Parkzone micro Spitfire has "Indigestion" - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-23-2013, 04:25 AM
Virgil Kee
Default Parkzone micro Spitfire has "Indigestion"
I live in two states, but can only fly in one of them. Bought the Spitfire in State "A", checked all functions OK. The motor fired up immediately, but I only ran it for a couple of seconds. I was confident that all was well.
HOWEVER, I'm now in State"B" and have had a chance to try to fly it. The motor fires up nicely, runs OK for a few seconds and then, starts to cut out every couple of seconds - - - - Blurp----Blurp ---Blurp! It then lands right away about 10-15 feet away. Following this, the motor will not start AT ALL! By now there is no warranty time left. Baffling!
Has anyone had this particular problem before?
Virg.
Virgil Kee is offline
Old 07-23-2013, 11:28 AM
Virg.
It Sounds like the lipo is bad and not holding a Charge, try a new Lipo.
also flying to LVC all the time will damage a lipo, Low Voltage Cutoff
you plane is equiped with a OCP Over current protection, and will shut down the motor if its drawing to much Electricity, that function could also be defective.
if the prop is tightened to tight, the motor will shut down.
here is the Manual for your plane, look at the trouble shooting section.
Hope that helps, Chellie
http://www.horizonhobby.com/pdf/PKZU2180-Manual_EN.pdf
http://z8rc.com/2012/10/parkzone-ult...bnf-with-as3x/
Old 07-23-2013, 02:37 PM
BBCorvette18
my experience with the micros and what your describing is lipo related like stated above.
BBCorvette18 is offline
Old 07-23-2013, 10:04 PM
Virgil Kee
Default "Indigestion" --- UM Spitfire
After my most recent bench test with the 1-cell lipo I was using, I checked its voltage at a robust 4.0+! I'll check the troubleshooting section of the manual. Thanks, Chellie BTW, do you haunt these forums daily? Has this activity totally replaced modeling for you? Virg.
Old 07-23-2013, 10:58 PM
Hi Virgil Your lipo might take a charge, but it may not want to hold the charge and the capacity under a load, try a new lipo, I Haunt this forum a lot I have not been doing to much flying lately, I need to get some of my planes back in order Take care, Chellie
Old 07-24-2013, 12:24 AM
LiPos that have sat on the shelf a long time may accept full charge but be unable to deliver rated current.
It can test 100% OK at 1C and be useless for flying.
Old 07-24-2013, 02:25 AM
BBCorvette18
a fully charged 1s lipo should be 4.2 volts 3.85 is storage
Old 07-24-2013, 03:04 AM
Wisc-BK
Watch this........:-(
Wisc-BK's Avatar
That is the way both my UMX T-28 ( 1s ) and E-Flite UMX Mig 15 ( 2s ) operate when the batteries are nearing LVC. Like Chellie says, try a different battery, it may appear charged but not be able to deliver under load. If all else fails, call Horizon, they are very helpful to customers of their products, they have helped my friend out many times and in some cases sent new parts free of charge.
Bob
Wisc-BK is offline
Old 07-24-2013, 04:36 AM
GBLynden
I agree with the others. It is time to try other batteries before your plane gets destroyed and no one wants that.
GBLynden is offline
Old 07-24-2013, 06:00 AM
Virgil Kee
Talking UM Spitfire "Indigestion" -- Final?
Thanks again, all. I did another bench test. The results were STRANGE, but apparently I've found battery-handling techniques that can work around any problem.
Dean in Milwaukee
07-03-2015 09:05 PM
coreman
26
10-25-2013 04:25 AM
02-20-2012 06:54 PM
ggunners
Flight Simulators
03-28-2011 08:37 PM
ggunners
Flight Simulators
12-27-2010 11:18 PM
Quick Reply: Parkzone micro Spitfire has "Indigestion"
Page generated in 0.10283 seconds with 13 queries
