Using 2S Lipos on brushed motors? OK?? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-04-2009, 08:06 AM
diverdon
diverdon's Avatar
Default Using 2S Lipos on brushed motors? OK??
Hello , I am putting together a plane for a friend of mine who has helped me so many times with lots of different things . I am going to use a brushed motor and the voltage listed is 9.6 volts .. Can I use a 2 cell lipo motor with this motor ?? Seems like a good Idea to me ..
What I am building is a super cub as a lot of you know you can buy the parts pretty cheap without the "crash saving" stuff I have this 480 motor eflite that fits the transmission real good .. it might not e right but I'm gonna use the transmitter that comes with the plane . Good enough for a beginner ? I think ..
But anyhow the only question is the battery 2 cell lipo .. should work fine eh . ... Thanks .. Hope everyone had a safe holiday , Don J.
diverdon is offline
Old 01-04-2009, 10:19 AM
slipstick
Yes you can use a 2S (7.4V) battery with a 9.6V motor...but the power you get out of it will be seriously reduced. You might want to try a bigger prop than usual to get some of the power back but then you need to be careful that the current doesn't get too high.
9.6V nominal brushed motors were typically used on 12V or more in the real world. I think I'd be looking at a 3S battery for it .
slipstick is offline
Old 01-04-2009, 10:41 AM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Don,
That's very generous of you. Good job. As mentioned by Steve, just be careful of the amps you are drawing out of those batteries with the 480 motor. Sounds like you are gearing it, so that will help. The 7.4V will make your plane pretty anemic though. A 3 cell is definitely the way to go.
Frank
Murocflyer is offline
Old 01-04-2009, 12:04 PM
diverdon
diverdon's Avatar
Thanks everyone , I'm OK going with the 3 cell lipo jus was afraid that it might burn out the motor .. My first cub I even did the "Break in procedure . i forget the whole thing but it involved using water to run the motor in .. Anyhow I started it up and the motor cooked in 10 secomds ,
Just my luck I guess .. No Big Deal Gonna try it again.No Water break in thou Thanks , I'll Let you all know how it works out , Don J.
diverdon is offline
Old 01-04-2009, 12:21 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Good luck Don and let us know how it turns out.
Frank
Old 01-04-2009, 01:20 PM
gfdengine204
gfdengine204's Avatar
Don,
2 things:
1. The 3S lipo may be a little more than that motor is designed for, so the brushes may wear out prematurely. Just so you are forewarned. Of course, if it DOES fail prematurely, it's a good excuse to replace it with a brushless setup.
2. Your ESC for that brushed motor may not be Lipo-friendly, meaning it's Low Voltage Cutoff will not be appropriate for Lipo packs. If you are not using an ESC specifically compatible with Lipos, you should run a short flight, land, and check battery voltage. You do not want to run that pack lower than 3.0V/cell (and preferably, IMHO 3.3V per cell to be on the safe side). For 3S that would be no lower than 9.0V (9.9V with 3.3V rule). Run a short flight of, say, 5 minutes, land, measure voltage and that should give you an idea where you are. Recharge your Lipo, note how many mAh go back in, and that should confirm your findings. You don't want to run these down too low or you risk ruining the pack.
gfdengine204 is offline
Old 01-04-2009, 03:16 PM
skyvolt12
skyvolt12's Avatar
Hi everyone,
I have a similar problem except a much better motor (Astro 05) direct drive. The plane I have it in is Bob Kopski's "Skyvolt", a great flyer. I had thought of 2 cell Lipo's, but now I am considering three cells and propping it to keeping it at 30 amps. I have had a FMA Lipo charger for a couple of years now but have yet to venture in to Lipo's. Fear of explosive out comes I guess. I sure would welcome any comments. Thanks in advance
Kenny
skyvolt12 is offline
Old 01-04-2009, 03:36 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Kenny,
Not a problem at all. This says it can run on 3-5 LiPo cells.
http://www.astroflight.com/index.php...products_id=72
Frank
Old 01-04-2009, 03:57 PM
Crash Test Dummy
Crash Test Dummy's Avatar
Re: Lipo cut off. If you stay with a brushed set up you can get some nice brushed controlers from Electrafly that will detect 2,3,and 4S Lipo cut offs. This will allow you to get max flight time without the worry of killing you Lipos.
http://www.electrifly.com/escs/gpmm2005.html
CTD
Crash Test Dummy is offline
Old 01-04-2009, 04:17 PM
skyvolt12
skyvolt12's Avatar
Hi again--- Super fast reply. The Astro ad that you are showing is for brushless 05.
Old 01-04-2009, 05:15 PM
Murocflyer
WAA-08 Pilot #1
Murocflyer's Avatar
Oh OK. I don't see them listed on their site and since I don't have one I can say for sure. Odds are it will be just fine but give them a call tomorrow to be sure.
I did find this for you though.
http://www.rcgroups.com/forums/showt...05#post3857710
Frank
Old 01-05-2009, 04:12 AM
diverdon
diverdon's Avatar
Hello , Thank you everybody for all of the great advice . I will let you know how it comes out .. Oddly I have 3 or 4 "Projects" going on right now ? That doesn't seem to happen to anyone else does it ??
Thanks Again , Don J.
diverdon is offline
Old 01-05-2009, 04:43 AM
Crash Test Dummy
3 or 4 projects at one time Naw, that never happens to me, LOL!!! Are you kidding, if I'm not building something, I'm fixing the last couple of planes I just crashed, LOL!!
CTD
wollins
10-04-2008 08:32 PM
jtcarn
09-09-2008 01:56 AM
tmackel
Batteries & Chargers
09-10-2007 12:07 AM
Warden
11-28-2005 02:57 PM
Milton
11-11-2005 02:35 AM
Quick Reply: Using 2S Lipos on brushed motors? OK??
Page generated in 0.07481 seconds with 13 queries
