Brushless Motor Construction Discuss design and construction of custom Brushless motors
Power 32 Stops turning after 50% Power
Old 09-17-2014, 01:34 PM
WingmanArt
RC Wingman
Default Power 32 Stops turning after 50% Power
Hi
I have a power 32 that will turn up to but not past 50% power. Does anyone know what the problem might be and if its repairable. If its repairable can you help you provide guidance.
Thanks for your responses....
Art
WingmanArt is offline
Old 09-17-2014, 01:50 PM
Porcia83
Did you check your throttle trim on the transmitter?
Also, this might be a problem with your ESC. Have you tried different esc's and batteries?
Porcia83 is offline
Old 09-17-2014, 02:03 PM
WingmanArt
RC Wingman
Pocia83,
Thanks for your response, although I should provide some more context.
This motor is out of a e-Flite Albatros that had the original ESC 60 in it. The ESC failed and it was replaced with a newer version. However, when the original ESC failed it did cook all my electrics on it and the motor had been acting up ever since. Thank god it failed on the take-off role...
You can now smell some burning but when I took the motor apart I could not see any damage. My guess is that there is some but cannot see it and do not know how to determine where or how to fix...
Old 09-18-2014, 01:00 AM
Originally Posted by WingmanArt View Post
Pocia83,
Here you Go, Testing Electric Motors. Written By Denny, one of the Best Of the Best here on Wattflyers.
http://www.wattflyer.com/forums/show...rushless+motor
Old 09-18-2014, 01:10 AM
If you can smell the motor and it smells burnt, Chances are that it got damaged, the test above will let you know for sure, IMHO, E Flite ESC are not the best ESC out there , use Turnigy ESC, IMHO they are Bullet proof Its all I use and never ever had any problems with them, test your motor before hooking it up to a new ESC. use the Red Plush or Sentry turnigy ESC. they have a Switching UBEC.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old 09-18-2014, 01:23 AM
Here is an Equivalent motor to the Power 32 which is a 4250-750KV motor
http://www.headsuphobby.com/Firepowe...otor-C-105.htm
or
http://www.headsuphobby.com/Power-Up...otor-E-590.htm
or
http://www.headsuphobby.com/Emax-GT3...otor-C-350.htm
Old 09-18-2014, 03:23 AM
I expect its demanding more power than the battery can deliver and shutting down on low voltage detect at the ESC
Or... maybe the ESC is programmed for the wrong cell count.
Old 09-18-2014, 12:32 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Art, if I were you, I'd remove/mutilate your e-mail address in your signature, before the spammers find you: art curl rc-wingman dot com.
People can use the forum private messages to contact you as well. Don't forget to turn on notifications.
ron_van_sommeren is offline
Old 09-18-2014, 04:52 PM
And the e-mail needs to not be put in a post...
Old 09-19-2014, 12:07 AM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Bingo! I think we have a winner!
Joe
Turbojoe is offline
Old 09-19-2014, 01:10 AM
Hi Chellie
Thanks!
As with a lot of us, the stuff we have that did work over the years sits on top of a big pile of stuff that didn't.
Old 09-19-2014, 03:37 PM
WingmanArt
RC Wingman
Default Thank-You
All,
Thank-you for all your advice, feedback and recommendations.
Cheers!
Art
Old 09-19-2014, 03:41 PM
WingmanArt
RC Wingman
Signature Test.....
Old 10-02-2014, 01:20 PM
WingmanArt
RC Wingman
All as an update,
As recommended I ran a drill test (Passed) and I ran a volt meter test on all 3 power connectors (Passed all combinations resulted in same Voltage). I then tried two fresh batteries 3 & 4 cell. As it turns out the motor began to smoke once throttle exceeded 50% power, the motor stopped spinning and started smoking.
My thoughts are that the winding is damaged. So my next question is their a good tutorial on how to rewire a motor. Never done it before but would like to give it a try.
Thanks for all your help!
Cheers!
Art
Old 10-02-2014, 02:33 PM
Its really all about paying attention to details and packing as much copper as you can fit into the the stator.
Air is wasted space. More copper = more power.
https://www.youtube.com/watch?v=JPgeDmQNvio
Old 10-02-2014, 03:34 PM
All as an update,
Cheers!
Art
I've wound and rewound a whole bunch of motors, brush and brush less types. IMHO, its just not worth it, what with the low cost of motors now days.
Plus you need magnet wire. I did!
Check gobrushless.com. they used to have winding info.
Old 10-02-2014, 05:53 PM
+1 I agree with Denny, Its just not worth the hassle to rewind motors, motors are so inexpensive now days, unless you wanted to custom wind a motor for a specific torque or speed.
Old 10-02-2014, 05:57 PM
Here is a nice motor from Heads Up Rc.
Firepower 40 Speed (4250-08) Outrunner Brushless Electric Motor
Click To Enlarge
  • Item #: C-105
The Firepower 40 Speed (4250-08) is a 7.0 ounce, 800kv, 750 watt outrunner brushless motor that is roughly equivalent to .40 to .46 two stroke nitro engines. It's a good choice for sport and scale airplanes weighing 3 to 6 pounds.
The Firepower 40 Speed comes with 3.5mm male connectors installed, and female connectors are included for your ESC.
Mounting Options: The Firepower 40 Speed can be mounted in front of a firewall using the included X mount and rotor end prop adapter. It can also be mounted behind a firewall, and a 5mm prop adapter can be purchased for mounting a prop on the motor shaft.
Propeller Test Data for the Firepower 40 Speed Motor:
It's a good idea to balance all propellers with a Propeller Balancer before using them on this motor.
Rotating propellers are dangerous. Please stay clear of prop and wear eye protection.
Battery Size Propeller Size Thrust (oz.) Amps Watts Notes 4-Cell 14.8v APC 12 x 6E 96 oz. 52 amps 720 watts Avoid constant wide open throttle 4-Cell 14.8v APC 11 x 5.5E 78 oz. 37 amps 560 watts 4-Cell 14.8v APC 11 x 7E 76 oz. 45 amps 650 watts 4-Cell 14.8v APC 10 x 5E 64 oz. 30 amps 475 watts 4-Cell 14.8v APC 10 x 7E 69 oz. 37 amps 550 watts 3-Cell 11.1v APC 14 x 7E 80 oz. 52 amps 560 watts Avoid constant wide open throttle 3-Cell 11.1v APC 13 x 6.5E 74 oz. 40 amps 440 watts 3-Cell 11.1v APC 13 x 8E 76 oz. 47 amps 510 watts 3-Cell 11.1v APC 12 x 6E 64 oz. 33 amps 370 watts 3-Cell 11.1v APC 12 x 8E 62 oz. 36 amps 400 watts Please be aware that the battery used can make a tremendous amount of difference in the performance of brushless motors. The above data was obtained using batteries in good condition that were fully charged. Thrust and amp draw may be less with the use of batteries rated at lower amp output, and slightly more using batteries rated for higher amp output. Other factors, such as ESC timing and variations in actual motor KV can affect the performance of brushless motors as well. We recommend the use of a Watt Meter to test the current draw of your particular power system, especially if you plan to use a prop that pushes the motor near it's maximum amp rating.
Firepower 40 Speed Specifications:
Weight = 7.0 ounces (198 grams)
Diameter = 1.65 inch (42 mm)
Motor length = 1.9 inch (48 mm)
Shaft = 5mm x 0.9 inch
Voltage = 12.0 - 26.0 volts (3 to 6 cell Lipo)
Current = maximum of 50 amps or 750 watts for 30 seconds
KV (rpm/v) = 800
Old 10-02-2014, 05:58 PM
or
Power Up 32 Sport Outrunner Brushless Motor
Old 10-02-2014, 09:51 PM
Then again... kit building is more expensive than buying an ARF... but we still do it.
It can be interesting to do a home rewind.
Old 10-03-2014, 12:36 PM
WingmanArt
RC Wingman
All,
Who can argue with the logic of motors being inexpensive! :-). I do appreciate everyone's input and time. I think I will file the old motor into garbage bin and look at the options provided.
Thanks again everyone for your input and advice.
Cheers!
Art
06-28-2017 04:22 PM
01-09-2017 02:23 AM
08-11-2014 03:36 AM
ewilliam
01-21-2014 06:32 PM
Albatross
07-25-2011 03:46 AM
Quick Reply: Power 32 Stops turning after 50% Power
Page generated in 0.14320 seconds with 13 queries
