buying a radio - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
buying a radio
Old 11-14-2008, 04:37 PM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
Default buying a radio
Well Ive been saving up my cheeseburger money & I finally have enough to buy a descent radio.at least I think its a descent radio. my question is do you have to use the receiver or will any 72mhz receiver work with it
JR XP-6102-ULTRALITE FM AIR/HELI 6-CH RADIO+RX+SERVOS - eBay (item 220311416034 end time Nov-19-08 17:35:03 PST)
Rolling Thunder is offline
Old 11-14-2008, 05:42 PM
Sky Sharkster
Sky Sharkster's Avatar
Default Any Receiver?
Hello Rolling Thunder,
The answer to your question is "Almost".
In the US, receivers are divided into "Shifts". This is the way the frequency band transmission from the transmitter is divided and decoded by the Rx. Futaba + Hitec are negative shift, JR + Airtronics are positive shift.
The manufacturers are smart enough to know that users of one brand transmitter may want to use a RX from another company. So, Hitec, for example, sells its Rx's in both shifts, positive + negative, even though only negative shift will work with Hitec transmitters.
Now, you have (or, may buy) a JR radio, which comes with a JR Rx, which works on positive shift. You can use any other FM positive shift Rx, which has a matching crystal tuned to the same channel as the Transmitter. The channel will be clearly marked on both the Transmitter and a little tag on the supplied Rx/crystal.
Or, you can buy a Rx which is "Auto-Shift" detect, Berg Rxs have this capability. As long as you get a matching crystal on the same channel as your Transmitter.
Hope this helps, here's a thread from Ed Anderson (AEAJR) with a full explanation;
http://www.wattflyer.com/forums/showthread.php?t=7008
Good Luck!
Ron
Sky Sharkster is offline
Old 11-14-2008, 05:50 PM
Rolling Thunder
Thanks Skysharkster I appreciate the info.I think I will go ahead & order one
Phil00722
04-24-2008 04:42 PM
Spankys Flying
General RC E-Heli Talk
17
03-10-2008 08:04 AM
Sir Raleigh
20
06-13-2007 07:47 PM
ronb
ParkFlyers
10
04-06-2007 06:27 PM
chrisburrough
Standard & Large E-Heli Talk
11-28-2005 03:07 AM
Quick Reply: buying a radio
Page generated in 0.06243 seconds with 12 queries
