castle bec in Viper
Old 09-01-2020, 04:55 PM
jangodog
jangodog's Avatar
Default castle bec in Viper
Castle bec in Viper
Aug 26, 2020, 06:07 AM
Hello. How do i install the Castle bec 10amp in the Eflite Viper? Under the belly beside the esc and do i need any accessories?
jangodog is offline
Old 09-01-2020, 05:38 PM
crxmanpat's Avatar
There is no specific place the Castle UBEC needs to be installed, but you do want it where it will get a little air cooling.
You will need to solder the power leads of the BEC into the battery connection. I think this comes with an EC5 connector, and the pins can be pushed out of the housing (they just snap in). Push the pins out and solder the BEC power leads to them (see example in the pic, the green circuit board is the BEC in this case). You will also need to pull the red wire from the ESC lead to the RX. Take a hobby knife and gently insert under the locking tab in the connector and lift up, then pull the red wire out and secure it with tape. The Castle RX lead then plugs into the RX in the battery/bind port depending on your RX.
Name:	freewing-90mm-edf-f-a-18c-hornet-130-amp-brushless-esc-motion-rc-12477227958385_large.jpg
crxmanpat is offline
Old 09-01-2020, 07:40 PM
jangodog
jangodog's Avatar
Great my friend. Finally someone took the time to help me on this bec issue
I won't connect an extra battery though to the bec just the main lipo.
Thank's.
jangodog is offline
jangodog
09-02-2020 03:42 PM
06-28-2017 05:22 PM
SkyDaddy
03-20-2017 07:54 AM
08-11-2014 04:36 AM
Merritt
08-08-2011 04:55 AM
Quick Reply: castle bec in Viper
Page generated in 0.10632 seconds with 16 queries
