A Scratch Builder (Trying to do the "Nasty") - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-13-2008, 02:14 PM
King Cobra
Permanently Banned
Thanks Tyler, sound great. It will be cool to see 2 Nasty's come togeather in different foam. Here are some pictures and weights after the initial sanding. Any comments and suggestions are more than welcome. I will be using te Zagi 400 ( I hope ) Enjoy. Matt
Name:	My 3-D Foamy 005.jpg
ID:	72508   Click image for larger version
Name:	My 3-D Foamy 001.jpg
ID:	72509   Click image for larger version
Name:	My 3-D Foamy 007.jpg
ID:	72510   Click image for larger version
Name:	My 3-D Foamy 009.jpg
ID:	72511   Click image for larger version
Name:	My 3-D Foamy 013.jpg
Name:	My 3-D Foamy 017.jpg
ID:	72513   Click image for larger version
Name:	My 3-D Foamy 019.jpg
ID:	72514   Click image for larger version
Name:	My 3-D Foamy 025.jpg
ID:	72515   Click image for larger version
Name:	My 3-D Foamy 022.jpg
ID:	72516   Click image for larger version
Name:	My 3-D Foamy 041.jpg
King Cobra is offline
Old 07-13-2008, 02:27 PM
King Cobra
Permanently Banned
Did you go with the 5mm?, and I am interested in your weights if possible. I took my sanded foam to work and checks the weights. I guess I got lucky to get the flaps equal in weight. I used a letter digital letter scale. I will take my electronics and motor tonight and get a weight check and I will know where I am so I can plan ahead. I don't think I can stay below 20 oz. Thanks. Matt
Name:	My 3-D Foamy 002.jpg
Old 07-16-2008, 12:00 AM
King Cobra
Permanently Banned
My electronics equaled aroun 9.5 oz for a total with foam to be around 12.5. I can go lighter tho. Matt
Old 07-16-2008, 12:10 AM
King Cobra
Permanently Banned
OK, after seeing this cool foamy take shape, I decided that I wanted stronger flaps. I found this styro wing and not sure what it came off. I don't have the fuse. Looks like a cub. Anyone recognise the factory plane number printed on the wing? Anyway, I cut and trimmed and took it to my table saw and hand sanded it. I really like it. It will take some abuse because it is strong.I would like to use hinges(real) and not tape if I can help it. Anyway, here is where I am. Any updates Tyler? Matt
ID:	72813   Click image for larger version
ID:	72814   Click image for larger version
Name:	My 3-D Foamy 003.jpg
ID:	72815   Click image for larger version
Name:	My 3-D Foamy 004.jpg
ID:	72816   Click image for larger version
Name:	My 3-D Foamy 006.jpg
ID:	72818   Click image for larger version
Name:	My 3-D Foamy 008.jpg
ID:	72819   Click image for larger version
ID:	72820   Click image for larger version
Old 07-16-2008, 12:16 AM
King Cobra
Permanently Banned
OK, after taking them flaps to the table saw to shave off a 1/4" and hand sanding them with a block, they came out great. Nearly just as light also. I believe I may use bamboo skewers instead of the carbon tubed arrows, for strenght and lightness. How would you hinge your flaps? Matt
Name:	My 3-D Foamy modified 001.jpg
ID:	72822   Click image for larger version
Name:	My 3-D Foamy modified 002.jpg
ID:	72823   Click image for larger version
Name:	My 3-D Foamy modified 003.jpg
ID:	72824   Click image for larger version
Name:	My 3-D Foamy modified 004.jpg
ID:	72825   Click image for larger version
Name:	My 3-D Foamy modified 005.jpg
Name:	My 3-D Foamy modified 006.jpg
ID:	72827   Click image for larger version
Name:	My 3-D Foamy modified 008.jpg
ID:	72828   Click image for larger version
Name:	My 3-D Foamy modified 010.jpg
Old 07-16-2008, 12:40 AM
TylerJCooper
TylerJCooper's Avatar
Matt your smoking me and yours looks better. I am starting to regret sharing this thread with you. I was able to get a little more work done. Basically, I was able to do the cut out. I am waiting now to get some carbon rods to strengthening. I hope to have the rods within the next week and start progressing forward.
Matt, you Nasty is looking sweet! Keep it up. Can't wait to see it's maiden flight.
ID:	72830   Click image for larger version
ID:	72831   Click image for larger version
TylerJCooper is offline
Old 07-16-2008, 01:05 AM
King Cobra
Permanently Banned
OK, but time for me to get smoked. I found these hinges in the shop. I really want to use them and I think the wing flaps will be ok with two red ones on each flap. I wish I had one more red one. I would be apt to use three on each flap. Anyway, here is where I get slowed down. NOW I am gonna see if I can find more material to replace the tail feather foam. The flaps take alot of abuse when things get wild. I will look for carbon rod myself. That is better than my carbon arrow tubes. here is a pic of some hinges I found. Thanks for the great comments. Matt
Name:	My 3-D Foamy hinges 002.jpg
Old 07-16-2008, 01:09 AM
King Cobra
Permanently Banned
Tyler: Yours looks like a real 'Nasty'. I wish I had blue core to use. Things would have been alot easier,but, I am stuck shaping my thick foam. I may have to find me a Zagi 560 before it is all said and done . Keep up the great work. Matt
Old 07-16-2008, 01:16 AM
aero_k
aero_k's Avatar
Both are looking good. Keep up the good work. Looking forward to final products...
aero_k is offline
Old 07-16-2008, 02:15 AM
Mthomas
Mthomas's Avatar
I have been building an Ikarus Nemesis.. but these look to be easier and almost as strong.. I guess that this is next on the building board...
Mark
Mthomas is offline
Old 07-19-2008, 10:57 PM
TylerJCooper
Well, I haven't got too much more done. I am waiting till I can get a Carbon rod to put in the wing and fuselage. While, I have been waiting I decided to do some sanding and cut the ailerons and elevator. I used 220 grit sand paper to put a round edge around the fuselage, rudder, front of the wing, and front of the elevator. I put a 33 degree sharp edge on the back of the elevator and ailerons.
It is hard to see the edges in the pictures, but I figured I would put them up anyway.
ID:	73202   Click image for larger version
ID:	73203   Click image for larger version
ID:	73204   Click image for larger version
Old 07-19-2008, 10:58 PM
TylerJCooper
Matt, I have been trying to figure out the numbers on your plane, but no luck. What are they?
Old 07-21-2008, 12:11 PM
NOZ69R
Default Motor & Prop Choice
Hey guys,
Have been watching both of the "Nasty" threads as i'm building one also.
What motor & prop choice will you be using?
I have grabed one of those Tower Pro Combo's "2409-18" from Hobby City with a 9 x 4.7 or 9 x 3.8 prop that came with it.
NOZ69R is offline
Old 07-21-2008, 06:07 PM
TylerJCooper
NOZ,
I haven't figured out power systems yet. Hopefully, someone with a little more experience will be able to help you out. Until then, here is a great link to teach you the technical aspects of electronics.
http://www.wattflyer.com/forums/showthread.php?t=24238
Old 07-22-2008, 08:10 AM
NOZ69R
Originally Posted by TylerJCooper View Post
NOZ,
Thanks for the link, I printed off all the info & made it into a ready reference book.
Here's a couple of pic's of mine so far, just started to fit the electronics
ID:	73436   Click image for larger version
NOZ69R is offline
Old 07-22-2008, 04:54 PM
TylerJCooper
NOZ, nice Nasty! It is nice to see one put together. I also really like the colors. What did you use? Lastly, don't forget to get a pic of vid of her maiden flight. :-)
Old 07-23-2008, 07:31 AM
NOZ69R
Thanks again,
First I used acrylic enamel undercoat then acrylic craft paint I stole from the missus.
I did the yellow as it's dark grey Depron & I like the ME-109, I also only painted the top for visiblity & orientation reasons so it would give an idea on which way its flying.
NOZ69R is offline
Old 07-24-2008, 04:54 AM
jps42
hey good job i am building a nasty printed plans tonight
jps42 is offline
Old 07-24-2008, 03:42 PM
TylerJCooper
jps42, feel free to join us. I have been really enjoying seeing all the different ways a Nasty can come together.
Old 07-24-2008, 07:07 PM
jps42
well i dont think i wil be building one this week but any tips would help
jps42 is offline
Old 07-27-2008, 12:40 AM
NOZ69R
Well I've just come back from the field after putting my Nasty up for it's maiden flight.
I got one of the more experinced pilots to do the honor's to trim it out first. It flew beautiful with only very minor trimming needed & he commented on how well it flies.
I then put it up and being my first aileron plane I was a bit nervous but it I did alright and had two more successful flights before the wind came.
I have the D/R's set low 40-50% just until I get used to it. Although it flys great on 100% too.
So I can recommend the Nasty.
NOZ69R is offline
Old 07-27-2008, 01:27 AM
smokejohnson
smokejohnson's Avatar
Congrats NOZ
smokejohnson is offline
Old 07-27-2008, 02:19 AM
NOZ69R
Originally Posted by smokejohnson View Post
Congrats NOZ
Thanks,
I guess practice makes perfect, so its more for me.
Previous plane was just rudder & elevator, my aim is to get a Corsair so I thought I'd cut my teeth on a cheap to build depron plane first before stepping up.
NOZ69R is offline
Old 07-28-2008, 03:50 PM
TylerJCooper
NOZ nice work. I finally was able to get my carbon rods. Last night I cut a slot and inserted them. I am currently putting a band of tape around the edges of the plane to give it additional strength. I should have some pictures up later today.
Old 07-29-2008, 04:27 AM
TylerJCooper
Here are a few pictures of the recent improvements. I have inserted the rods, close to finishing taping the ends, and look forward to putting the wings/elevator to the fuselage. I am already anticipating problems mounting the engine and still trying to save for a TX. It might not get up this summer, but it sure is a lot of fun to put together.
For the other NASTY builders... Please get some flight pics. I want to see what I am working for.
ID:	73944   Click image for larger version
ID:	73945   Click image for larger version
ID:	73946   Click image for larger version
ID:	73947   Click image for larger version
Quick Reply: A Scratch Builder (Trying to do the "Nasty")
Page generated in 0.11249 seconds with 54 queries
