One transmitter for multi copters? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-12-2013, 02:31 PM
dontrinko
Default One transmitter for multi copters?
If I buy several of the same model can I use one transmitter for all of them?
Would this work with cx,cx2 and Scout?(not sure if scout is dsm) I know the scout is 3 channel but I could ignore that stick.
At present I have scout/EFLRT324, MCX2/MLP4DSM, and CX2/LP5DSM .
I also have a used 120SR coming with a tx. Thanks; Don
dontrinko is offline
Old 11-12-2013, 07:08 PM
To the best of my knowledge, you'd need all the recievers to be within the same frequency format, recognized or compatible with a matching transmitter.....like a Spektrum DSM DSMX system (or equal).
Old 11-12-2013, 08:16 PM
dontrinko
The 120sr came. it also has a MLP4DSM transmitter. I'm guessing that eventually I'll end up with a DX6I. Don
Old 11-12-2013, 09:26 PM
pmullen503
A DX6i will work with all your Spektrum compatible helis but check it's programming capabilities carefully. It might make sense to go up to a DX7, 8, or 9. I ran into the DX6i's programming limitations pretty quickly with airplanes.
Your RTF TX's do have some resale value. That will defray the cost of whatever new TX you choose somewhat.
pmullen503 is offline
Old 11-12-2013, 09:44 PM
dontrinko
Thanks; I need to educate myself on theDX6I.
Can I program in the "beginner" mode for my MCX2 and scout? (scout may not be DSM) Will the stock tx still work after I bind to the DX6I? From what I have read it will store 10 different helicopters.
Don
Old 11-12-2013, 10:40 PM
zoltron55
you can bind everything but the scout. I had a mcx, mcx2 & the 120sr bind with dx4,5 & 6. something about the scout that will not let it bind to anything but the trans that came with it
zoltron55 is offline
doctor727
05-29-2013 07:04 AM
KenK
11-21-2012 05:00 AM
NFA Fabrication
13
05-02-2012 09:22 PM
calldaffer
44
04-22-2011 12:37 AM
DanWard
12-24-2010 01:16 AM
Quick Reply: One transmitter for multi copters?
Page generated in 0.09845 seconds with 13 queries
