Programming differential thrust with a DX9 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 04-12-2018, 03:45 AM
Default Programming differential thrust with a DX9
I'm putting this here for others who might be searching for help in the future.
After I finished my Baby Divine flying wing, I decided to take advantage of the twin motors to add differential thrust the ability to vary the thrust from right to left. This will add some yaw control. Since flying wings typically have no yaw control, this should be a real plus.
Heres the plane:
The left-hand motor turns normally with standard prop.
The right-hand motor is reversed with pusher prop.
The left-hand motor plugs into the actual throttle channel (THR) on the Rx.
The right-hand motor plugs into the AUX1/FLP channel on the Rx. Since Im using the FLP channel, I first have to disable the flaps. Otherwise, if I accidentally hit the flap switch, I alter the thrust to the right-hand motor. If you're using channel other than Flaps or Gear, you can probably skip this first step.
Disable Flaps
AX1 > FLP
RATE: -100% -100%
OFFSET: 100%
SWITCH: ON
Next, I mix the throttle into the flap channel. I leave trim active.
Mix Throttle into Flap Channel
THR > FLP
RATE: -100% -100%
OFFSET: -100%
SWITCH: ON
TRIM: ACT
Lastly, I mix the rudder into the throttle channels for each motor. I put this mix on Switch B so I can disable it if I want to. I initially set the rate to 60%. Set it to whatever you want, but make sure both mixes use the same rates. The higher the rate, the more the rudder input affects the speed of the different motors.
Mix Rudder into Left-hand motor:
RUD > THR
RATE: -60% -60%
OFFSET: 0%
SWITCH: B
TRIM: INH
Mix Rudder into Right-hand motor:
RUD>FLP
RATE: -60% -60%
OFFSET: 0%
SWITCH: B
TRIM: INH
admin
05-07-2020 05:04 PM
pcm10xmode
Electric Ducted Fan Jets
01-11-2015 03:12 PM
Blackbeltrrf
12
10-07-2014 05:41 PM
propnut48
06-17-2014 12:43 AM
Hose Man
03-23-2011 01:57 PM
Quick Reply: Programming differential thrust with a DX9
Page generated in 0.04318 seconds with 11 queries
