The thrust of motors
Old 07-28-2017, 10:00 AM
AlenJk
Default The thrust of motors
I only know a little about quadcopter motors, and there is a question about my motor's thrust. I bought 4 pcs 2305 2450KV motors from a motor online shop, and I got a thrust data on their motor details, but my fridens said the thrust data probably is wrong, they should at least 1100g/1200g, but he is not sure.So what do you think of this motor thrust data? is this data right or wrong?
AlenJk is offline
Old 07-28-2017, 03:25 PM
Here's a web-site that has many resources to determine tech specifics related to multi-rotor props........:
http://www.propwashed.com/miniquad-p...-buyers-guide/
Follow the various links to educate yourself.....personally, I find GemFan props quite reliable and very economical....!
Old 07-29-2017, 05:23 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Motors don't produce thrust, propellers produce thrust
[strike]This subforum is dedicated to designing/building/(re)winding motors.[/strike]
UAV / FPV or Power Systems subforum would be more suited for advice.
ron_van_sommeren is offline
Old 07-29-2017, 05:34 PM
I moved this to the power systems forum which is more appropriate to the question.
As noted above, motors don't produce thrurst. Propellers produce thrust. how much thrust they produce is based on the motor and specs, prop and its specs, battery and its specs and, to some degree the ESC and its specs. A system produces thrust by how it spins the prop. Change any element and the thrust will be different.
AEAJR is offline
Old 07-29-2017, 05:38 PM
There is also an obvious error in the OP's place of residency.......more than likely another global opportunist lookie-loo........
admin
10-13-2021 08:50 PM
06-28-2017 04:22 PM
Joe 1320
Electric Ducted Fan Jets
13
02-02-2012 01:15 PM
Hose Man
03-23-2011 01:57 PM
terrynshed
12-16-2010 05:00 PM
Quick Reply: The thrust of motors
Page generated in 0.07557 seconds with 13 queries
