question re:Hobbico Quick Field DC Charger MKII - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-06-2005, 01:45 AM
rmbler
Default question re:Hobbico Quick Field DC Charger MKII
i just purchased the above charger and upgraded my e-flight blade heli with the upgrade kit as well as the e-flight 800mAh battery my understanding is that the li-ion and li-po batt. settings are the same just want to make sure its set right so i don't blow up my batt. pack can anyone tell me what and how i should set the charger as far as amps. setting and time ect. also i will be running it through a jump starter car starter batt. with a 12 volt accessory cigarette lighter type input.
thanks in advance
Phil
rmbler is offline
Old 10-07-2005, 04:42 AM
Matt Kirsch
Matt Kirsch's Avatar
The instructions that come with your LiPoly pack should describe the acceptable charge rate. With the exception of the SkyVolt and BalancePro packs from FMA Direct, the univerasal maximum (NOT to be exceeded) charge rate for all LiPoly packs is 1C, or one times the Capacity of the pack.
In your case, 800mA, or .8 Amps is the acceptable charge rate.
I believe this charger has an automatic shutoff when the pack is charged. You should not need to set any timer. It will take about 1-1/2 hours to charge a fully depleted pack.
Matt Kirsch is offline
Old 10-07-2005, 05:49 PM
rmbler
Thanks for the reply Matt i am really new to this hobby and cant afford to spend good money on battries that i blow up i spend enough on crashes thank you again.
Regards,
Phil.
rmbler is offline
Dan Matheson
01-20-2008 06:44 PM
raceredg
11-05-2006 07:16 PM
usedhippo
06-21-2006 03:29 PM
meegosh
23
01-03-2006 03:28 PM
Blaze.45
12-20-2005 02:37 AM
Quick Reply: question re:Hobbico Quick Field DC Charger MKII
Page generated in 0.07537 seconds with 13 queries
