cowling construction - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 12-07-2008, 06:12 AM
colvid
Default cowling construction
Have several planes which have been converted to brushless and now the cowlings do not fit. How do I make new ones? Someone suggestioned 2 liter coke bottles. How about a fantastic new procedure I don't know about. Please!!!
Larry
colvid is offline
Old 12-07-2008, 07:09 AM
lmopar69
Gravity Stinks!!
lmopar69's Avatar
Well, you can vaccu-form them if you want. You will have to make a "mold" though to do that. Really not to hard to do though. I have seen a few threads here and on RC Groups that explain how to make a contraption to do it, but I have not done it yet myself.
Good luck man, hope you get it all worked out.
Laine.
lmopar69 is offline
Old 12-07-2008, 08:28 AM
Maybe this info might help, make a pattern cowel from balsa, then vacuum form, hope that helps, Chellie
[media]http://www.youtube.com/watch?v=hGBRiYhxRTM[/media]
http://www.wattflyer.com/forums/show...hlight=vaccume
http://www.instructables.com/id/Make...-plastic-vacu/
http://www.youtube.com/results?searc...rch_type=&aq=f
http://www.ffscale.co.uk/page4f.htm
http://www.cstsales.com/tutorials/fiberglass_mold.pdf
http://www.rcgroups.com/forums/attac...mentid=1379325
http://www.rcuniverse.com/forum/m_3209607/tm.htm
http://www.ffscale.co.uk/page4g.htm
Old 12-07-2008, 03:07 PM
colvid
Default Making Cowling
Wow!!!! Thank you for all of the links.
Lary
colvid is offline
Old 12-07-2008, 03:40 PM
newjak
AMA Park Pilot Partner
newjak's Avatar
Nice!! I've add those links to my collection. Thanks
newjak is offline
Old 12-07-2008, 11:58 PM
Lary
Your both very welcome, Take care and have fun, Chellie
Old 01-30-2009, 03:00 AM
Scorpion
Scorpion's Avatar
Cool Ready-made cowls from your local supermarket
Here's an idea for radial cowls, Skippy peanut butter (see photos), after you finish eating it of course ! The jars come in 2 sizes and are made of thin flexible plastic so they should handle some fairly hard hits.
Just cut a big round hole in the bottom and cut to the length you need, instant cowl. Then all you need to do is use fine sandpaper to roughen the outside surface for painting.
You could even use 2 jars, one for the cowl and another for the front part of the fuselage. Or how about cutting the top of the cover off and gluing the threads inside the cowl and putting the fuselage jar with the threads forward. You'd have a cowl that unscrews !!
Next time you go shopping, look at all the different plastic container sizes and shapes used for foodstuff, shampoos, spray and squirt bottles, etc. Even large vitamin bottles would be great for a multi-engine warbird. The choice is almost endless. Don't forget to check out the dollar stores.
Building a big radial-engine model like a Yak-54? How about a big Javex bottle.
Name:	Skippy peanut butter.jpg
ID:	92011   Click image for larger version
Name:	Skippy peanut butter jars.jpg
Scorpion is offline
Old 01-30-2009, 04:28 AM
colvid
Default Cowling
Those are some great ideas Scorpion; we recycle and have many plastic containers which could have been used.
Larry
colvid is offline
Old 01-30-2009, 04:57 AM
Bub Steve
Bub Steve's Avatar
Larry
I've been use'in Yogurt cups for years! there GREAT!!!!!!! bubsteve
ID:	92029   Click image for larger version
Name:	petty an red 221.jpg
ID:	92030   Click image for larger version
Name:	petty an red 492.jpg
ID:	92031   Click image for larger version
ID:	92032   Click image for larger version
ID:	92034   Click image for larger version
Name:	petty an red 344.jpg
ID:	92035   Click image for larger version
Name:	petty an red 760.jpg
ID:	92036   Click image for larger version
Name:	petty an red 436.jpg
ID:	92037   Click image for larger version
Name:	petty an red 765.jpg
Name:	petty an red 718.jpg
ID:	92039   Click image for larger version
Name:	petty an red 359.jpg
ID:	92040   Click image for larger version
Name:	petty an red 195.jpg
ID:	92041   Click image for larger version
Name:	petty an red 779.jpg
ID:	92042   Click image for larger version
Name:	petty an red 538.jpg
Bub Steve is offline
Old 01-30-2009, 06:43 AM
Yes those work Great, and i Love skippy Peanut butter too
Old 05-24-2010, 04:20 AM
Bill G
Super Contrubutor
Bill G's Avatar
Balsa radial cowl
ID:	128518   Click image for larger version
ID:	128519   Click image for larger version
ID:	128520   Click image for larger version
Bill G is offline
Old 05-24-2010, 06:14 AM
TLyttle
TLyttle's Avatar
Good stuff, Bill, I build my cowls the same way, except that I use 1/32 ply to wrap around the discs. Then I wrap soft balsa around that to come to the necessary thickness; lots of soaking in hot water aids the process. Just as tough as any plastic bottle IMHO, and I test my cowls often!
TLyttle is offline
Old 05-26-2010, 08:23 PM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
Default Use a 3 Liter soda bottle and heat gun.
I have posted this on a thread about the E-Flite P-47, but didn't notice this thread til today. I am posting some pictures of the final result but I can describe the process and post earlier pictures later (does that make sense?).
1. Take original cowl and dig out a hole in your sandbox (we all have one right?) and dampen the hole with water from cup or glass.
2. Insert cowl into damp hole and fill in the gaps until you have a "negative" sand mold resembling your cowl (you have carefully extracted the cowl from the sandbox by now).
3. Make 4 parts plaster of paris to 1 part water mix to pour into the sand mold.
4. Pour plaster mix into sandbox mold and let set for two hours. It will be a little damp at that point depending on relative humidity but plenty strong for a heat mold.
5. Take your 3 liter (or 2 liter bottle depending on size of your plane) and saw off the bottom of the bottle leaving the cap end in place.
6. You can make a wooden jig (see this thread by Barry [baz49exe]: http://www.wattflyer.com/forums/showthread.php?t=36104) to hold the plaster plug or just melt the overlapping bottom of the bottle over the back end of the plaster plug with your $10 heat gun (do this on LOW). Either way you will be cutting- a dremel plastic cutting wheel is ideal here. I have not used a releasing agent (e.g. vaseline, etc.), but I would recommend it if you want an intact plaster plug for re-use. I cracked mine.
7. Once you are satisfied with the results, use either your Dremel or a razor saw to remove the bottle neck (in front) and overlapping plastic in the rear of the plug to release your plaster mold.
ID:	128642   Click image for larger version
ID:	128643   Click image for larger version
ID:	128644   Click image for larger version
ID:	128645   Click image for larger version
ID:	128661   Click image for larger version
ID:	128662   Click image for larger version
ID:	128663   Click image for larger version
ID:	128664   Click image for larger version
ID:	128666   Click image for larger version
Voyager2lcats is offline
Old 10-07-2012, 10:14 AM
OzMo
OzMo's Avatar
HI,
I have had good luck making cowls, as well as repairing noses, with epoxy and
Dollar store KNEE HIGH HOSE. They come 10 for a buck and in various colors.
Rough out a cowl shape out of plain ole stirofoam, just get it fairly smooth. smear it with your favorite 15 (or slower) minute epoxy, pull one hose over apply more epoxy and pull over one or two ....about 4 will make a fairly stiff cowl, less works fine for little ones. A bit of fiber glass or Carbon fiber between hose layers could be used to stiffen up the rims on big uns. This comes out flat in finish but final coat of epoxy thinned out a bit will make it shiny. If you want it painted omit the final coat of epoxy and just smear it with spackle ,sand and paint. Hog out the foam after or disolve it out with acetone. I just hog it out and lightly sand the inside as I don't like the mess of disolving it out. Some foam can be left in intentionally for structure too.
OzMo is offline
Old 10-07-2012, 12:25 PM
That's interesting. I'll try and keep that in mind. When do you cut the openings for the motor, etc.?
Old 10-07-2012, 09:43 PM
OzMo
OzMo's Avatar
Default cutting formed cowls
Trim the piece and cut openings when the epoxy is setting up. That is when its not the least bit sticky but still flexable. Scissor will work just fine at that point. If it does get hard no problem just use you Dremmel tool and a sanding drum.
If you cowl has an irregular shape cover the wet epoxy with bits of plastic wrap (use pieces to avoid wrinkles) then cover with soft foam or rags to fill inside curvs etc.)and wrap with an ace wrap. (This step is BEFORE taking out the foam mold ) Wrap NOT TO TIGHTLY, you don't want to mishapen it. This is harder to do but leaves a glassy surface. Its a similar process to making a one off fuse.
Take a few "minutes" () to puruse hand launch glider building vids on you tube. Lots of building tricks there but the real gold mine of info is in free flight building. The light structure techniques apply well in electric plane construction. Lots of those old school planes showing up as electrics these days and I think that is really cool.
OzMo is offline
Old 07-27-2013, 04:25 AM
1geo1
George
Default LOVE IT
PLEASE make sure this thread stays up !
1geo1 is offline
Old 07-28-2013, 01:50 AM
hayofstacks
hayofstacks's Avatar
still here 5 years later....
we ve been building up a 3d printed cowling that is showing some promise.
hayofstacks is offline
Old 07-28-2013, 02:47 AM
Copy the link and place it in your bookmarks or favorites:
That way you'll always have it as a reference.........
Old 08-03-2013, 10:21 PM
RepRapper
We
RepRapper is offline
Old 08-03-2013, 10:50 PM
RepRapper
We have been working on 3D printed model airplane parts. This includes Cowls, Landing gear, Sailplane nose blocks, basically those labor intensive things that can really slow down the construction of an airplane, We have also been expirementing with parts that would really benefit by being made out of plastic. I am sure that many of you have an airplane that has some plastic damage and it is hard to find replacement parts or maybe they are in China? If any of this intrest you check these out.
Old 08-04-2013, 05:14 AM
tr4252
tr4252's Avatar
That's pretty cool. What sort of plastic are the printed parts?
Tom
tr4252 is offline
Old 08-04-2013, 05:35 AM
hayofstacks
pla plastic. you can also print with abs if that's how you setup your printer.
Old 08-07-2013, 08:32 AM
RepRapper
Default 3D printed parts
Tom
It uses PLA or Poly Lactic Acid. This is a low heat very strong plastic. There have been dozens of plastic used. The most popular are ABS that's plastic Lego's are made of. And PLA which is stronger then ABS. If you have ever stepped on a Lego then you know how tough it is.
PLA smells a lot better then ABS and that is why I use it.
Old 08-07-2013, 11:27 PM
tr4252
tr4252's Avatar
Thank you.
What sort of programs do you use in translating the concept to finished part? I use Autocad and can write G Code programs for CNC, but do not work much in complex 3D forms.
Tom
tr4252 is offline
Quick Reply: cowling construction
Page generated in 0.11556 seconds with 43 queries
