WWI planes - Page 175 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
WWI planes
Old 09-26-2010, 07:47 PM
  #4351
degreen60
Flying Fish
degreen60's Avatar
Originally Posted by scalercflyer View Post
I will provide pics of the build as I progress. Let me know your thoughts Guys. And NO D you can't have it unless I turn the kit into confetti! Marty
You do not need anykind of bracing on the wings. Just fly without any bracing. Do long dives and tight loops.
degreen60 is offline
Old 09-26-2010, 07:57 PM
  #4352
TM4197
Dope&Fabric
TM4197's Avatar
UNREAL!!! like a buzzard flying around in circles, waiting for the kill!
TM4197 is offline
Old 09-26-2010, 08:49 PM
  #4353
degreen60
Flying Fish
degreen60's Avatar
Okey?
Old 09-27-2010, 02:24 AM
  #4354
scalercflyer
scalercflyer's Avatar
Default The Sopwith Pup Build
OK Boys. Here are some pics. The plane went together quickly. I worked on it early this morning when the witches were sleeping! A few things were noted. The decals were and are crap! The fuse had a chunk out of it. I did try to remove the decals but I started to pull the paint off. Perhaps I would be better off just covering them or just leaving them alone. I am installing Sir Percy that I made up and painted. He came from my Comet SE5a kit. Also had to open the servo tray to install my TP 5 gram servos. Still not 100% sure on my power plant choice. Maybe i'll have you Guys help me to choose. Also note the HUGE rudder and fin. I had half a mind to cut it down but it would look out of place with that huge elevator/stab so I left it alone. After all it's not scale, just sorta. Look at the pics and see what you guys think. Long dives and large loops indeed! Next thing you'll be suggesting D are some violent spins! Marty
Name:	sopwith pup 001.jpg
ID:	136145   Click image for larger version
Name:	sopwith pup 002.jpg
ID:	136146   Click image for larger version
Name:	sopwith pup 003.jpg
ID:	136147   Click image for larger version
Name:	sopwith pup 004.jpg
ID:	136148   Click image for larger version
Name:	sopwith pup 005.jpg
Name:	sopwith pup 006.jpg
ID:	136150   Click image for larger version
Name:	sopwith pup 007.jpg
ID:	136151   Click image for larger version
Name:	sopwith pup 008.jpg
ID:	136152   Click image for larger version
Name:	sopwith pup 009.jpg
ID:	136153   Click image for larger version
Name:	sopwith pup 010.jpg
scalercflyer is offline
Old 09-27-2010, 02:44 AM
  #4355
degreen60
Flying Fish
degreen60's Avatar
Do as I did. Take the decals off. Go to Walmart and buy some acrylic paint. One bottle of a green you like for top and sides of plane. A bottle of linen for the bottom. If you have a color printer get some white sticker paper and make your own decals. Laser is best cause it is water proof.
I don't want to waste violent spins on a Pup. I need the violent spins made by a Bristal Scout(I don't have one of those yet). Wait a second, now let me look, what can I change a Pup into. LOL
If you really want to make the Pup differant, there was a Pup in one of the training schools that was black and white stripped.
Old 09-27-2010, 02:50 AM
  #4356
degreen60
Flying Fish
degreen60's Avatar
I am going to have to look for that Sir Percy. I take the pilots I get with models that are in 2 pieces, fill them with epoxy and use them as masters for my Vac-u-form to make more pilots.
Old 09-27-2010, 09:58 AM
  #4357
scalercflyer
Default Decal removal
D what is the best way to remove the decals? I was thinking GOO GONE but I'm not sure if it will attack the foam. Maybe I should try it on a piece of scrap from my TM. It's the same foam with paint on it. Marty
Old 09-27-2010, 10:02 AM
  #4358
scalercflyer
Here's the one I was thinking of D. It's the captured Pup on the right of the screen. Marty
http://www.wingnutwings.com/ww/A3932...B6507D64DC8FEC#
Old 09-27-2010, 12:19 PM
  #4359
degreen60
Flying Fish
degreen60's Avatar
I just peal the stickers off taking the paint with them. I do not care what it looks like where the sticker was cause I put a new sticker over the spot after I repaint the plane. Some planes have a smooth finish on the surface of the foam. If that surface is missing in spots I just paint over it. You can tell where the damage was but does not look that bad. Just call it battle damage fixed in the field.
Old 09-27-2010, 01:21 PM
  #4360
scalercflyer
Sounds like a good way to make pilots D. Did you make your own vacuum tool or have a real Vac-u-form? What do you use for plastic? An old coke bottle perhaps? Maybe you can show us a sample. Thanks, Marty
Old 09-27-2010, 02:44 PM
  #4361
degreen60
Flying Fish
degreen60's Avatar
I picked up an old Mattel Vac-u-form in a junk shop for about $5. I buy precut but not drilled sheets for around $10 for 50. I do not think these sheets make as clean a copy as the original sheets but are a lot cheaper. After painting they look good enough for me. I always give the pilots a final wash of thined black paint. Kind of hides flaws and makes them look dirty. The pictures of my Pup has one of my larger pilots in it, came with a Kaven Albatros. My next picture of the Breguet 14 will show 2 people made with my small pilot master. I think I got it long ago in a Sterling kit.
Old 09-27-2010, 06:04 PM
  #4362
scalercflyer
Default GP tech support
Just got off the phone with their tech support guy Mark. All I have to say is WOW! He listened to my problem, told me he was glad I called and expressed his concern. I told him about the problem with the decals and he is sending me a new wing. I also sent an email to their tech support line and am awaiting a response. Great Job Mark! Thanks! Marty
Old 09-27-2010, 06:54 PM
  #4363
degreen60
Flying Fish
degreen60's Avatar
Here are some of the pilots I made.
ID:	136170   Click image for larger version
ID:	136171   Click image for larger version
ID:	136172   Click image for larger version
ID:	136173   Click image for larger version
ID:	136175   Click image for larger version
ID:	136176   Click image for larger version
ID:	136177   Click image for larger version
ID:	136178   Click image for larger version
Old 09-28-2010, 01:35 AM
  #4364
TM4197
Dope&Fabric
TM4197's Avatar
Scalercflyer: If you have a Michelle's craft store, they sell florest paint that will not damage the foam. I used forest green and brown on this tiger moth..the foam was white, I shot very light coats of green then filled in with brown. Just the Green would look good on your Pup. It ages the look of the body as well. Used the green "heavy spray" on the Scout wings. I thought I heard Degreen60 sticking a pin in his airplane voodoo doll again...this time it was a Bristol Scout. I'am not flying mine for weeks now!!!!!
ID:	136215   Click image for larger version
TM4197 is offline
Old 09-28-2010, 02:25 AM
  #4365
scalercflyer
Default In the hands of the Germans
Well I tried converting the Pup to a captured plane. Not completely satisfied with it though. I think I'll paint her (per all of your suggestions) Since I think it would look better. I'm entertaining painting the crosses on it too instead of printed paper attached with white glue. It doesn't seem to stick well anyway but I wanted you Guys to get the idea. What do you think? Kinda different HUH? marty
Name:	Sopwith Pup 2 001.jpg
ID:	136221   Click image for larger version
Name:	Sopwith Pup 2 002.jpg
ID:	136222   Click image for larger version
Name:	Sopwith Pup 2 003.jpg
Old 09-28-2010, 03:50 AM
  #4366
degreen60
Flying Fish
degreen60's Avatar
I use Elmer's Washable School Glue Stick to attach printed paper. Were it comes loose I just run the stick around the edges again. It will finally stick tight enough not to come loose.
Old 09-29-2010, 12:57 AM
  #4367
enemyace19
Beware the hun in the sun
enemyace19's Avatar
Looks good to me
enemyace19 is offline
Old 09-29-2010, 01:20 AM
  #4368
TM4197
Dope&Fabric
TM4197's Avatar
I like it.....paint the wheel covers half black, half white!
TM4197 is offline
Old 09-29-2010, 01:40 AM
  #4369
scalercflyer
Thanks Boys! I am continuing with the build. On the wheels I was thinking of putting some small crosses. More to come. Marty
Old 09-29-2010, 03:18 AM
  #4370
degreen60
Flying Fish
degreen60's Avatar
Looks good, now my Pup pilot needs to get those black crosses in his cross hairs.
Old 09-29-2010, 03:19 AM
  #4371
degreen60
Flying Fish
degreen60's Avatar
Now we have at least 2 of the GP Pups that do not look like all the rest.
Old 09-29-2010, 03:31 AM
  #4372
scalercflyer
My combat flying skills honed in the war choked skies over South Jersey will save the day! You'll never get on my six D! Marty
Old 09-29-2010, 09:31 PM
  #4373
degreen60
Flying Fish
degreen60's Avatar
Breguet 14 is now armed. Still needs bomb racks installed. Also closeups of the aileron cables.
ID:	136304   Click image for larger version
ID:	136305   Click image for larger version
ID:	136306   Click image for larger version
ID:	136307   Click image for larger version
Old 09-29-2010, 10:05 PM
  #4374
TM4197
Dope&Fabric
TM4197's Avatar
Really nice job!! That looks great!! are the ailerons smooth? Nice job on the engine cowling too! Can;t wait to see her in the air!
TM4197 is offline
Old 09-29-2010, 10:36 PM
  #4375
degreen60
Flying Fish
degreen60's Avatar
When I first installed the ailerons I had lots of down but very little up. I could not get the top line tight enough to get the ailerons to go up. I made 2 small metal clips that go through the brace wire holes at the top of the front middle struts. I pulled the upper aileron lines tight by hooking them in the clips. Now I have lots of up too. They are very smooth but the plane will only do a slow roll. I find I only need to use the rudder if I raise the nose while flying slow.
Quick Reply: WWI planes
Page generated in 0.16335 seconds with 45 queries
