MCX charger = crap - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
MCX charger = crap
Old 12-28-2008, 09:54 PM
Liquidity
Combat Vet
Liquidity's Avatar
Default MCX charger = crap
I dislike the MCX charger. So I did something about it. I threw it almost all of it away, after I stole the 2 pieces I needed to make an adapter so I can charge my mcx lipos off my regular charger.
Here are some pics.
Basically I opened the MCX charger, unscrewed the 2 screws that holds the bare wires to the case. Then I cut the 2 wire leads. I then installed 2 power power connectors (Any connector will work fine) and plugged it into my charger.
Very simple. See my pics if you need to. I made an adapter to connect to the banna plugs I aready had.
ID:	88217   Click image for larger version
ID:	88218   Click image for larger version
ID:	88219   Click image for larger version
Liquidity is offline
Old 12-28-2008, 10:05 PM
groundrushesup
groundrushesup's Avatar
Here are some pics.
Bloody Brilliant. I actually planned something similar but I ordered the female of the 1S connector from Redrocket hobbies to do so.
groundrushesup is offline
Old 12-28-2008, 10:11 PM
gfdengine204
gfdengine204's Avatar
That is outstanding. Like GRU, I too ordered the female end, and planned on putting banana jacks on it. What settings are you charging your batts on that charger (which is the same as mine. Scary! LOL)?
Thanks Bryan!
gfdengine204 is offline
Old 12-28-2008, 10:12 PM
Liquidity
Combat Vet
Liquidity's Avatar
I have 3 chargers. With a 4th one on order.
I charge the MCX lipos at 100mA. Or 0.10A for you unedumacated folk
Old 12-28-2008, 10:14 PM
Liquidity
Combat Vet
Liquidity's Avatar
Oh yeah... I figured it was worth stating this. Do NOT use servo plugs. The male servo ends are too thick and will stretch out your contacts on your battery and they will not work in the plane.
Old 12-28-2008, 10:15 PM
groundrushesup
Thanks Bryan!
Yep still no word from Red Rocket on availability but hope springs eternal.
Old 12-28-2008, 10:40 PM
gfdengine204
Bryan,
Have you tried .3A? The E-Flite charger charges at that rate. It would cut your charge time down some.
Old 12-28-2008, 10:42 PM
Liquidity
Combat Vet
Liquidity's Avatar
Nope I havent tried it. But I will.. I had no clue the mcx charger chargers at nearly 3C that is crazy
Old 12-28-2008, 10:53 PM
gfdengine204
Well, IIRC, 1C is more important for multi-cell packs to ensure they stay closer in balance, not an issue with a 1S cell.
I may try .5A on one just to see, but when I start using my Accu-Cycle I'll charge them at .3A.
Old 12-29-2008, 02:55 AM
rcproptester
We the People...
rcproptester's Avatar
where at?
rcproptester is offline
Old 12-29-2008, 03:06 AM
groundrushesup
Originally Posted by rcproptester View Post
where at?
This should be the one.
Old 12-29-2008, 03:10 AM
rcproptester
We the People...
cool thanks!
Old 12-29-2008, 03:12 AM
groundrushesup
cool thanks!
No sir, I am not to be thanked, for it is the mighty power of Google that has saved the day.
And perhaps my fingers for the typing part.
Old 12-29-2008, 03:30 AM
rcproptester
We the People...
I should have googled it, but I am lazy. that is why I thanked you
Old 01-10-2009, 06:17 PM
groundrushesup
Default Like Liquidity,
I decided to take matters into my own hands and hack up the stock charger for the female connector. Of course I did this the day before I got the female connector in the mail, but oh well, it works great.
I am charging the single cell I have right now (70mAh) at 3C (.21A) just to be on the safe side - I have put many many cycles through it. Now I'm just waiting for my Tenergy cells to arrive.
Pics below.
GRU
ID:	89886   Click image for larger version
ID:	89887   Click image for larger version
ID:	89888   Click image for larger version
ID:	89889   Click image for larger version
Old 01-10-2009, 06:53 PM
gfdengine204
Well, I got one of these.....perhaps I should tear open one of my chargers (I have two) and snag another connector......
Old 05-01-2009, 09:21 AM
Toddy86
Hi Liquidity,
I am a recent convert to Anderson Power Poles (due to my complete ineptitude with a soldering iron) and I noticed in your pictures that you had used them too. Could you tell me whether you used the 15 or 30 AMP connectors?
Toddy86 is offline
Old 05-07-2009, 10:54 AM
rcproptester
We the People...
I think he uses either depending on the size battery
Old 05-07-2009, 03:43 PM
Liquidity
Combat Vet
Liquidity's Avatar
Sorry I have been out of this thread for awhile.
If you have the 15A connectors, use them. I didnt have any 15A on hand, so I used 30A connectors. The wire from the charger is very thin and would be better with the 15A
Old 05-07-2009, 11:59 PM
Toddy86
Thanks for that, I took the plunge last night with my 30A connectors but used the 15A hole on the crimping tool just so it would crimp tighter and it seems to have worked well. I love powerpoles!!!!
Toddy86 is offline
KE4NYV
E-Flite Helicopters
28
05-10-2011 05:23 PM
mjack777
E-Flite Helicopters
11
01-03-2009 06:14 PM
WingingIt74
E-Flite Helicopters
12-17-2008 07:09 PM
KE4NYV
E-Flite Helicopters
11
12-14-2008 12:01 AM
Old Blade Man
E-Flite Helicopters
11
11-14-2008 06:29 PM
Quick Reply: MCX charger = crap
Page generated in 0.08997 seconds with 23 queries
