Carbon CUb S+ initial settings for elevator after flap installation - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-01-2019, 04:55 PM
Jimigunne
Default Carbon CUb S+ initial settings for elevator after flap installation
I have completed the flap mod on my Carbon Cub S+ and it works great on the bench. Am using it with a DX8 transmitter. On the flap setup page, there are percent options for elevator. I assume this will mix in a little down elevator for approach and more down elev. for full flaps. Am a bit worried that I might set the percentage too much down elevator on initial flight with flaps and it would nose over into the ground. The Carbon Cub manual doesn't say anything about elevator settings for flaps. Does anyone know what are good initial settings?
Jimigunne is offline
Old 07-01-2019, 09:34 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Percentages are useless, they only make sense for exactly the same total throws.
You need mm deflection, or an angle.
ron_van_sommeren is offline
Old 07-04-2019, 02:27 PM
Jimigunne
You have a good point there. I am checking &setting up the appr and full flap deflection to what the Cub manual specifies today, and it would be good if had some clue about how many mm deflection to set the elevator to....so I am at least in the ballpark on the first use of flaps.
Old 07-30-2019, 03:50 AM
F22trainer
You donít really need them, and none are specified in the manual.
I can tell you it will balloon nose up at about 1/3 throttle- you have to force the nose down for a landing. I added some based on the same settings for my T-6 from eFlite and my Cherokee from same vendor. Works out pretty good with the Cherokee settings - check the free download manual from them.
F22trainer is offline
Flite-Metal
Electric Ducted Fan Jets
544
10-12-2018 01:18 PM
boodaghost
9
08-28-2014 02:44 AM
amrmatt
11-06-2013 03:25 AM
Turner
09-25-2013 12:01 AM
eagle33
04-14-2011 11:44 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: Carbon CUb S+ initial settings for elevator after flap installation
Page generated in 0.07195 seconds with 9 queries
