Maxcim 13Y - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Maxcim 13Y
Old 07-27-2005, 04:48 PM
Graham
Default Maxcim 13Y
I have a Maxcim 13Y motor with a gear drive. I have not used this motor as yet and wonder if I could use it in a 5 - 6 Ib. craft as a direct drive? I am thinking something like the WM Dago Red Mustang with a 3 Bladed prop.
I suppose I could experiment on the bench, but thought I might get good info back from experience out there.
Graham
Graham is offline
Old 07-27-2005, 05:15 PM
Andy m
Andy m's Avatar
I had a Maxcim once myself but it too was geared so I do not know how it would suit direct drive.
Try dropping an email to Tom (the guy who makes them) he is always very helpful with information.
Andy m is offline
Old 07-27-2005, 08:54 PM
Matt Kirsch
Matt Kirsch's Avatar
I suspect that the motor won't be able to turn much of a prop direct drive, but it might be able to turn a 4-bladed prop that would be appropriate on a .40-size plane (11"-13") as-is. Do you know what the gear ratio is?
Matt Kirsch is offline
Old 07-28-2005, 06:12 PM
Graham
Default Gear Ratio
Hi Matt...
I have various gear ratios I could use, around 4 - 1 seems to be what was used on a previous app. which was a 1/4 Scale Spacewalker I understand.
Graham is offline
Old 07-29-2005, 02:42 PM
Matt Kirsch
Hmm.. Any idea what the power system looked like on that SpaceWalker? That is, battery, prop size... If we can get a starting point, we might be able to extrapolate the right combination for a .40-size warbird.
I just looked over at P-Calc on www.flydma.com, and they have the entire MaxCim line listed... There are three different "13Y" motors listed. Which is yours?
Old 07-30-2005, 01:01 AM
Greg Covey
Greg Covey's Avatar
Graham,
You'll still need the gearbox on your 13Y. Just use a lower reduction ratio starting around 2:1 and prop for 40amps on 20 cells or 6s Lithium.
Good luck!
Greg Covey is offline
Old 07-30-2005, 01:37 AM
Graham
Thanks Greg.. appreciate your feedback.
Graham
Graham is offline
Old 07-30-2005, 03:27 AM
ragbag
Default retiming motors
If you take a motor setup for a gearbox, you have to retime it. I won't go into the complete process, but it means connecting an amp meter and load. Unsolder the back of the motor, the brush end, and turn it one way then the other until you get the lowest draw of amps.
I believe that is the way, been a while since I read the instructions and can't lay my hands on them right now.
Anyway they are timed when you get them for the direction they are to be run in.
George
Gainesville FL
OOPS, that's a brushless motor. Disregard all of the giberish above.
GAP
ragbag is offline
Old 08-02-2005, 03:33 PM
jrb
Always thought Mustangs look and fly best with a 4 blader: http://www.rcgroups.com/links/index.php?id=4788 .
jrb is offline
Old 08-20-2005, 05:30 PM
canamrichard
goelectric
canamrichard's Avatar
I believe that motor would only work with the gearbox for a plane as large as that.
canamrichard is offline
Old 08-20-2005, 05:39 PM
canamrichard
goelectric
I am currently putting together a Spacewalker II which will weigh around 6.8 lbs with motor and battery. The only thing I felt comfortable with as a direct drive motor is an AXI 4120/18. A gearbox with a MaxCim would also work. I will be using a 5s3p battery and around a 13X8 prop if I go direct. Check with www.espritmodel.com for good guidance on motor/prop/battery for your plane.
Old 08-21-2005, 10:47 PM
Walt Thyng
Walt
Walt Thyng's Avatar
Tom's "Y" wind motors are best with a gearbox. The "D" motors are better for direct drive.
WT
Walt Thyng is offline
Bill Hawthorne
07-04-2008 07:26 PM
Bill Hawthorne
07-20-2007 02:18 AM
Doppelganger
17
08-25-2006 06:01 PM
DWS
02-28-2006 09:47 PM
Quick Reply: Maxcim 13Y
Page generated in 0.11274 seconds with 15 queries
