Blade cp pro inverted - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-05-2008, 11:22 PM
Futurepilot13
Futurepilot13's Avatar
Default Blade cp pro inverted
Does anyone no how to uninvert the blade cp pro because it is inverted now i dont know how to uninvert it for normal flight mode.
Please help me.
James,
Futurepilot13 is offline
Old 12-06-2008, 04:33 AM
vortex05
Blade CP, Blade 400
I don't understand you mean turn off the idle up switch?
vortex05 is offline
Old 12-06-2008, 06:06 AM
Futurepilot13
Default No
No i mean when i start it up as i slowly speed up it just pushes the air up instead of down, I dont know how to make the air go down it is in inverted flight mode. i need it in normal flight mode.
Thanks,
James
Old 12-06-2008, 06:52 AM
vortex05
Blade CP, Blade 400
Did you plug the motor wires in reverse? Have your checked to see if any of your channels on your Tx have been changed? (the little dip switches at the bottom of the tx)
vortex05 is offline
Old 12-06-2008, 05:34 PM
Futurepilot13
Default Yeah
Yes i cheched that to man this is really getting me PO. LOL
well thanks for your help mabey someone else can help me like you did.
Thanks, James
Old 12-06-2008, 06:26 PM
vortex05
Blade CP, Blade 400
I guess if you could post a video or a picture of what the heli looks like with the motor disconnected but the throttle in the position that it would be in when in flight it would help us judge the blade angle.
If you can take 2 pics 1 with the throttle at 0 and one with it at 100% we can determine if you have it set at the right angles.
vortex05 is offline
Old 12-06-2008, 06:31 PM
TDisaster
TDisaster's Avatar
Put your blades on upside down?
Hey it happens .
TDisaster is offline
Old 12-09-2008, 06:07 PM
Futurepilot13
Default Yes
Yeaha ive done that i think i know the pron\blem if it is not the problem then ill heep yall up to date thanks for yalls time,
James
Old 02-25-2009, 04:18 PM
EpoweredRc
3D Flyer
EpoweredRc's Avatar
I would say the blades on backwards or the motor running wrong direction. I dun both of those with my first CP I felt so stupid when someone told me HA ha
EpoweredRc is offline
Old 02-25-2009, 05:55 PM
RyuuChi
did you try reversing the cyclic servos? it sounds to me like they're moving the wrong direction when you throttle up. This is not "inverted mode" I'm guessing that you're using the stock radio so there's no way to reverse the swash mix, so just try reversing the three servos that are on your cyclic control. let us know if that works.
RyuuChi is offline
Old 02-26-2009, 05:19 AM
Alpha_&_Omega
Too many birds
try moving the throttle past mid stick (the left stick). sound like you may be in idle up mode...a.k.a stunt mode. up until mid stick you will have negative pitch... so you can fly up side down. past mid sick you should be able to get some downward thrust. I you know this already, sorry for the basics, but its a common mistake.
if you do know this, check your servo movements and pitch settings.
Alpha_&_Omega is offline
20Q
E-Flite Helicopters
43
07-29-2010 02:21 PM
tcorn
E-Flite Helicopters
10-27-2007 05:33 PM
rfalls86
10-16-2007 02:23 PM
vortex05
E-Flite Helicopters
07-10-2007 02:45 AM
kmagvette
E-Flite Helicopters
36
06-17-2007 11:39 PM
Quick Reply: Blade cp pro inverted
Page generated in 0.13159 seconds with 13 queries
