Old 12-01-2017, 03:43 PM   #1
Friends: (17)
Default This may just be the ticket ... discharger to power USB as well
https://www.ebay.co.uk/itm/Smart-Bat...wAAOSwKtlWlNDy
This little item reckons 1 - 6S discharger to 3.8V and capable to power USB items etc.
I can see many uses for this if it works .... I've ordered one ...
Old 12-04-2017, 08:06 PM   #2
Looks interesting but discharge power is quite modest. It uses a couple of 10W resistors so the absolute max it can do is 20W discharge power. On a 6S LiPo that's less than 1 amp. Is says it does up to 2A discharge but that must only be achievable on a 2S LiPo.
But fine if you are dealing with small batteries and/or have plenty of time.
Old 12-04-2017, 08:47 PM   #3
Friends: (17)
Its more for the field charging of items in my mind. The discharge rate of course is pitiful I agree.
Old 12-05-2017, 04:56 PM   #4
If you just want the USB charger functionality for your phone or camera then you could use one of the Hobbyking LiPo voltage checkers with built in USB: https://hobbyking.com/en_us/hobbykin...ker-2s-6s.html
Be warned though, I've had a couple of these and they cant cope with a 6S battery when using the USB charger. They must use a linear voltage regulator which burns out if the voltage stepdown is too high. It works fine on a 3S LiPo. The discharger device you found may get around this problem, or it may not, hard to say without doing a test and seeing if it fails or not.
Old 12-05-2017, 05:00 PM   #5
Friends: (17)
It came about because I fly DJI as well as more usual RC crap !!
I have a discharger for DJI packs that charges phones etc. while doing its job. A number of people have asked me for links to it ... and this one kept coming up.
With it also catering for normal LiPo's and so dirt cheap ... I thought why not.
I'm sure there are better and worse units out there ... with linking to them and testing - we can separate the grain from the chaff ...
May have figured out what killed my plane- DX5 power glitch CNY_Dave RC Radios, Transmitters, Receivers, Servos, gyros 18 12-05-2017 07:49 AM
Everything You Wanted To Know About Electric Powered Flight AEAJR Beginners 165 06-28-2017 05:22 PM
MeanWell Power Supply for sale on RCU The MacDaddy Batteries & Chargers 0 02-08-2017 03:15 AM
Everything You Wanted To Know About Electric Powered Flight AEAJR General Electric Discussions 273 01-09-2017 03:23 AM
Heli Terms for Beginners brnyrbbl Beginners - Helis 54 12-03-2016 12:08 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Page generated in 0.07200 seconds with 27 queries
