Pattern aircraft Discuss electric powered pattern aircraft in here
direct connections tsunami
Old 12-01-2006, 02:17 AM
texas
Default direct connections tsunami
Has any one ever converted a tsunami to electric? I have had a kit for many years and may make it a project.
texas is offline
Old 12-27-2006, 12:10 AM
feathermerchant
I have the DC Sea Fury kit. Is it similar? I have seen the sea fury fly and it flies great electric.
feathermerchant is offline
Old 08-28-2008, 04:34 AM
doxilia
Default Tsunami
Not yet... I began building this model 11 years ago, left it in its current state (it had less hangar rash at the time) and recently decided to finish it. I'm considering using electric but I had set it up for glow at the time and the model, as designed, does not really provide for an easy way to swap battery packs. I suppose a hatch could be made out of the nose bottom but you'd have to plan for this before starting the build. The fuse structure is very light and there is little support for potential hatches.
Still... I'd like to see a Tsunami on electric. Beautiful plane! I've heard some comments about strange yaw control due to the angled rudder hinge line... we'll find out soon enough!
ID:	76595   Click image for larger version
ID:	76596   Click image for larger version
doxilia is offline
Old 09-15-2008, 10:23 PM
texas
Yeah, thats the plane, have not built it yet. I've had this kit for at least 14 years. Some day I will build it as electric. Its a beautiful plane. Let me know if you finish in electric and good luck with it.
texas is offline
Old 09-16-2008, 06:07 AM
doxilia
Hey Texas,
glad you're back on the thread. You must have bought your kit back in '94. I got mine in '96 and pretty much brought it to the state you see in the first two pictures. Friday, I got back on to it after working on some other projects. I'm going to try and finish it before month's end as I want to get started on a scratch built electric 20 size (48" span) Tiporare (that I've dubbed the Nanorare). If you're interested in those plans check the classic pattern forum on RCU.
Re electric, if you can figure out a convenient way, more power to you. I decided to stick to glow since I have the engine and the fuse is already essentially built. I would recommend that you either make a hatch out of the nose bottom, or better yet, out of the canopy area. The nose is built such that it is rather tricky to built access into it (you'll have fun with F2...). More importantly, access to the motor is the real issue. In principle you don't want a huge gash on the nose bottom to install the motor but without it, access to the motor/engine area is virtually nil. The only other option would be to install the motor as you build and it would then essentially be locked in place and maintenance would be limited to access through the nose ring - removing the motor would probably not be possible under this scenario.
But... if there's a will there's a way. Maybe you could make a motor access hole in the bottom and a hatch out of the canopy/fuse top... yea, that's how I would go about it. I would power it with a high kV motor since prop size is somewhat limited (10" max). Probably something along the lines of 750W, 4S if you can.
I've also considered making a foam core wing for it and install mechanical retracts - maybe some day.
I've started a build thread on RCU in the classic pattern forum if you're interested. Maybe this will provide the necessary inspiration to get your started!
Cheers, David.
doxilia is offline
Old 02-08-2009, 05:20 AM
doxilia
I'm afraid she didn't end up e-powered but there she is! (Hopefully I won't get thrown off this forum by posting photos with a glow engine...)
Looking forward to seeing some others!
David.
ID:	92923   Click image for larger version
ID:	92924   Click image for larger version
ID:	92925   Click image for larger version
ID:	92926   Click image for larger version
doxilia is offline
Old 03-07-2009, 03:12 PM
vonJaerschky
The Hun in the Sun
vonJaerschky's Avatar
I had one of these back in the late 90's, too. I remember it was a great flying airplane. I had a Webra Speed .40 with a tuned pipe on it. I've just ordered another from Juno R/C and plan on electrifying it. I think it's the perfect conversion airplane because it is already a nice light weight design. I'll see if I can shave a few more ounces off the airframe somehow.
vonJaerschky is offline
Old 06-09-2016, 08:50 AM
Evengers
Cheers, David.[/QUOTE]
Hi David, I know this is a very old message thread but are those plans still available somehow?
Thanks!
Evengers is offline
Inspired_Art
ParkFlyers
04-02-2008 06:26 AM
texas
12-01-2006 02:31 AM
Fred Marks
Batteries & Chargers
11-03-2006 10:04 PM
afpe45
02-24-2006 02:24 PM
jerryb
8
12-18-2005 10:50 PM
Quick Reply: direct connections tsunami
Page generated in 0.10152 seconds with 18 queries
