New "Builders Links" - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-16-2008, 06:49 PM
Sky Sharkster
Sky Sharkster's Avatar
Default Great Links!
Thanks for the links, Ron. I appreciate it. I've added them to the list.
Ron
Sky Sharkster is offline
Old 08-16-2008, 06:51 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
Compilation of diy brushless controller designs:
http://www.rcgroups.com/forums/showthread.php?t=140454
Compilation of diy brushed controller designs:
http://www.rcgroups.com/forums/showt...hreadid=157193
Vriendelijke groeten Ron van Sommeren
motor building tips & tricks
diy brushless motor discussion group
Drive Calculator download & discussion group
int. electric fly-in, Nijmegen, the Netherlands
ron_van_sommeren is offline
Old 08-16-2008, 06:56 PM
ron_van_sommeren
"Some of us may have run across a brushless motor that has questionable operation, perhaps after overheating it, or after crash damage. It may even have come from a swap shop. The question is "Do you want to connect it to an ESC" and risk possible damage to the ESC? ..."
Several simple test methods:
http://www.wattflyer.com/forums/showthread.php?t=35216
http://www.rcgroups.com/forums/showthread.php?t=240993
Old 08-16-2008, 06:58 PM
ron_van_sommeren
Connector test and numbers, in German techno-geek-speak, which is pretty much the same as English techno-geek-speak We all can read numbers, can't we?
http://www.elektromodellflug.de/
-> datenbank ( = database)
-> hochstromsteckersysteme ( = high current connector systems)
(use http://babelfish.altavista.com for automatic translation)
Old 09-10-2008, 02:55 PM
starcad
Model Designer
starcad's Avatar
Hi Ron, thanks for the list. I was wondering if you could include StarCad Plans at
http://www.starcadplans.net
Thanks again for that assume list
Guy
starcad is offline
Old 09-11-2008, 04:05 AM
Sky Sharkster
Default They're On The List!
Hello Guy,
Thanks for the kind words, I've added the link to the "Plans" list. I also added a note, since W/F does not allow links to site that require registration to view the content, I explained that the downloads are free but registration is required to do so. Since the SITE may be viewed without registration, it doesn't break any rules, but my clarification is necessary.
Ron
Old 10-12-2008, 02:37 PM
Sky Sharkster
Default Clean Up
After finding a couple non-working links, I went through the entire "A to L" page and found 29 bad links. Things change quickly on the web! I deleted the non-working links and combined a couple others.
Next, the "M to Z" page.
Ron
Old 12-17-2008, 06:57 AM
Twmaster
Registered User
Twmaster's Avatar
Here are a couple of links to consider adding:
Building tips by Pat Tritle: http://www.rcscalebuilder.com/Default.asp
Reasonably priced plans printing service:[email protected] He charges only $10 for a 30 sq foot plan on 36" wide paper. Smaller plans, for example he quoted me $4.99 for a 36 x 48 plan print.
I don't think the guy has a web site.
Twmaster is offline
Old 12-17-2008, 12:10 PM
Sky Sharkster
Default New Links
Thanks, Mike,
I've added Pat Tritles' site. I don't know how to make a link to the plans site, but would like to add it to "Kits + Plans".
Ron
Old 09-16-2009, 06:12 PM
FoamHeadMike
Build Crash Repair Repeat
FoamHeadMike's Avatar
Thumbs up GLAD i FOUND THIS fORUM!
Wow Just WOW!
What an awesome database for every kind of subject about Foam model building Imaginable
Thanks for taking the time to do this for usuns
FoamHeadMike is offline
Old 09-17-2009, 03:49 AM
Sky Sharkster
Default Welcome Aboard!
Hello FoamHeadMike, Welcome to Wattflyer!
I'm glad you found the links helpful. I've been working on this a long time and try to keep it upgraded. Sometimes links close and I don't find out about it right away.
Hope you enjoy your time here,
Ron
Old 09-17-2009, 07:37 PM
Huffy01
Huffy01
I just ordered some balsa wood from www.balsacentral.com in Australia.
I bought (this all 915mm long and ungraded wood) 25 100x0.8mm ,10 100x1.5mm, 5 100x3mm sheet. 20 6.5x3mm, 10 6.5x12.5mm strip. 5 6.5x6.5mm triangle. 2 25x25mm block. 5 3x3mm and 5 9.5x9.5mm stick for $150. That includes $13.75 for freight and 10% government service tax.
Huffy01 is offline
Old 09-17-2009, 08:59 PM
Sky Sharkster
Default New Balsa Supplier
Hi Huffy,
I've added it to the list, Thanks!
Ron
Old 10-04-2009, 03:31 PM
Big Johnny
Master Of The Crash
Big Johnny's Avatar
Default Laser Cutting
Yo Sky. You need to add Top Notch Products to your laser cutters index. http://www.topnotchkits.com
John Valentine is great to work with, a true modeler
Big Johnny is offline
Old 10-04-2009, 03:58 PM
Sky Sharkster
Default New Laser-Cutter
Thanks, Johnny, I've added it to the list. looks like some nice kits, too!
Ron
Old 10-22-2009, 02:37 AM
hillbillynamedpossum
Rode the short bus
hillbillynamedpossum's Avatar
http://www.aircraftspruce.com/
Heres a source for everything you need to build a full size air plane. They have aircraft grade plywood, will saw out spruce per your specs, have fiberglass at good prices, and West Systems Epoxy at very good prices. They even have balsa 2x4's Dont know why, but I want one.
And BEST OF ALL they will ship you a FREE PAPER CATALOG. Ive seen them, and they are 2" thick. Do you best Homer Simpson "MMMMMMM Caaataloooog"
Possum
hillbillynamedpossum is offline
Old 10-22-2009, 11:43 AM
Sky Sharkster
Default Spruce Supplier
Thanks, Possum, I've added it to the list!
Ron
Old 10-29-2009, 02:41 PM
Huffy01
Huffy01
I found www.amainhobbies.com and bought some books, it has paypal payments for international buyer. I tried rcstore and tower hobbies but they only have paypal payments for US residents.
Huffy01 is offline
Old 10-29-2009, 02:45 PM
Huffy01
Huffy01
before I forget 2 more sites, www.hobbyparts.com.au ,www.hobbytools.com.au.
Huffy01 is offline
Old 10-29-2009, 04:55 PM
Sky Sharkster
Default New Link
Thanks, Huffy,
This is a great idea, I made a new thread for World Links.
http://www.wattflyer.com/forums/show...631#post656631
Ron
Old 05-29-2010, 06:52 PM
Huffy01
Huffy01
I don't know if this is any use. I've just start airbrushing using Auto air paint's (www.autoaircolors.com) There water based paints and can be used on just about everything but need a clear urethane paint to seal them.
The great thing about the paint is you can use a heat gun, etc to dry them so you can do several passes quickly.
I bought them from www.airbrushmegastore.com thats an Australian company.
Huffy01 is offline
Old 05-30-2010, 02:56 AM
Big Johnny
Master Of The Crash
Big Johnny's Avatar
Possum
I have One Possum, isn't it great.
Old 09-24-2010, 12:25 PM
waynejb
Great job with all those links, Just shows how big this hobby really is.
waynejb is offline
Old 09-24-2010, 12:27 PM
waynejb
I have 2 more sites that are brand new , but I don't have enough posts to post links. I think I need 1 more post.
waynejb is offline
Old 09-24-2010, 12:30 PM
waynejb
One is an instant download plan site for foamies and the other being built around the idea of the foam craftsmen.
waynejb is offline
Quick Reply: New "Builders Links"
Page generated in 0.14240 seconds with 9 queries
