Servo Extensions?
Old 11-04-2006, 04:47 AM
HAL9000
Default Servo Extensions?
Can you use a servo extension wire between the ESC and the receiver?
HAL9000 is offline
Old 11-04-2006, 04:51 AM
I have, and have had no problem Hal.
Old 11-04-2006, 04:53 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Hi HAL,
I sure hope so. I just opened my 52" P-38 that came in today and was looking at the instructions. It calls for extensions since the receiver is in the center pod and the two ESCs are out in the booms with the batteries. I also have to use a Y connector to hook 2 ESCs to one receiver.
Grasshopper is offline
Old 11-04-2006, 04:56 AM
Yup same situation Tom, different plane. My Super Airliner esc are in the wing, needed extensions and a y also to hook it all up.
Acutally the proper term in my lingo is a siamese connection, 2 into 1. A y is 1 splitting into 2... as in fire hose
HAL9000
the only difference i see in the wires is it seems the wires for the esc are a little thicker. Do the servo extension wires allow for the BEC?
HAL9000 is offline
Old 11-04-2006, 04:58 AM
that may just be the brand Hal. Mine appear to be the same size...
Old 11-04-2006, 05:01 AM
HAL9000
cool thanks guys for the quick replys... dont you guys have better things to do on a friday night then work on planes?
HAL9000 is offline
Old 11-04-2006, 05:07 AM
Grasshopper
What do you mean? It's too dark to fly so we have to build. Are you actually implying there is life outside of RC??
Old 11-04-2006, 05:08 AM
hehe... laptop on the workbench!
HEY WAIT A MINUTE... what are you doing Hal??? LOL
Old 11-05-2006, 12:28 AM
Gary Hoorn
Chesepeake Bay RC Club
Gary Hoorn's Avatar
Hal,
Others have given you an answer. I have noticed that generic extensions which cost less seem to have a heavier gauge wire than say the expensive JR ones. In any case they all work. I have been using extensions wherever needed for some time.
Gary
Gary Hoorn is offline
Old 11-05-2006, 01:10 AM
Gohmer
Banned
Smile
I have had no problems using extensions there. I recommend a long enough one to wind around a JR RF filter.
Gohmer is offline
Old 11-06-2006, 09:25 PM
Crash
Crash's Avatar
Has anybody tried hooking up three ESC's to a receiver? How would this be wired?
Crash is offline
Old 11-06-2006, 11:08 PM
cyclops2
ESC's pull almost no current to operate at any speed.
So, yes, you can put + 50 ESC's into a receiver.
BEC power for the servos can be a problem. The BEC is on the ESC way out in the wing somewhere. The receiver is in the middle.
4',6' 8' of extension is going to drop a lot of volts if you have BIG STRONG servos with large loads. You want to be VERY sure that with any amount of trim added to any channel it does not ever cause the servo to EVER, EVER, hit a mechanical stop. That split second bind will cause massive voltage drops on the wires from the BEC regulator. A PCM could see it as interference and go to lockup for a few seconds. When it clears, all would be back to normal from your jiggling all your levers around excitedly.
Pray you are not straight up or down at lower heights.
I would recommend a complete ground test at all servo trim settings on each channel to avoid this from happening in the air.
As a after thought. The plane is probably so big you should have NO problem in justifying a seperate battery pack for the receiver and the servos.
20C--30C-- and higher C's with BIG servos and LARGE surface loads are ASKING for BEC line voltage drops to screwup a plane needlessly.
cyclops2 is offline
Lymph
General RC E-Heli Talk
8
08-16-2008 09:08 PM
Rick Marshall (Thud)
04-14-2008 06:20 PM
Forge
04-03-2008 11:23 PM
Warden
09-09-2006 12:22 PM
Grasshopper
Batteries & Chargers
8
06-05-2006 08:13 PM
Quick Reply: Servo Extensions?
Page generated in 0.10470 seconds with 13 queries
