
Randy
termite is offline
Old 10-14-2005, 01:42 AM
easytiger
Banned Permanently
Not sure which way I want to go...super light and hand launch, or maximum power and retracts...or build two of them...
Old 10-15-2005, 05:58 PM
easytiger
Banned Permanently
All framed up, just needs a final sanding.
I played around with retract installations for a while yesterday. Mechanical is no good, no way to make the linkages work. I don't have air retracts small enough. I settled on OK mechanicals actuated by Clippard air cylinders. Overall weight gain would be on the order of 7 ounces, by the time all was said and done, and the mains would have to be flat wheels such as Williams Brothers to fit in the very thin wing...
In the end, I decided it was not worth it.
I do think I will put in maple blocks for fixed gear, so at least I have the option.
Anyway...everything fit together PERFECTLY, engineering was SUPERB, and I have about eight hours in it to get to this point...
ID:	2659   Click image for larger version
ID:	2660   Click image for larger version
Old 10-15-2005, 07:21 PM
Andy m
Andy m's Avatar
Easytiger,
Your model is looking good!
I am at the covering stage with my Hunter using Poly-C and tissue to keep the weight down.
Power for mine is Mega 16/15/3 and 4s Lipo.
Andy m is offline
Old 10-15-2005, 09:45 PM
easytiger
Banned Permanently
Looks just like mine! I am going to do the same thing, covering-wise. Sort of wish they had just sheeted the entire wings, I may do that, to do the whole thing in tissue.
How much power from that setup?
Old 10-15-2005, 11:06 PM
watt_the?!
watt_the?!'s Avatar
the wattage fan will be fine.
Tim.
watt_the?! is offline
Old 10-15-2005, 11:08 PM
watt_the?!
watt_the?!'s Avatar
Originally Posted by termite View Post
Thrust, not sure.
16/15/2 = 450 watts
Randy
We added thrust to Luc Dietvorst's FanCalc version 2.0. Not sure if its out yet, but it'll have it when released.
Tim.
Old 10-16-2005, 12:26 AM
easytiger
Banned Permanently
Tim.
The Wattage fan is equivalent to the Wemotec 480? I can put 700 watts into it?
Old 10-16-2005, 12:31 AM
watt_the?!
watt_the?!'s Avatar
well, itll do the same up to the point where it fails...
dunno if it can absorb 700W, but it is on a par with the minifan at least up to 500W.
Data is available up to 500W that ive found so far.
might have to ask around about what others have put into it. On the efficiency side, its good.
Most of the RBC kits do well on 400W- im sure you know.
Tim.
Old 10-16-2005, 12:36 AM
easytiger
Banned Permanently
Judging by the much more sophisticated design of the Wemotec over the Wattage, I suspect the software is not really giving a real-world figure, the Wattage fan seems awfully primitive. But who knows?
I have built some RBC kits, I like them very much.
This thing is much more sophistacated, though, in plans, instructions, packaging, decals, and, above all, the plastic parts are MUCH better.
I'd build another RBC kit, though, those guys are supercreative and keep cranking them out. That F100 is tempting.
Old 10-16-2005, 12:40 AM
watt_the?!
watt_the?!'s Avatar
ET, i know our past revolves around this, but im trying to help, not mislead. the data to 500W are test, not software.
from that data it can be extrapolated to 700W and beyond, but i wouldnt post that as i dont know of anyone who has run them that hard.
What would be great is if you put 700W into it, held it over a digi scale, and measured V, I, thrust, and rpm. Then we'll know. my bet is that itll do it well, but as i qualified it, i only know of someone doing 500W and getting great results.
Tim.
Old 10-16-2005, 03:41 AM
easytiger
Banned Permanently
I think for this project, I will stick with the Wemotec, which LOOKS to be more efficient, and the plane is designed around it, and I know it will take the power and not put out anybody's eye...
Old 10-29-2005, 02:09 AM
easytiger
Banned Permanently
Well...I put in fixed removeable gear, and fully sheeting the wing.
The LG blocks only added an ounce and a half, and the sheeting lets me cover the whole bird with just tissue and dope. Tissue on open areas is not great for a jet, too many holes.
Old 12-25-2005, 07:11 AM
termite
termite's Avatar
Any progress Tiger?
Randy
termite is offline
Old 12-25-2005, 12:48 PM
easytiger
Banned Permanently
Absolutely. Ready to paint. I did silkspan and eight coats of clear nitrate dope. Pics later this week.
Did I mention how nice this kit was? Really love it...
Old 12-28-2005, 12:56 AM
easytiger
Banned Permanently
All ready for paint...
Old 12-28-2005, 01:07 AM
termite
termite's Avatar
Lookin' good my friend.
Let me know if I can help with the power system:p
Randy
www.dynamoelectrics.com
termite is offline
Old 12-28-2005, 01:08 AM
easytiger
Banned Permanently
I actually got it painted already, but did not photograph it yet...
I WILL need help with the power system, I have bought none of that stuff for this plane yet, but I will hold out for a few weeks, been spending too much, I want to buy another turbine first....
Old 01-13-2006, 05:03 AM
easytiger
Banned Permanently
Coming along, panel lines are next...
ID:	5925   Click image for larger version
ID:	5926   Click image for larger version
Old 01-13-2006, 10:44 AM
Andy m
Andy m's Avatar
Easytiger,
Looking really good with that paint job............................I must get mine finished! :o
Andy m is offline
Quick Reply: West Wings Hawker Hunter
Page generated in 0.15867 seconds with 19 queries
