detrum bm2815a-kv 1100 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Brushless Motor Construction Discuss design and construction of custom Brushless motors
Old 03-02-2012, 10:49 PM
golfryan
Default detrum bm2815a-kv 1100
detrum bm2815a-kv 1100 Im trying to find specs on the motor and cant find them any anywhere. Broke the shaft off and hopefully can just replace the shaft but dont know what size it is. Hasnt even had a maiden flight on it just taxied it into a wall. I cant get the shaft out its almost like its pressed into the housing took out the set screw and the c-clip and it wont budge, any suggestions. There is a little shaft left just wondering if I could put a spinner collet onto it but i dont know the saft size and its hard to measure 3.5 mm or 4mm
golfryan is offline
Old 06-22-2012, 06:21 AM
waynebyerlyjr
Default dynam motor replacement
graysonhobby.com and xheli.com both stock the dynam motor.
graysonhobby.com also stocks JUST the shaft. the shaft IS pressed into the motor housing VERY tightly, but may be hammered out if you take care. I HAVE replaced mine ... lightly tap out, lightly tap in ... no problem really.
waynebyerlyjr is offline
Page generated in 0.04039 seconds with 10 queries
