ESC to BEC connection Question - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-20-2008, 06:17 PM
fjintx
Default ESC to BEC connection Question
I am new to electrics and can't find this answer posted online. How are you guys attaching the wires from an external BEC to the ESC? I am trying to solder them to the same Deans connector that goes to the battery and having a lot of trouble connecting two wires at the same time to each Deans terminal. It just occured to me that maybe there is trick to doing the connection.
Thanks in advance for any advice!
Frank
fjintx is offline
Old 12-20-2008, 06:22 PM
Twmaster
Registered User
Twmaster's Avatar
You have the right idea. However in soldering you ideally should have a good mechanical connection before putting solder to the parts. I typically, when using Dean's[0], will take about 10MM of insulation off the wire from the BEC and wrap it around the power lead to the ESC. Solder that then solder that to the connector.
Mike N
[0] I no longer use Dean's as the EC3 connectors are much simpler to deal with for me.
Twmaster is offline
Old 12-20-2008, 06:26 PM
fjintx
Mike,
Thank you for the quick reply. I was sure there must be some special trick to getting these two wires on the same Deans connector. I'll redo the wires per your advice.
Thanks for the guidance.
Frank
fjintx is offline
Old 12-20-2008, 11:33 PM
Dr Kiwi
Here is my mock up for a UBEC installation - as mentioned, twisting the two wires together before trying to attach 'em to the Deans is the answer.
Name:	BEC connection 002 640.jpg
Dr Kiwi is offline
Old 12-20-2008, 11:54 PM
fjintx
Thank you Doctor. Sending the detailed photo is very kind of you! Now I know exactly how everything hooks up and how to do the leads so that they stay put. I just soldered the BEC to the ESC by twisting the wires before soldering. I then used heat shrink to add additional holding power and for strain relief.
Everything is working perfectly.
Thanks again for taking the hassle out of this gas to electric conversion.
Frank
fjintx is offline
Old 12-21-2008, 12:01 AM
Twmaster
Registered User
Twmaster's Avatar
Excellent job! Glad to be of help! Don't forget to disconnect the red wire from the ESC if your ESC has a BEC onboard.
Twmaster is offline
Old 12-21-2008, 01:00 AM
Bub Steve
Bub Steve's Avatar
The Good Dr, is right, Don't for get to tin the poo out of um as well, here my set-up for the twins till my new UBEC from Heads-up gett's here,I can switch-um out from one to the other fast, bub, steve
Name:	petty an red 809.jpg
ID:	87361   Click image for larger version
Name:	petty an red 810.jpg
Bub Steve is offline
Lymph
Beginners - Helis
8
05-26-2008 12:06 AM
Franny
Castle Creations discussion
05-31-2007 11:24 PM
kf6gub
04-27-2007 12:40 AM
kf6gub
12-07-2006 02:31 AM
Quick Reply: ESC to BEC connection Question
Page generated in 0.06250 seconds with 17 queries
