Scorpion Motor Q&A - Show us your Scorpion! - Page 5 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-29-2008, 07:26 PM
  #101
Gohmer
Banned
Smile
Originally Posted by Foamiesrfun View Post
all you needed was a longer shaft from a driffrent motor and replace the shaft, 5 minute job.. But glad you got something that would work.
maybe the 22 series is driffrent from the 30's and cant be replaced as simple i do not own a 20 series yet.
Sounds like all they want to do is sell those cheap chinese motors. Don't care if they fit your application or not.
Gohmer is offline
Old 01-31-2008, 08:17 PM
  #102
quilly101
Default My Scorpion Squadron
All of my aircraft are flown on cheap 3 cell lipos, Sorry I have no pics of my aircraft, but i'll provide links of what I have and what I'm using, Hope this helps.......
http://www.telink.cz/en/katalog/su29.htm on Scorpion 2208-30 with a gws 9x5 prop, 7 mins on 850mah 20c, unlimited vertical
http://www.e-fliterc.com/Products/De...ProdID=EFL2175 Exactly same set up as SU29, above, with not as much vertical
http://www.freeair.cz/ENGLISH/Blast-AJ.html on Scorpion 2215-18 with a gws 10x6 prop, 10 mins on 1300mah 20c, unlimited vertical
http://www.allerc.com/Snip-JP.htm Exactly same set up and performance as Blast, above
http://robotbirds.com/catalog/produc...oducts_id=1825 (Multiplex Gemini) on Scorpion 3008-28 with APC 11x5.5E, 10 mins on 1800mah 20c, unlimited vertical, (had to re-drill motor mount or you can order the one that fits the acromaster as that is a straight fit!) I LOVE THIS PLANE WITH THIS SET UP!!!!
http://robotbirds.com/catalog/produc...oducts_id=2015 (Multiplex Acromaster) on Scorpion 3014-18 with APC 12x6, 10 mins on 2200mah 20c, unlimited vertical.
Any questions, feel free to ask!
quilly101 is offline
Old 01-31-2008, 09:31 PM
  #103
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Wow -- 10 minutes of flight time seems to be your standard... :o
Old 01-31-2008, 09:50 PM
  #104
quilly101
Obviously not flat out. I get 10 minutes with general flying, if i really start bending sticks it'll usually drops to about 8, but even thats enough for me. All of my batteries are real budget jobs, but I do charge them using a balancer, and I only ever half charge the battery after use, then fully charge a day before flying.
Old 01-31-2008, 10:38 PM
  #105
Lieutenant Loughead
UNCLUB OWNER
How fast do your airplanes fly?
Old 02-01-2008, 05:22 AM
  #106
quilly101
None of them fly particularly fast, the gemini maybe when its downwind, they all just pull really well, so when I say vertical, its not like a rocket, just a steady pull that keeps on going.
Old 02-10-2008, 05:16 AM
  #107
mike early
Maybe you scorpion guys can help:
I have the Scorpion 35 ESC and 3008-32 motor. Using DX7 and 6100rx. If I give it throttle too quickly, it will energize to only about 50% power. If I give it throttle slowly, it'll go 100%.
What is the cause of this?
mike early is offline
Old 02-10-2008, 07:38 AM
  #108
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Mike,
There could be a couple reasons this is happening. Two important additional details we need are what prop size are you running and what specific battery are you using. First I would try another battery, if you have one, to see if this changes anything. If you have a battery that can't really deliver enough continous power for the motor it may make the voltage sag down quite a bit especially when you move the throttle quickly. This short burst of power and low voltage could make the ESC believe it's time for the power cut off. By default the Scorpion ESC is set to 50% reduction in power when it hits the power cut-off, thus you suddenly get 50% power.
If another battery does not remmedy this problem, perhaps you can fix it by programming the ESC for a lower cut-off voltage. The default for this is 3.0v so you could safely try 2.9v instead by setting switch 7 and 8 to "off" on the programming card.
A prop that is too big for this motor could also cause the motor to pull over 35A and cause this, but this is not the issue as long as you are running a prop 12x8 or lower.
If that doesn't help you may need to calibrate the throttle on the ESC if you have not done this already. This is very commonly needed by DX7 owners flying electrics. Here are some instructions for doing this....
Before doing this you should make sure your throttle on your DX7 is set to 100% throw as this is sometimes set higher, like 125%. To calibrate the ESC throttle endpoints, first remove the prop from the motor for safety reasons. Next, turn on your tramsmitter with the throttle stick in the full throttle position, and then plug in your battery. The ESC will emit a "Beep-Beep" tone. After you hear the tone, move the throttle stick to the idle position. A couple seconds later you will here the "Beep-Beep" tone again, followed by a "Dee-Doo" tone. Once this happens, the endpoints are calibrated. Now you can unplug the battery, reinstall the prop, and try the throttle again.
Please come back and let us know what you find out. It may help someone else with the same problem in the future.
Ramovan is offline
Old 02-10-2008, 07:53 AM
  #109
mike early
3S lipo. Six different batteries from 1800 to 2400 (15c)
I tried 4 batteries and they all behaved the same. I set the throttle endpoints as well. No effect.
It doesn't have enough time to see how many amps will be pulled, it just goes straight to part throttle. All batteries allowed me to increase throttle a bit more slowly and would happily fly the Align Spitfire straight up with Master Airscrew Electric wood prop 10x8.
I am thinking it's something else. Either the transmitter or the ESC.
I will hook the programming card up and take a look at what I might change.
Old 02-10-2008, 08:05 AM
  #110
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Mike,
Programming the ESC settings is a very good idea. I'm wondering if the "motor acceleration time" setting would have an effect of this issue. Perhaps setting it higher would have an effect on this problem.
Ramovan is offline
Old 02-10-2008, 09:32 PM
  #111
mike early
There are many many settings on the programming card. Impressive if I thought they all could be useful. Very probably they are.
Anyways, I changed one option at a time including:
Motor Acceleration Time
Power Cutoff Type
Current Overload Protection
Battery Low-Voltage Cutoff
Motor Braking Type
Maybe some others too.
None of these variables had any effect on my fast-throttle-up = low power output.
The one that fixed it appears to be:
changing the Cell Count Detection (Default = Auto) to 3-Cell Li-Po.
I have no idea why this would impact anything at all. I was ready to give up and presume it was the DX7 or 6100rx when I changed this setting, but now it powers to 100% regardless of how fast I give it full throttle.
Old 02-10-2008, 09:33 PM
  #112
mike early
As far as I can tell, this page is the only place on the world wide web that asks or tries to answer this issue. I wonder if it's only happened to me.
Old 02-11-2008, 12:01 AM
  #113
CygnusX1
CygnusX1's Avatar
I also run the same ESC but have not had any issues. I also use the same motor. I will double check these things as I haven't maidened it yet.
How hot does the ESC get? Mine seems to get very hot within one minute of hooking up the battery. It gets hot even if I am not running the motor. I'm not sure I need to worry about it or not.
CygnusX1 is offline
Old 02-11-2008, 12:09 AM
  #114
mike early
strange. do you have any servo chatter or binding? Are the throttle endpoints set?
I've noticed mine has warmed when working on the retract servo, but it was chattering half the time (reason why I was working on them...fixed now). I was also experimenting with half-throttle "glitch".
The one time I flew it I lost track of time and ran the battery down to 8% before I finally flair-stalled on landing. The battery and the esc and motor were just somewhat warm. That's without much airflow at all.
Old 02-11-2008, 12:59 AM
  #115
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Mike,
I closely watch a much larger Scorpion Q&A thread on another forum where thousands of questions have been asked, and I have never seen this issue before, so it is not something common by any means.
Glad you figured it out. Perhaps the ESC wasn't detecting the battery chemistry correctly and that caused it to have a lower-than-normal range of voltage to the motor. I have many Scorpion ESCs and I usually program them to turn off the brake and I set the battery type to a 3-cell lipo while I'm at it. I think this is a better setting than letting the ESC auto-detect each time it boots up. Just in case a partially discharged battery makes the ESC believe it has a NiMh or a 2-cell lipo. The battery type is determined strictly by the voltage it expects a certain type of battery to be.
Ramovan is offline
Old 02-11-2008, 01:00 AM
  #116
Ramovan
RC Dude Hobbies
Ramovan's Avatar
What battery are you using on your Scorpion ESC?
Ramovan is offline
Old 02-11-2008, 01:14 AM
  #117
worldraft
worldraft's Avatar
What is the other thread / Q. & A. that U follow Randy
worldraft is offline
Old 02-11-2008, 03:06 AM
  #118
Ramovan
RC Dude Hobbies
Ramovan's Avatar
The Scorpion Q&A thread on RC Groups. There are over 1500 posts now.
http://www.rcgroups.com/forums/showthread.php?t=660918
Ramovan is offline
Old 02-11-2008, 03:50 AM
  #119
worldraft
worldraft's Avatar
Thanks Randy I'll going to need somthing soon so I'll chech this out
Old 02-11-2008, 07:59 AM
  #120
jarosujo
Hi Ramovan,
what Scorpion motor and ESC would you recommend for Multiplex Acromaster with 3s A123. All up weight will be about 1100g (35-40 oz). I can't decide- 3008-28 (400W) or 3014-16 (600W). I want unlimited 3D.
Thanx
jarosujo is offline
Old 02-11-2008, 08:29 PM
  #121
Ramovan
RC Dude Hobbies
Ramovan's Avatar
Originally Posted by jarosujo View Post
Hi Ramovan,
Thanx
Jarosujo,
Between those two motors you would definitely want the 3014-16 if you want some vertical performance. The 3014-16 with an APC 12x6E prop on a 3-cell A123 would put out about 54oz of thrust and pull a max of about 36 amps. That would give you around a 1.5:1 power ratio if your Acromaster comes in on the light side at 35oz, and 1.3:1 if your AUW comes in at 40oz.
This setup would perform much better on a 4-cell A123 pack. The additional voltage makes the thrust jump to 80oz with a max current of 50A which would be a 2:1 power ratio, even if your AUW comes in on the heavy side at 40oz. If you already have the 3-cell A123 and don't want to buy another battery right now you could run this setup with a 3-cell and see how it performs for you. If you decided you need more power you could later step up to a 4-cell pack. For this reason I would choose a 55A ESC to ensure you have that future flexibility. The 55A ESC would also run cooler on your 3-cell setup since you would not be pushing it to the max (which is never a good idea).
Ramovan is offline
Old 02-12-2008, 11:19 AM
  #122
jarosujo
Thanx a lot,
I have two 3s A123 packs already for my heli, that's why I want to use them.
Later when I need more power, I will go for 4s setup. I just hope Scorpion ESC works with A123 (NiCd voltage protection and timing flights).
jarosujo is offline
Old 02-18-2008, 03:46 AM
  #123
c_russell
Default Interstate Cadet
I have a Interstate Cadet, WT without Motor or Battery is 2.5 lbs. the battery is a 4 cell Lipo 3100 mah. I have been flying with an Astro 015 brush motor drawing 22 amps at WOT and cruise a half easily. I have been using a 12 X 6 E prop. This configuration is around 300-350 watts.
I want to replace it with a Scorpion Motor. I have two smaller on which have served me well. I was looking at the 3008-32. Any other suggestion.
Russell
c_russell is offline
Old 02-27-2008, 12:11 AM
  #124
Liquidity
Combat Vet
Liquidity's Avatar
Randy, there are a whole lot of people that picked a the Extreme Flight Yak54E during the last couple of days. Many people have not settled on a power system and are looking for a good setup at a great price.
Take a peak over at this thread. You might be able to get a lot of people into Scorpion motors.
http://www.rcgroups.com/forums/showt...12#post9237226
Liquidity is offline
Old 02-27-2008, 12:26 AM
  #125
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Yeah, I may have ordered one (or two) of the Yaks this morning while on the road to Nevada. I haven't checked on what Scorpion motor I may need but I do have a Scorpion 3014-16 NIB at home. If that won't work then it'll get a Scorpion of some sort. Gotta LOVE these motors and ESC's!! It's the only brand I buy anymore.
Joe
Turbojoe is offline
Quick Reply: Scorpion Motor Q&A - Show us your Scorpion!
Page generated in 0.10261 seconds with 10 queries
