Looking for 10V 1100 mAh battery in Dallas, TX area!
Old 07-04-2009, 12:43 PM
soccerrprp
Default Looking for 10V 1100 mAh battery in Dallas, TX area!
hi all,
i bought a remote control car for my son the other day and suspect that the battery (lead acid) is dead. does not recharge. i need to find a 10V 1100 mAh battery in the Dallas, TX area. Anyone know where i can go to get this? I found one NiCd online, but rather pick it up locally. If there is a 10V battery with more than 1100 mAh, that of course, would be fine.
someone please confirm this: it would be okay to get a battery pack that is slight higher Voltage than what the device requires, correct? such as a 10.8V with at least 1100 mAh? Or will a 9.6 V be fine, though just slightly below?
Thanks.
Richard
soccerrprp is offline
Old 07-04-2009, 03:49 PM
Air Brake
10.8 or 9.6 should both be in a safe range for a replacement. dont go too much higher on the voltage unless you are sure that the motor is rated to handle it. any LHS in the dallas area should be able to hook you up no problem.
Air Brake is offline
UglyNet
ParkFlyers
17
05-11-2009 07:38 PM
everydayflyer
31
11-12-2008 06:36 PM
EpoweredRc
11
12-23-2007 11:55 PM
Figure.N9ne
Ebay for sale
10-24-2007 04:22 AM
10-03-2005 04:08 AM
Quick Reply: Looking for 10V 1100 mAh battery in Dallas, TX area!
Page generated in 0.06502 seconds with 12 queries
