Electric power parts
Old 10-29-2018, 08:59 PM
hkeelljr
Default Electric power parts
Howdy one and all, I am back after a long absence, due mainly to life and changing interests. I have taken up woodturning, and been doing some small craft work also. Now that the FAA has stuck their nose in it and I still have my models I wanted to make sure I am covered when I start back flying. To that end, I am looking for the correct study guide, I know it bites, but they are in charge and might as well get on board. Rather be covered than to be an example to others. I had started a electric stick beforehand, about thirty or forty inches in span, and one thing I had looked for was steerable nose gear. Is there a company that makes the correct size gear, all I am finding is what uses 1/8 dia. wire . Is someone have something smaller or would the bigger gear work. Thanks for the time.
hkeelljr is offline
Old 10-30-2018, 12:55 PM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
For some unknown reason the hobby manufacturers dropped the 1/8" nose gears. The jump now is from 3/32" right to 5/32". Depending on the plane the 3/32" may not be strong enough and the 5/32" may be way too heavy.
Carl Goldberg had a perfect 1/8" nose gear package but it has been out of production for quite some time now. I got lucky and found a package deal on eBay a while back and got five very old NIP. And No I won't part with any. I did find one listed on eBay right now though. LINK. Better grab it while you can! The other option is the smaller 3/32" Dubro 234 LINK. I wouldn't use it on a plane heavier than about 20 ounces MAX though. If the plane is a porker then go with any one of a dozen (or more) available 5/32" gear.
Joe
Turbojoe is offline
Old 10-30-2018, 02:29 PM
have a look at the STINGER gear on Hobby King ... for about $6 - you get trike gear with quick release plates AND a servo with the front leg gear ...
I use these on many models as they work ... are cheap ... and look good.
https://hobbyking.com/en_us/stinger-...ith-servo.html
Old 10-31-2018, 12:06 AM
Turbojoe
Turbojoe's Avatar
Those Stinger gear aren't gonna work too well on a Stick type plane. The nose gear is usually firewall mounted. The picture is of my Mountain Models "Lucky Ace" version of the old Ugly Stick.
Joe
File Type: jpg
Turbojoe is offline
Old 10-31-2018, 12:34 PM
Agreed .... but like my Lanyu T45 - that had firewall mounted front gear ... which I removed and installed the Stinger gear up behind the firewall ...
You could of course remove the servo box and just use the arms with saddle clamps to the firewall ... and a servo back where you want. Its easily dismantled ... once the set screw joiner is loosened and slid of the steering leg ... the leg lifts out of the servo mount. You can set that arm at 90 deg and use the joiner again ...
At $6 a pop ... ??
Old 10-31-2018, 05:13 PM
Turbojoe
Turbojoe's Avatar
At $6 a pop ... ??
And HK shipping is minimum $3.33 for a total of $10.23 with a 14-39 day wait. Want it in less than a month? Then shipping is $16.84 for a total of $24.27. Why not just get the proper part for $11.00 shipped and not have to modify anything or wait until the row boat from China gets here? HK is not the panacea for USA modellers like it is for those of you in Europe.
Joe
Turbojoe is offline
Old 10-31-2018, 06:48 PM
Hi TJ ... what happened to your US Warehouses ?
Please note - I was not pushing the Stinger onto anyone - just suggesting it and when your post said that it was unsuitable - posted a way to make it so.
If a suitable item can be found quicker - fine - I am first in line to say go for it.
Old 10-31-2018, 07:30 PM
Turbojoe
Turbojoe's Avatar
It's only available in the Hong Kong warehouse.
Joe
Turbojoe is offline
Old 10-31-2018, 07:59 PM
Joe
The strange thing is ... over here - unless I VPN - I can only see EU / Global W/H listings ... we don't get to see US and other W/H listings ... so I am unaware of US W/H situation.
My apologies.
Old 10-31-2018, 08:08 PM
Another solution of course ......... bend your own legs ?
I used the black rods sold by HK for my Concorde ....
TU144 being finished ...
06-28-2017 05:22 PM
01-09-2017 03:23 AM
DonT
07-22-2015 02:18 PM
78yes
05-04-2014 04:20 PM
Quick Reply: Electric power parts
Page generated in 0.07826 seconds with 14 queries
