proper lipo charging question - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-27-2008, 05:27 PM
brokenblade
Default proper lipo charging question
Hi,
I just got a IMAX B6ac and it works good but I want to make sure I'm charging right so I won't mess up my batteries. I'm charging both 7.4 2s batteries and 11.1 3s. All with different mah ratings. Do I charge at 1c for all of them or is that a starting point where you do 1c with some math for each battery. Also do I ever discharge them. I always thought discharging, then charging and balancing refreshed the batteries. Thanks for any input.
brokenblade is offline
Old 12-27-2008, 05:33 PM
Twmaster
Registered User
Twmaster's Avatar
Hi Brokenblade and welcome to WattFlyer!
1C is pretty much the standard for charging lipo batteries.
As for discharge, I usually set my charger for 2C and let'er go. However I almost always balance while charging my packs.
Twmaster is offline
Old 12-27-2008, 05:40 PM
brokenblade
Default Lipo discharge
Thanks for the info. How often should you discharge Lipo's? I'm thinking when the cell rates change quite a bit. Am I right? Thanks again
groundrushesup
groundrushesup's Avatar
Originally Posted by brokenblade View Post
Hi,
1C is different for each battery. For a 2200mAh lipo, 1C is 2.2 Amps. For a 900mAh LiPo, 1C is .9 Amps. 1C is the safe spot for most chargers, and it will preserve your batteries. No need to purposely discharge them (unless you intend to store them for extended periods, but thats different). In fact, discharging them too far will seriously harm them.
This RCG post does all the 'splainin' you are looking for - read it. Its important.
GRU
groundrushesup is offline
SUPERSPORT
11
04-18-2008 06:41 PM
Micro_R/c.co.za
10
10-18-2007 09:55 AM
Lawn Dart
10-28-2006 05:52 AM
Lawn Dart
9
10-16-2006 04:50 AM
Dick Schenz
15
06-29-2006 06:09 AM
Quick Reply: proper lipo charging question
Page generated in 0.05460 seconds with 13 queries
