XB-70 Valkyrie, 24" Span
Old 01-13-2010, 07:29 PM
Octavius
Alien Surfer
Octavius's Avatar
Default XB-70 Valkyrie, 24" Span
After what I'd like to think of as a success on a 20" version, I've decided to build a larger one. This one is a slightly perverted XB-70 since I've changed some stuff. Mainly the engine ducking is much smaller and no intakes. One thing that's important to me is to have a scale length fuselage.
Span: 24"
Length: 41"
Motor: Turnigy 2836 3700kv
Battery: 1750 mah 4S 30/40C
ESC: 60 A
Prop: APC 4.2x2 or 4.1x4.1 (possibly cut down)
After this I'd like to make an even larger one on twin pushers and have working wing tips that drop and completely scale.
Last picture is my previous XB-70 at 20" span.
ID:	118123   Click image for larger version
ID:	118124   Click image for larger version
ID:	118125   Click image for larger version
ID:	118126   Click image for larger version
Octavius is offline
Old 01-13-2010, 08:03 PM
Billmanak
Looks great. This has always been on my wish list.
Billmanak is offline
Old 01-14-2010, 03:28 AM
Dr Kiwi
Just a question... can you really use all the speed generated by that very high Kv motor on 3s/4s with a toothpick prop... would it not be better to use a slightly lower Kv motor and a somewhat larger prop for greater thrust and efficiency??
3700Kv @ 14v and 80% of Kv x V must get you >40000rpm... that's over 160mph pitch speed. Even 3s will get you 130mph pitch speed... what do you reckon the max. airspeed of the plane could be?
Dr Kiwi is offline
Old 01-14-2010, 05:15 AM
Octavius
Alien Surfer
Octavius's Avatar
This setup is popular with some of the speed guys, and I've tested it on 3S on the plane below. Crashed before getting to try 4S.
Even though the real XB-70 is mach 3 normally I wouldn't push a scale plane this hard. I'd just like to see what's it's capable of. I have a more reasonable motor/battery combo I might switch to after I test this. But I almost might just move to the next, larger version of the plane which is my end goal.
I'd like to get this one to 100 mph.
End goal version might roughly look like a twin setup:
30" span
50" length
2836 2300kv (2X)
1750mha 3S (2X)
30A ESC (2X)
APC 6x4E and 6x4EP
Octavius is offline
Old 01-14-2010, 07:54 AM
Octavius
Alien Surfer
Octavius's Avatar
Didn't have much time tonight so I only built the canard. It turns out it's only 13.75 sq in and the moving part is 1/3 of that. It's quite small.
Octavius is offline
Old 04-10-2012, 01:02 AM
heartbreakfatty
Default XB-70 Canard
You will find that you have to increase the moving part(elevator)to about 2/3 of the canard. 1/3 is not enough. In fact elevons are the best solution to this. I have a foamie that uses elevons and it works fine. In fact. if I was building a scratch XB-70, I would set it up so the entire canard wing moved. This aircraft has been my favorite model of all time.
heartbreakfatty is offline
skyline_g35
Electric Ducted Fan Jets
11-17-2009 04:09 AM
meatbomber
9
07-02-2008 09:27 AM
PerlAddict
64
01-04-2008 02:50 AM
lmopar69
10-02-2007 02:07 PM
Quick Reply: XB-70 Valkyrie, 24" Span
Page generated in 0.11879 seconds with 21 queries
