Eflite Jenny Put-together-thread
Old 04-22-2009, 05:48 PM
  #476
Fly Time
Ask me how I know
Fly Time's Avatar
The 6" prop that E-Flite recommeds looks too small IMO. I use a 7x3 with a TowerPro 2210-21 motor of around 2000kv I think.
Hate to say this, but I'm not sure the E-F 300 outrunner would be a very good motor for this plane. To get any power out of a smaller 6-7" prop, you will need to use a 3 cell lipo, which would be heavy and wouldn't fit without significantly modifying the battery compartment. To use a 2 cell battery with that motor, you are going to have to put a cartoonishly big prop on it, probably 9"-10". Maybe you could try a higher pitch 7" or 8" prop as 7car7 suggests.
Fly Time is offline
Old 04-22-2009, 06:35 PM
  #477
Bub Steve
Bub Steve's Avatar
I thought you were use'in a 3-cell but 8/6 will be ok on her with a two-cell, a 9/6 would be better, the old girl swung a big prop anyhoo! bubsteve
Bub Steve is offline
Old 04-22-2009, 09:12 PM
  #478
C130 Load
C130 Load's Avatar
Originally Posted by stevecooper View Post
I copyied&pasted it,,, Now I got busted,,, Oh-Wellyour bub, steve
Shouldn't have told on yourself,, It fooled me.
C130 Load is offline
Old 04-22-2009, 11:29 PM
  #479
Bub Steve
Bub Steve's Avatar
I'm a bumbubsteve,
Old 06-14-2009, 02:15 PM
  #480
Capt.RJM
Default First time out with the Jenny..
First off I would like to thank all of you folks for the very helpful info on taking this plane from the box to the air. This has been a very painless experience and this bi-plane is a fun, slow and stable platform.
The most important mods were to the rudder and elevator, beefing them up with some 1/32 fiberglass sheeting I had left over from a sub project. Running the wires stiffen up the wing and greatly reduced the flex in flight.
I failed to read into the warning about the carbon fiber tube engine mount. I got lucky the other day when my engine tore loose from the tube and suffered only minor damage to the plastic cowling. This was an easy repair with some plastic screen door material and acutually is an improvement and fuctional now.
[media]http://i154.photobucket.com/albums/s253/CaptRJM/DSC01156a.jpg[/media]
Thanks again for the info and this board is first class...
Capt.RJM
Capt.RJM is offline
Old 10-15-2009, 03:56 PM
  #481
swimmer
After several months of flying my Jenny with the Park 300 IMHO it handles the Jenny beautifully. I do have to use a 9"x4.7 prop and in proportion to the airframe looks very nice. The slightly increased weight of the 300 plus servos used for ailerons does create the need to hold more airspeed when landing but that is no problem.
swimmer
swimmer is offline
Old 10-15-2009, 05:30 PM
  #482
degreen60
Flying Fish
degreen60's Avatar
One of my modeling books shows the real Jenny used a 100 inch prop. Using both span and fuselage length of the Eflite Jenny I avaeraged the scale to be about 1/14. The model needs a 7 inch prop to be close to scale. I am flying on 2s, 1100 kv motor, 7x6 prop. At WOT the prop is turning 6500 rpm and the motor is pulling 5amps. The Jenny will fly on about half throtle.
degreen60 is offline
Old 10-15-2009, 10:32 PM
  #483
details
details's Avatar
Originally Posted by degreen60 View Post
This is just what my Jenny J9 needs. Did you make patterns for the floats you can scan in for others to use? I was thinking of making the floats solid foam. I want then to remove easy so I can fly with wheels too.
degreen60,
A while back when you made a really cool float set for your Jenny and you posted a couple of pictures of real N-9H curtiss floatplanes. I am trying to make one of these a bit more scale-like with the rounded nose and extra bays in the wings.
Do you remember where you found these photos, or have any higher resolution copies? The only other photos of real N-9H I have found have squared off noses
Dave
ID:	111437   Click image for larger version
details is offline
Old 10-16-2009, 03:34 AM
  #484
degreen60
Flying Fish
degreen60's Avatar
Originally Posted by details View Post
degreen60,
Dave
I do not remember where I found the photos. If you will PM me your email address I will email you all the photos I have of N9s
aviatordave
WWI Era
406
05-09-2011 03:13 AM
Liquidity
219
11-01-2010 05:56 PM
aviatordave
3D Flying
59
11-26-2009 11:29 AM
Hugo
Electronic Builders Workshop
10-06-2008 02:41 AM
SGT.SHAGGY
02-22-2008 07:18 PM
Quick Reply: Eflite Jenny Put-together-thread
Page generated in 0.11505 seconds with 16 queries
