Hobby King Orange Spektrum receiver?
Old 06-08-2011, 05:53 PM
Nieuport Fly Guy
Nieuport Fly Guy's Avatar
Default Hobby King Orange Spektrum receiver?
I ordered this little Orange Spektrum receiver Compatible with all SpektrumDSM2 transmitters...(building first RC plane) and it will not bind to my transmitter. Has one antenna ( not two)... Was this just the wrong purchase? I have stock transmitter from HZ champ...and an order in for thd dx6i transmitter?
A perfect foamie or parkflyer receiver. Very small and very light! Model ORNG4
The new range of OrangeRx receivers are built using original components and MCUs and with state of the art SMT automation to ensure a quality product each and every time.
All OrangeRx receivers are QC tested before leaving the factory.
The OrangeRx will work with ANY Spektrum DSM2 2.4Ghz transmitter
The OrangeRx 4ch is only 2.5g in weight and 36x14x7mm in size. Great for small planes, helis, parkflyers or even medium sized sport planes.
Key features.
Super light weight 2.5g /2.9 grams with shrink tube!
Compatible with DSM2 1024/2048aircraft radio and module systems
4Channels
Compact design 36x14x7mm , with shrink tube37x15x8mm
Short 29mm antenna for mounting in almost any location.
Included.
OrangeRx-4 DSM2 Compatible receiver
Nieuport Fly Guy is offline
Old 06-08-2011, 06:58 PM
Old Fart
Lost at LAX
Old Fart's Avatar
Hmm, should work - I have several of the 6ch in parkflier foamies (bound to my JR XP9303)
What procedure are you going through to bind?
Old Fart is offline
Old 06-08-2011, 07:04 PM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
The failure rate on those cheep clone receivers is very hi. Like Old Fart said - check the procedure your using to bind is correct. If that doesnt work your likely out of luck.
Larry3215 is offline
Old 06-08-2011, 07:06 PM
simibill
General Factotum
simibill's Avatar
I'm guessing the Tx included with the HZ Champ is just a DSM not a DSM2 which is probably what the Orang Rx requires. It should work fine with the Dx6i you are getting.
simibill is offline
Old 06-08-2011, 08:46 PM
Nieuport Fly Guy
The Tx with the champ is dmx2... Binds with my BNF Ember...so maybe the unit is defective. Will affirm when I receive my dx6i!
Old 06-08-2011, 09:21 PM
NJSwede
3D wannabe
NJSwede's Avatar
Does the short range TX that comes with the micro BNFs really bind with full range/parkflyer receivers? Has anyone tested? The digital handshake procedure in digital radio is typically quite complex and the parties identify themselves and usually state what type they are and what capabilities they have. Maybe the small TX tells the RX that it's not full range and the RX refuses to bind? Has anyone tested this?
I'll test this with an OrangeRx and a genuine Spektrum as soon as I get a few minutes later tonight.
NJSwede is offline
Old 06-09-2011, 12:03 AM
Nieuport Fly Guy
Thanks...my newly ordered dx6i is on back order until late June....so it would be nice to know if it is just the stock Rx that don't bind vs the full spectrum ones!
Old 06-09-2011, 08:09 AM
Past President of PSSF
I have several of these RXs, sometimes I have had to get the transmitter ant less than one foot away before it bound, then everything worked fine.
Wildflyer is offline
Old 06-09-2011, 10:27 PM
Nieuport Fly Guy
I just received the hard cased Orange Rx receiver from HK and it binds perfectly with my stock controllers! Perhaps the other one will still bind with my dx6i once received. Anyway ordered more of the hard case Rx's to have on hand for the GWS pico tiger moth and slow stick I ordered.
Old 06-10-2011, 08:37 AM
I just received 2 of the new 9 ch Orange RXs, they look great! They bound perfectly to both my JR 9303 and my JR 8103
I will be doing range and flight tests very soon.
Old 06-10-2011, 05:15 PM
BEAR-AvHistory
RDRC
BEAR-AvHistory's Avatar
sorry misspost
BEAR-AvHistory is offline
jrflyboyVP2
133
08-11-2012 12:36 AM
tallflyer
Company Discussions
04-12-2011 02:10 AM
mxaexm
Scale E-Powered Aircraft
02-12-2011 08:33 AM
bob4432
01-03-2011 05:29 PM
BOBWRC
12-13-2010 05:02 AM
Quick Reply: Hobby King Orange Spektrum receiver?
Page generated in 0.13343 seconds with 13 queries
