Gee Bee model E
Old 06-21-2013, 11:59 PM
KingOfClass
Default Gee Bee model E
I recently acquired a vintage coverite Gee Bee model E fuselage. Does anyone know where I can find wings to fit this? (I think the wings are supposed to be 56 inches) can it be efficiently powered by an electric motor? and can I make it a 3 channel?
Thank you,
Jonathan
KingOfClass is offline
Old 06-22-2013, 12:03 AM
Thank you,
Jonathan
Hope this Link Helps, Chellie
http://www.outerzone.co.uk/plan_details.asp?ID=2853
http://brodak.com/spirit-of-yesterye...-bee-e-rc.html
Old 06-22-2013, 12:20 AM
You may never find an exact fit for the wings without redesigning... You have to identify what kit it was, if it was a kit.
Fortunately the wing is fairly simple on that aircraft.
Yes it can be powered by electric. We now have electric power system choices appropriate for less than 1/2 oz to over 50 lb models. It will be a question of identifying what power system is right for your model.
"Vintage" can mean a lot of things, depending on who you are talking to. I tend to think of 1930's and 1940's models when someone says "vintage". That would make the aircraft Free Flight (90%+ probability if its that old) These can easily be converted to 3 channel in most cases.
If it was originally a 4+ channel RC model then converting to 3 channel can be problematic. You need a new wing so some of the changes needed could be designed into the replacement. That would give a good chance of success but it guarantees you will be building a wing from scratch.
If it was originally a control line model its usually a bad idea to go for less than 4 channels when converting to RC.
So... we need more info about the model. Pictures would help if you don't know exactly which kit (or maybe even ARF) it was.
Its possible it was the one covered in this (other discussion site) thread.
http://www.rcgroups.com/forums/showthread.php?t=1530902
If it is... there's a lot of info available.
Old 06-22-2013, 05:54 PM
KingOfClass
That seems to be the correct model because the tail number and appearance is the same. I will try to post pictures late next week. (I'm in another state ATM) the model still has the control rods and control horns for the elevator and the rudder and they seems to be in working order. Any specifics you would like to know? As for "vintage" it is late 70s early 80s based on what I've read so not really vintage. I hope this helps and appreciate the input.
JR2012
11-30-2012 06:19 PM
phillipmorris
06-29-2012 04:16 PM
phillipmorris
ParkFlyers
06-28-2012 04:28 PM
Capt Easy
12-05-2011 07:21 AM
Flysohigh
Foamies
04-08-2011 11:08 PM
Quick Reply: Gee Bee model E
Page generated in 0.09025 seconds with 13 queries
