Show us your.................scratchbuilts - Page 7 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-01-2007, 04:28 AM
  #151
Originally Posted by Crashalott View Post
Thanks TV for the compliments on the plane.
I now have a new Mustang complete and ready for a maiden flight as soon as the weather is right.
This was done from a Gene Bond plan which i modified a little bit.
The paint scheme is from a picture i saw on the net called Voodod Mustang.
Thats is really a very nice looking airplane, Nice job Crashalott, Keep up the great work, Chellie
Old 11-01-2007, 05:43 AM
  #152
LtDan
Here is my "Funder & Lightning" plans were from a guy on RC Groups, made of Cell 88, GBx double, 9-7 prop, 1320 mah 11.1vdc, hitec Rx, 2 futaba wing servos and HS 55 for elevator.
ID:	45984   Click image for larger version
ID:	45985   Click image for larger version
ID:	45986   Click image for larger version
ID:	45987   Click image for larger version
LtDan is offline
Old 11-01-2007, 05:49 AM
  #153
Nice plane LtDan looks like its a nice flyer, Take care & Have fun, Chellie
Old 11-01-2007, 12:55 PM
  #154
Crashalott
Crashalott's Avatar
Thanks for the good words there Chellie
Have a nice day.
Crashalott is offline
Old 11-04-2007, 03:23 PM
  #155
lmopar69
Gravity Stinks!!
lmopar69's Avatar
Here is the latest and greatest pictures of the SRT/10 courtesy of my wifey. We should get to do the maiden Friday or so if all goes right.
Laine.
Name:	Me and SRT.JPG
ID:	46092   Click image for larger version
Name:	Me and SRT2.JPG
lmopar69 is offline
Old 11-04-2007, 05:14 PM
  #156
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Laine,
Wheres the midget supposed to sit? LOL
Water Boy is offline
Old 11-04-2007, 05:41 PM
  #157
lmopar69
Gravity Stinks!!
lmopar69's Avatar
Who needs a midget... I thought you were tagging along for the maiden flight? We could put some velcro on your ass and you should be good to go! Watch out for those low, high speed, inverted passes I like to do though!
Laine.
lmopar69 is offline
Old 11-04-2007, 06:56 PM
  #158
Laine.
Old 11-04-2007, 07:07 PM
  #159
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Laine.
Hell Yeah! Strap me in. My life insurance is all paid up. Just keep the spins to a min. I don't like getting dizzy.
Old 11-04-2007, 07:34 PM
  #160
flyranger
I Crash Things!!
flyranger's Avatar
Originally Posted by flyranger View Post
Thanks, C h e l l i e, for the kind words. I am trying to get away from the square sided fuses I have been making. I am developing a system for building rounded fuselages by using a 5/16in dowel as a removable "crutch" and 1/2 Elmers Foamboard to make the formers. Then I bend the 3mm Elmers foamboard around a 1 1/4 in pvc pipe to give it a shape of a "U" and use it to "skin" the formers. Here's some pics of the progress. The stiffeners are 100 for one dollar bamboo skewers. I create the former images using a graphics editor (Paint Shop Pro) then stick them to the foamboard with a glue stick. The former is cut out with a razor blade, the center hole is punched and the marks are transferred to the edges using a pen. Paper is then removed from front and back of the cut out former.
Plane is complete and test flights are done. Trim required just a little down elevator. Used a feebay chinese motor, 9x7.5 prop and this sweetie "gets little" real quick! AUW is 16oz with the commonsense 3s 1650ma lipo. Haven't decorated yet, but looking at calling it "Rocket 88"
Name:	joy 5 027.jpg
ID:	46108   Click image for larger version
Name:	joy 5 028.jpg
ID:	46109   Click image for larger version
Name:	joy 5 029.jpg
ID:	46110   Click image for larger version
flyranger is offline
Old 11-04-2007, 09:07 PM
  #161
Sweet Little Plane flyranger reminds me of the GLH, Goes Like Hell, plane from yester years, Take care, Chellie
http://my.pclink.com/~dfritzke/glh.pdf
Old 11-05-2007, 12:34 PM
  #162
flyranger
I Crash Things!!
flyranger's Avatar
I had forgotten about this plane! I really like the look of the "raked back" tail feathers. Thanks C H E L L I E!
Old 11-11-2007, 03:04 AM
  #163
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
Well if u haven't seen it at other posts heres my scratch built Spirit B 2 slope soarer. It's my 4th prototype of a model B 2 if u count the non-flying plastic testors model i built for scale references.Anyway it has yet to be thrown off a hill i only have to balance proper C G (33% of main rib cord i'm thinking) and it will be go for glide testing.Should it be controllable with out winglets or split rudderons for yaw controll I'll consider powering it up.It's made of 4 layers of polystyrene insulation foam laminated with elmers wood glue with a 1/8 th inch plywood (with lightening holes )main and outer ribs hot wire cutting templates.The upper airfoil i shaped by what looked good to me.The under side of the main body is shaped as a keel that follows the shape of the full sized acrft.It has the bird beak like leading edge.The outer wing panels are dow blucor 1 1/2 inch hot wired to the rib and tip ply.they are removable. THe outer panels are reinforced with nylon drywall tape and diluted white glue.This is a very light and strong method of reinforcing by the way .Cheap too.The model spans 92 " and the main rib cord is 36".The outer panels have a 9 " cord. The plane weighs 4 lbs 3 ozs. but if i have to add 5 ozs of nose weight it will come in at around 7 ozs. per sq. ft. wing loading.It has 2 hitec HS 81 servos operating the elevons which are located on the main body as in the full scale acrft.Its fuse is 1/2 " polystyrene hot gluded around bulkhead formers.The cockpit and engine nachells are shaped from some kinda light soft foam like florists would use i got dumpster diving for foam scraps.It's painted with rustoleum dark grey latex , the trim on the leading edge is radar absorbing black electrical tape.The foam was sealed with diluted white glue.I have about 20 hours work in it and only about 20 $ cost.Looks cool huh.
Name:	spirit b 2.jpg
ID:	46583   Click image for larger version
Name:	spirit b 2 002.jpg
ID:	46584   Click image for larger version
Name:	spirit b 2 003.jpg
Alpea42 is offline
Old 11-11-2007, 05:03 AM
  #164
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Thats awesome!
Larry
Larry3215 is offline
Old 11-11-2007, 07:08 AM
  #165
That Look great, and only 4 lbs, Ok lets power it up 3520-7 Towerpro motor,
3520-7 Towerpro motor 25.00
https://www.unitedhobbies.com/UNITED...?idProduct=666
50 amp ESC 18.95
4 cell lipo 4100mah 74.10
https://www.unitedhobbies.com/UNITED...idProduct=4129
Ubec 4 amp 11.25
https://www.unitedhobbies.com/UNITED...idProduct=2160
Total $129.30 for 500 to 600 Watts with a 4 cell lipo
Model: TowerPro 3520-7
Size: 45.5diam x 72mm
Weight: 262g
Voltage: 10v
Idle Current: 1.6A
Suggested Battery Config: 4-5Lipo
Kv: 600RPM/v
Shaft: 5mm
Max Eff Current: 45A
Max current: 56A
Max Power: 850W
Suggested prop: 13*8, 14*7 APC-E (thin electric)
Suggested BESC: 60A
Suggested Battery Range: 2200mah 4S1P ~ 4000 5S1P
Test Data ResultsKv = 660 rpm/V
Rm = 0.074 ohms
Io = 1.9A @5V, 2.4A @12V, 2.7A @15V
Recommended props:
13x6.5 APC-E (4 cells: 35A, 500W, 2200g, 49mph, 7900rpm)
12x10 APC-E (4 cells: 42A, 600W, 1600g, 71mph, 7400rpm)
14x7 APC-E (4 cells: 42A, 600W, 2700g, 49mph, 7400rpm)
12x8 APC-E (4 cells: 33A, 480W, 2000g, 60mph, 8000rpm)
13x8 APC-E (4 cells: 40A, 570W, 2300g
Old 11-11-2007, 07:15 AM
  #166
Airhead
Redneck Member
Airhead's Avatar
Hey Alpea,
Your B2 looks pretty sweet.. Now, get out of that swimming pool before your wife catchs you...
Airhead is offline
Old 11-11-2007, 07:20 AM
  #167
Airhead
Redneck Member
Airhead's Avatar
Laine.
Whoa.....Laine, that is big!!....
Airhead is offline
Old 11-12-2007, 12:25 PM
  #168
Crashalott
Crashalott's Avatar
Hey there Alpea,
Good luck with the maiden!
Old 11-12-2007, 04:11 PM
  #169
Alpea42
Alpea42's Avatar
thanks crash I added 6 ozs nose weight which only moved C G 3 inches forward its now 41% of cord but the leading edge angle is very sharp at about 115 degrees so there is a lotta lifting surface behind C G maybe 80 % or more.So in my mind i see all that air pressure compensating for a rear ward C G.LOL.I'm laughing at my non technical engineering i feel like the german model designer in the movie Flight Of the Pheonix.Wheres my slide ruler.One of my all time favorite movies .Anyway i fixed a angle of attack prob. with the left outer wing panel .it had a few degrees more angle of attack than the right .enough to see by eye. So i filled and redrilled the trailing positioning dowel hole.Its veterans day, the sun is shining ,my son ,the assistant launcher is off school .we are go for test flight #1 I'll post the debriefing later T C Al
Alpea42 is offline
Old 11-12-2007, 10:48 PM
  #170
Alpea42
Alpea42's Avatar
this thing will fly and it did .1st tried pulling it with a kite string at a run no go .8 or 9 mph not enough air speed. it did break ground surface tension once when i yanked the string felt less drag.So we climbed 20 yards up a 45 degree slope put a little up trim on elevator and i launched it 15 yards into some bushes.Everything looked good.Next had my son try to launch .Thunk into the dirt he cant throw it at flying speed.Ok a little more up elevator trim hand him the tx .5 more yards up the hill take out a d sized battery in the nose.I decide to throw at the bushes again with umph.3 running steps 15 degree attitude above the horizon ungawawh heave.off it climbs for 15 yards ,air speed bleeding off rapidly over the bushes and starts dropping nose down level wing., i yell up elevator to my son but with lack of air speed all the elevator in the world wont level it out.thunk it hits the park turf 50 yards out in front of us at a -45 degree angle of atttack basicly unhurt small crack in wing rib glue joint no prob.My son and I look at each other knowing i cant throw 5 lbs 50 yards and yell IT FLIES . I think the Wrights only made 100 ft. their 1st effort .lol.Anyway stay tuned more to come
Alpea42 is offline
Old 11-12-2007, 11:07 PM
  #171
Alpea42
Alpea42's Avatar
Oh i forgot to mention the stunt pilot of the plane that was built for the movie Flight Of The Pheonix was killed during the filming when the plane crashed.T C Al
Alpea42 is offline
Old 11-14-2007, 07:39 AM
  #172
lrplin
50 amp ESC 18.95
Ubec 4 amp 11.25
Weight: 262g
Voltage: 10v
Idle Current: 1.6A
Kv: 600RPM/v
Shaft: 5mm
Max current: 56A
Max Power: 850W
Suggested BESC: 60A
Rm = 0.074 ohms
Recommended props:
Can anyone go to hobbycity.com? everyone i went there, it always said : hobbycity.com/unitedhobbies.com is now restricting its customer locations due to a spate of copyright infringements from other vendors.
If you are a legitimate shopper, please fill in the form below and we will grant you access;
If you feel you have been redirected here in error, please email: [email protected]
lrplin is offline
Old 11-14-2007, 11:10 AM
  #173
FlyingMonkey
Flite Test Fan
FlyingMonkey's Avatar
no problem here, but I am already registered with them.
FlyingMonkey is offline
Old 11-14-2007, 07:11 PM
  #174
Larry3215
Larry3215's Avatar
Good grief!
They are making it sound like other vendors are steeling thier copyrights!!!
What a joke!
They are the ones doing all the copyright infringement!
Typical tactics for them and many other oriental vendors - steel everything you can and forget ethics.
Larry
Old 11-14-2007, 11:13 PM
  #175
fr4nk1yn
^_^
fr4nk1yn's Avatar
Not to go off topic but... How exactly is HobbyCity infringing on anybodys copyrights?
While there are Chinese companies that do I'm not sure how THEY do it.
What is interesting about them is how they sell inexpensive motors that look, and have stickers, just like some other companies sell but they always seem to claim "it's the same series but custom wound for us" (:
Sorry but it chaps my nads that these motors are sold for sometimes twice as much money THEN people bash the ones sold by UH.
fr4nk1yn is offline
Quick Reply: Show us your.................scratchbuilts
Page generated in 0.10488 seconds with 25 queries
