E-Flite Mini Pulse XT - Page 5 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-24-2007, 09:42 PM
  #101
newjak
AMA Park Pilot Partner
newjak's Avatar
Default Re-maiden
Just got back from remaidening my MPXT! I repaired damaged from a crash a while back and upgraded my motor from the PNP 450. I decided to go with the park 480 910kv. Nice upgrade from the pidly 450. I flew through 8 pack with a giant smile the whole time. With the new motor in place it flew fantastically and settled in nicely when time to land...not as floaty as it was with the 450 in the nose. Just happy to have it back in the air
newjak is offline
Old 06-24-2007, 11:27 PM
  #102
RandolphNav
Just out of curiousity..which 480 are most of you using? the 1000 or 900?
RandolphNav is offline
Old 06-25-2007, 12:39 AM
  #103
ronb
Originally Posted by qmulus View Post
I've just tried flaperons (25%) and it REALLY slows the plane down on landing. Actually, I didn't care for it. I might try spoilerons just for fun, but just the normal setup seems fine to me.
With my CellPro 2100s I get 20+ minutes of fairly aggressive flying and still land with 3.4V+/cell with my Rimfire 35-30-950 and a 10x8 prop. YMMV.
FWIW, I have really been enjoying this plane. I haven't even bothered to take others to the field this week.
qmulus,
thanks for your info. Glad to hear that news. With the stock PNP 450 I should have plenty of fly time!
ronb is offline
Old 07-21-2007, 06:48 PM
  #104
truevine77
Did you have any problems mounting the rimfire? I'd like to get the 35-30-1450
truevine77 is offline
Old 07-21-2007, 07:43 PM
  #105
qmulus
Well, I did make my own X mount out of .125" aluminum, which took a trip to the hardware store for an $8 strip of .125" aluminum and about an hour of cutting, filing and drilling, as the bolt pattern of the Rimfire was different than the Eflite motors. Basically, I took the outline and bolt pattern of the aluminum mount supplied with the Mini Pulse and made a new one with the mounting pattern of Rimfire. I also needed to countersink the top screw holes on the mount where the screws bolt to the firewall and bevel the screws a bit with a file so that I could get a ball tipped hex key into the bolts.
It is clean and looks pretty much like it was meant to be that way, but if the Eflite 480s mount right up, I would definitely go that route instead if I had it to do over again. The modification to fit the motor was definitely not worth the price difference between the Rimfire and Eflight motors.
HTH!
qmulus is offline
Old 08-27-2007, 10:30 PM
  #106
Andrew James
Default Himax 2812-850 in a mini Pulse xt
I am looking at the Mini Pulse XT for a second plane after my HZ Super Cub. I have a Himax 2812-850 not doing anything. Will this do well replacing the Park 450?
Andrew
Oct 6/07 - I bought the MPXT last month, yet to fly due to wind and work. I went with the Park 450 (4mm shaft) and the ARF.
Andrew James is offline
Old 08-28-2007, 01:58 AM
  #107
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Andrew
I don't know the 2812-850 other than it's an 850kv motor. The park 450 is a 950kv motor. A large percentage of flyers with the MPXT upgrade to the Park 480 to make the plane a little hotter. Mine still has the 450 and flys really well with it. Your 850 will probably fly the plane but won't give it a lot of extra for aerobatics.
rea59 is offline
Old 08-28-2007, 02:28 AM
  #108
qmulus
Andrew
I bought that motor originally for my Mini Pulse ARF as well, but never flew with it once I compared specs to the Park 450 and 480s. The 2812-850 is rated at 140 watts, which IMHO, would end up with fairly poor performance. A 11x7APC or 10x8 MA prop would probably max it out and it would be rather slow.
I am sure that the Mini Pulse would fly with the Himax, but I would go with ~1000 kV motor capable of 250 watts. The Mini Pulse LOVES to fly fast, and the 2812-850 will definitely leave you wanting for more. It also has a different mounting pattern than the E-Flite motors, so you would have to modify the stock mount or make a mount to fit. Having BTDT, it isn't worth it IMO. Either get the PNP version or better yet buy the ARF, some HS-55s and a Park 480 1020. You will be VERY happy.
FWIW, I like mine so much that I just bought my second Mini Pulse, even though I don't need it. This one was a slightly damaged PNP off of ebay for $75 shipped. The minor damage has been repaired and it is on its way to becoming a "super" Pulse.
qmulus is offline
Old 08-28-2007, 03:51 AM
  #109
qmulus
delete
qmulus is offline
Old 08-28-2007, 11:09 AM
  #110
gsk11740
I'm outta here!
I think I may have to get another Mini Pulse. I totaled mine a few weeks back (brain glitch) and thought I would get something else to replace it. I'm finding out there really isn't a replacement for a Mini Pulse, except of course for another Mini Pulse.
gsk11740 is offline
Old 09-04-2007, 02:27 AM
  #111
RandolphNav
Thinking of getting one of these or another warbird....is the mini pulse like a 3D plane or more of a sporty plane like the MUS? I got the E-flite extra 480 ARF and that's definitely a 3D plane...just curious Is it a lot of fun like the MUS?
Old 09-04-2007, 04:15 AM
  #112
Phoenex
Phoenex's Avatar
Default Pulse video
I have posted a video over at RcGroups if you are interested.
http://www.rcgroups.com/forums/showthread.php?t=737128
Phoenex is offline
Old 09-04-2007, 06:36 PM
  #113
UncleBob
Still Flying G3 ...
It's not a 3D plane, but it's acro-capable. Fun plane, seems a little fragile, particularly the gear. Lots of folks are replacing the gear bolts w/ nylon to preserve things.
UncleBob is offline
Old 09-04-2007, 10:41 PM
  #114
Phoenex
Phoenex's Avatar
You can replace the bolts, but the nylon will snap off and may ram the wheel pants up through covering. Best to just beef up the landing gear area. The only thing I did was to soak the wood in the landing gear area and firewall with CA. Smooth landings should not be an issue with this wing design.
Phoenex is offline
Old 09-04-2007, 11:10 PM
  #115
qmulus
Count me as one who has put the wheel pants into the wings on a hard "landing" with nylon gear screws. Now I use nylon on the wings and the stock steel on the gear with a beefed up mount. I've bent the gear a time or two, but haven't ripped out the bottom. Oh, and I've left off the pretty pants too.
qmulus is offline
Old 09-05-2007, 12:00 AM
  #116
UncleBob
Still Flying G3 ...
A great wing can't smooth a rough field. In any case it's a great plane.
UncleBob is offline
Old 09-05-2007, 02:45 AM
  #117
Phoenex
Phoenex's Avatar
You right about that, one of the runways we are flying from is an old road that is rough and is much harder on the planes.
Phoenex is offline
Old 09-05-2007, 03:01 AM
  #118
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
I'm glad to see there is a thread here on the MP also. Got all the goodies in for mine today. Going together slowly but surely. Maiden planned for this weekend.
Frank
Murocflyer is offline
Old 09-19-2007, 04:37 AM
  #119
dmgcm
Just got one of these puppies myself, its the PNP version, curious what is the average flight time on a 11.1v 2100mah 22c (My Trex Heli Lipo's) pack using the 450 motor and 10X7 prop?
Also new to the aircraft scene, spent more than 15 years in the heli, but what prop sizes are you guys using on the 450 motor? and what dis/ads do you have with the sizes u may use?
I will probally upgrade to the 480 motor a little later on.
Regards
Dm
dmgcm is offline
Old 09-19-2007, 10:58 PM
  #120
rea59
BEEP..Bleep..BEEP
rea59's Avatar
Regards
Dm
I use a 10X6 most of the time....occasionally I'll throw on a 10X8 (little higher current and a little more speed)
rea59 is offline
Old 09-19-2007, 11:14 PM
  #121
dmgcm
Tks for that rea59, and what kind of flight times are you getting?
Regards
Dm
dmgcm is offline
Old 09-19-2007, 11:23 PM
  #122
rea59
BEEP..Bleep..BEEP
rea59's Avatar
As with any plane or heli flight times are a direct result of 1) mah of the pack and 2) throttle managment. The more time spent at WOT the less time spent in the air. I have found every flight to be different as I do different things in each flight. I'm also very conservative not wanting to overtax the pack or have to dead stick in a hurry. Typicaly about 15 min in the air, sometimes with plenty to spare, sometimes not.
3S 2100mah pack
rea59 is offline
Old 09-19-2007, 11:27 PM
  #123
dmgcm
Tks again Rea59,
I was just after an average, so i have an idea how to gage it. Your replies have really helped me
Regards
Dm
dmgcm is offline
Old 10-03-2007, 06:08 PM
  #124
ARTP47
Having a problem with ground handling on my Pulse. The plane has a big pull to the left even with full right rudder. Some people say the gear should be toe in, others say toe out, Still other say increase the ruudder through. Any ideas or help would be welcomed.
P.S. both wheels turm freely and gear has not had a hard bump .
ARTP47 is offline
Old 10-03-2007, 06:29 PM
  #125
newjak
newjak's Avatar
Checkyour tail wheel to make sure that it is straight. I had a similar problem. I had to pull my tail gear a bit forward and made sure it was vertical as well...problem solved. Hope this helps
newjak is offline
Quick Reply: E-Flite Mini Pulse XT
Page generated in 0.15301 seconds with 11 queries
