Cheetah U3520-6 motor - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-03-2019, 09:03 PM
Gordone
Default Cheetah U3520-6 motor
I'm trying to find the power specs for this motor, i.e., number of battery cells and amps or watts. I know the kV is 840. It was originally sold by BP Hobbies who stated that Cheetah motors are made by Suppo. The motor is not listed on the Suppo website.
Gordone
Gordone is offline
Old 10-04-2019, 12:18 AM
crxmanpat's Avatar
Looks like Altitude Hobbies still sells the Suppo motor. Here are the specs:
Suppo 3520/6 (42-47) 840kv Specifications:
● Number of Cells: 3-7s lipo; 8-20 cell NiMh
● Max Efficiency Current: 18-40A (>75%)
● No Load Current (10v): 2.1A
● Max Current: 50A/60s
● Max Efficiency: 82%
● Resistance: .050 ohms
● Shaft Size: 5.0mm
● Poles: 14
● Max Watts: 1295W
● Weight: 200g
● Motor Dimensions: 42x47 (mm)
● Motor bolt pattern (back of motor): 22mm x 22mm (hole to hole)
● X-mount hole pattern: 54mm x 54mm (hole to hole)
● Minimum recommended ESC: 50A*
● Recommended Model Weight: 1800-3000g (64-107 oz.)
crxmanpat is offline
Old 10-04-2019, 04:13 AM
Originally Posted by Gordone View Post
I'm trying to find the power specs for this motor, i.e., number of battery cells ...
Any voltage, as long as current and rpm don't get too high. Wire insulationlacquer can handle several hunderd volt.
Old 10-04-2019, 09:57 AM
Gordone
Wow, thanks for the quick and thorough response!
Gordone is offline
05-28-2020 09:50 PM
admin
05-07-2020 05:04 PM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
02-16-2016 12:19 AM
Quick Reply: Cheetah U3520-6 motor
Page generated in 0.05460 seconds with 13 queries
