need help choosing servos!!!!! - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-11-2009, 03:43 PM
swedendude
Exclamation need help choosing servos!!!!!
hi i was just wondering if a servo in the descripion says 4-6 volt but im running a 10.6 volt battery does this mean ill fry the servo???
swedendude is offline
Old 01-11-2009, 04:01 PM
smokejohnson
smokejohnson's Avatar
More than likely your ESC has a BEC built in that will lower your voltage to run the receiver. If not than you will need an external BEC that will serve the same purpose.
What type of ESC are you running?
smokejohnson is offline
Old 01-11-2009, 04:03 PM
swedendude
im not sure yet but its going to be a newer brushless esc
If you are using the onboard BEC in the ESC then that is the way it will work. The main power will be provided to the motor and the ESC will step down the voltage to the servos in the proper range.
No if you are going to use a separate flight battery then you will need a 4.8 to 6v pack for that unless you use a separate voltage regulator.
Old 01-11-2009, 04:11 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Since you have the voltage concern put to rest, the next step in choosing a servo is figuring out the correct application. This depends on the plane and its purpose in life. Typically lighter/smaller planes can use lighter servos -not always the case but most of the time.
What plane are you looking to add servos to? The good thing is, most manufactures worth their salt will recommend what servos to use in their planes.
Frank
Murocflyer is offline
Old 01-11-2009, 04:16 PM
swedendude
its a 42 inch trainer electric plane but see it didnt come with a manual it was like a off brand its not foam
Old 01-11-2009, 04:18 PM
swedendude
k
Old 01-11-2009, 04:24 PM
smokejohnson
Do you already have this plane or are you bidding on it?
Old 01-11-2009, 04:26 PM
swedendude
i already bought it
Old 01-11-2009, 04:28 PM
smokejohnson
What all do you have for the plane already?
Radio, battery, motor...anything?
Old 01-11-2009, 04:30 PM
swedendude
nothing yet but im buying the rd8000 airtronics tx and rx for it
Old 01-11-2009, 04:33 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Wow, I was going to ask the same question.
Two pound airplane? For servos, I would use HS-65s. Those will not give you any troubles.
Frank
Old 01-11-2009, 04:36 PM
swedendude
why is this a bad plane? thanks do i need different servos for rudder elevator and ailerons thanks
Old 01-11-2009, 04:39 PM
Probably not a "bad" plane per say. Getting one like that to start out on proves to be more difficult for the new flier as you have to figure out what all it needs as opposed to a ready to fly model like the HZ Supercub that comes complete and takes all the guess work out of it.
http://www.horizonhobby.com/Products...ProdID=HBZ7100
But since you have already bought this one, like I said before, we'll help you get there.
The one model servo will be fine for all your surfaces on this model.
Old 01-11-2009, 04:41 PM
swedendude
i know but i beeen flying the firebird phantom and hobbyzone supercub for a long time now and think im ready to step up a little
Old 01-11-2009, 04:42 PM
swedendude
i have both planes
Old 01-11-2009, 04:43 PM
That's right, you mentioned that already and I forgot again...
I need more coffee...:o
Old 01-11-2009, 04:44 PM
swedendude
lol
Old 01-11-2009, 04:46 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Please keep us posted on progress since we are not familiar with this plane, it would be nice to learn more about it. Pics are a plus.
Frank
Old 01-11-2009, 04:47 PM
swedendude
but do u need different servos for the functions on the airplane???
Old 01-11-2009, 04:49 PM
swedendude
alright i will but right all got got is what u see in the ebay pictures i wont have anything else en till i get parts for it. but i will kepp u posted and try todo pictures.
Old 01-11-2009, 04:51 PM
smokejohnson
No...the same servo will work fine on all the control surfaces. As Frank said the Hitec 65's would work well. The SG90's from Heads Up would also work. Just depends on how much you want to spend.
Old 01-11-2009, 04:53 PM
swedendude
alright
Old 01-11-2009, 04:56 PM
swedendude
the reciever im getting says only z connectors for servos are there things so can run different servos like that have s connectors sorta like adaptors???
Old 01-11-2009, 04:59 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
They'll fit. No worries.
Frank
Quick Reply: need help choosing servos!!!!!
Page generated in 0.17224 seconds with 12 queries
