Wheel Brakes
Old 11-17-2007, 06:23 PM
simibill
General Factotum
simibill's Avatar
Default Wheel Brakes
Does anyone have any info on mechanical wheel brakes? I remember seeing some years ago which were activated by cables attached to a servo. I think they were made by DuBro, but I don't see any mention of them now.
simibill is offline
Old 11-18-2007, 02:25 AM
Sky Sharkster
Sky Sharkster's Avatar
Default Whoa!! How Do I Stop This Thing?!!!
Hi Bill,
Well, after seeing your post I took a look at some of the links on the "Warbirds" sticky, figured Robart or one of the other retract gear-makers would carry mechanical brakes...nope.
Then I tried Tower and Horizon, a search for "Brakes" got me lots of R/C car listings but no aircraft brakes. A few hydraulic/compressed air systems, but no mechanical or servo-driven.
So, I'm out of ideas!
Good Luck,
Ron
Sky Sharkster is offline
Old 11-18-2007, 02:32 AM
Twmaster
Registered User
Twmaster's Avatar
http://www.hobby-lobby.com/wheels.htm#Brake
Twmaster is offline
Old 11-18-2007, 02:43 AM
Twmaster
Registered User
Twmaster's Avatar
Also a quick Google search found the part number from Du-Bro.
Part #157. they no longer list it on their web catalog. However this link claims to have them: http://www.happyhobby.com/hobb_html/dubro.htm
Twmaster is offline
Old 11-18-2007, 10:04 AM
Boomerang
Boomerang's Avatar
Yes, I have a Dubro brake. It's just a spring wound around a hardened steel drum which locates between the spokes on a wheel.
I also have a Kavan electric brake, as linked by Twmaster, fitted to a turbine model but it's bulky & quite heavy.
Brakes are required on turbine models in the US & other places, usually air operated & quite light & compact. Like most things turbine the biggest weight saving will be to your wallet. - John.
Boomerang is offline
Old 11-18-2007, 03:20 PM
eflight-ray
eflight-ray's Avatar
simibill
It might be worth checking out the model car sites to see if they have anything usable.
eflight-ray is offline
Old 11-18-2007, 10:13 PM
simibill
General Factotum
simibill's Avatar
I didn't see anywhere on the link you provided any mention of Part #157?
simibill is offline
Old 11-18-2007, 10:59 PM
Twmaster
Registered User
Twmaster's Avatar
Go look again.
Twmaster is offline
Old 11-18-2007, 11:08 PM
simibill
General Factotum
simibill's Avatar
Yep, you were correct, I didn't scroll down far enough.
simibill is offline
Old 09-06-2022, 04:55 PM
Flite-Metal
"Look Of The Real Thing"
Flite-Metal's Avatar
Kavan Electro Brake (9 volt) DIY. Simple to set up and use.
Flite-Metal is offline
Old 09-06-2022, 11:15 PM
And @Flite-Metal didn't scroll up far enough
Old 09-07-2022, 12:11 AM
Flite-Metal
Cool ?????????????????????????????
Does anyone have any info on mechanical wheel brakes? I remember seeing some years ago which were activated by cables attached to a servo. I think they were made by owDuBro, but I don't see any mention of them now.
What should you expect for a mechanical brake. The Kavan electic brake provides a proper brake instead of a kinda sorta except on feather-lite models.
.........................................$ 19.31 (Click To Order)
.................................................. .......SKU: 3370.................
Old 09-10-2022, 07:46 PM
Originally Posted by Flite-Metal View Post
You replied in a thread from 2007 Ed.
Page generated in 0.12239 seconds with 15 queries
