Twister 40 Outrunner? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 06-23-2014, 07:13 PM
Davethebluessinger
Child of the 60s
Davethebluessinger's Avatar
Default Twister 40 Outrunner?
Hi,
Just bought a scratchbuilt PushyCat Clone.
It's fitted with a 60A ESC and a "Twister 40" outrunner.
I suspect the motor is quite old, I've googled it but can't find any details.
I'd like to work out prop sizes etc. Anyone know the specs for this motor please?
Davethebluessinger is offline
Old 06-23-2014, 07:37 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
There is a motocalc table that shows up of an EM Twister 19/40, showing 1000 kv. Prop all depends on voltage, 3s would be okay with a 7 inch to 9 inch prop I would think.
thepiper92 is offline
Old 06-23-2014, 07:41 PM
Davethebluessinger
Child of the 60s
Thanks!
Old 06-23-2014, 08:13 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
That may be the wrong motor, but it's all that shows up. Sizing is close to a 2836 motor, longer but less diameter, or at least that's what I would think of the 19/40 part, so a 9 inch prop is probably what you want for the max size, or maybe a really low pitch 10 inch.
Old 06-25-2014, 10:18 PM
Davethebluessinger
Child of the 60s
Default Down on power....
OK so I weighed the plane tonight and it's around 2.15Kg (4 3/4Lbs) including motor, ESC and battery. When I bought it it was running a 10 x 6E prop on a 4S and it wasn't particularly quick, I had a 10 x7 APC Thin electric in the garage so tonight I put that on with virtually no effect. I'm not looking for supersonic speeds but can anyone suggest anything other than motor change to speed her up? If required I will buy another motor (suggestions welcomed) but HK and the like don't have a big stock of these larger motors in the UK warehouse.
Old 06-26-2014, 05:26 AM
Any joy with giantshark.co.uk ?
Old 06-26-2014, 05:47 AM
thepiper92
Warbird Fanatic
thepiper92's Avatar
With that same motor, a 5s and smaller prop is about all you can do, if your setup can do 5s. You can try a 10x8 or 10x10. Not sure if the motor would handle it. How hot is it getting with the 10x7? 4s sounds like a lot for that motor and prop to me. Of course specs aren't exactly available, but I don't think it is anymore that a 300W motor. I have a 1200kv 2836 in my mini switch, 3s and 8x6 and 8x8 prop, and it hauls. Your plane is 3x the mass though, so with that a bigger motor, bigger prop and higher pitch seems the path for speed.
First, see what weight you can dump, like a smaller 4s. Second, check your temps, or better yet a wattmeter, to determine if you can go the easiest route of a 10x10. If that is a no go, then maybe 5s, and a 7 inch prop I'm guessing, although not sure how much more speed would be gained. I would sooner pick up a larger motor, put 5 or 6s, and play around with the props maybe allowing you a 9x9 prop or something.
Old 06-26-2014, 01:40 PM
Davethebluessinger
Child of the 60s
Thanks for the advice, thinking of changing the motor to this http://www.giantshark.co.uk/product/...er-outrunner-m
Any thoughts
Old 06-26-2014, 03:00 PM
It needs a lot more info about the model .. as the Pushycat as sold by HK etc. is a lot different ...
http://www.hobbyking.com/hobbyking/s...earch=pushycat
It is rated at 475gr for a start !!
Or clone of this PUSHY-CAT :
http://www.hobbyking.com/hobbyking/s...rSearch=Pusher
You are really out on your own as the weight is a lot higher and needs serious power.
So go on ... ??
Wingspan ?
Length ?
Motor supplied ?
LiPo supplied ?
ESC supplied ?
Prop size supplied ?
The whole has to be evaluated to get an idea of what motor is best ... but at 2.15Kg - that's some motor you will need.
Old 06-26-2014, 03:51 PM
Davethebluessinger
Child of the 60s
Solentlife, it's a model twin boom pusher built from a scaled up plan in the RCME published about 2010 so not really a pushycat.
Wingspan 52" Length (nose to trailing edge of elevator) 51"
Motor used by previous owner EM Twister .40
Prop 10 x 6E
4S 3700 mah Lipo
Hobbywing Pentium ESC
I will measure and post the Length later.
Old 06-26-2014, 05:02 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
So go on ... ??
Wingspan ?
Length ?
Motor supplied ?
LiPo supplied ?
ESC supplied ?
I noticed that weight too. I couldn't wrap my head around what was making the plane so heavy. Definitely gonna need a bigger motor.
Old 06-26-2014, 05:08 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
Any thoughts
This is a heli motor, so it looks like it can be mounted one way. 1600kv and 4s will scream and at almost 900W, it can take a good sized prop, but you would have to play with props to find the max for this motor.
Old 06-26-2014, 06:46 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
This one seems good. http://www.giantshark.co.uk/product/...rushless-motor
Old 06-26-2014, 06:58 PM
Davethebluessinger
Child of the 60s
Added length of plane to my previous post!
Old 06-26-2014, 08:37 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
I scaled up your wing area using specs from a 36inch wingspan PushyCat, getting 517 sq. inches for wing area. For weight, all out yours is 76 oz, subtract 16 oz for battery and motor, 60 oz. This is likely a bit more than empty weight, but it will work I think.
Results: best is a Turnigy Aerostar 4340 720kV, with a 12x10 prop, max airspeed is showing 81mph, level at 56mph
A slower one: Scorpion HKIII 4025 890kV with a 11x7 prop, 65mph max
For your prop size: Scorpion SII-3020-1110kV, 65mph max.
Old 06-26-2014, 08:53 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
Here is the beast you need: http://www.hobbyking.com/hobbyking/s...ner_900w_.html
Old 06-26-2014, 09:24 PM
Davethebluessinger
Child of the 60s
Thanks thepiper92 however I think I'd have to go with the third option Scorpion.
Reason being if I go up to a 12" prop it'll hit the ground as the nose comes up on take off!
Old 06-26-2014, 10:06 PM
thepiper92
Warbird Fanatic
thepiper92's Avatar
That would be a problem on a pusher. 60mph should be fine though, certainly not slow. If you can't find the motor, find a similar one in kv, and max wattage. You may be able to get a similar size and slightly more wattage, allowing a higher pitch.
29
10-28-2013 07:49 AM
riot3d
Warbird Electrics
08-29-2013 01:10 AM
Air-on
10-16-2011 02:14 PM
Quick Reply: Twister 40 Outrunner?
Page generated in 0.11713 seconds with 11 queries
