Safety Guides for Your Drone Before Flying - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
UAV / FPV Forum to talk about UAV / FPV electric R/C flight.
Old 02-24-2016, 09:20 AM
Gens_Tattu
Post Safety Guides for Your Drone Before Flying
As Drone become more and more popular in rc field, it has been more and more things for us to pay attention to. The most important thing is check the drone physically and know the basics before fly your drone. Drone parts are expensive, so it is necessary to check out all the parts before you head out for a flight. Here are some basics you need to check off before taking off your drone.
1: Weather Conditions
Drones is critical to the operating temperatures so that their gears do not freeze and their batteries remain undamaged. Be sure to refer to your owner’s manual for your device’s operating temperature range. Almost all consumer drones should not be flown during the winter due to below zero temperatures.
2: Your Drone Status Checking
Also it is important to check your drone for any loose parts or areas of damage. Begin by checking that the unit’s blades are firmly attached and would not fall off the craft during a flight. Also inspect each blade for nicks or cracks. If one is found, it is important to ground your flight and obtain replacement parts.
3: Battery’s Capacity Checking
Checking your drone’s battery is fully charged and ready to fly. If you suspect your battery may have an issue, immediately contact your aircraft manufacturer’s support department.
Now get a proper battery is good for us, many drone battery now can automatically check the battery capacity, battery status, such as Phantom battery, Tattu Plus smart battery, etc. Before fly, you can know the battery status by the indicator.
4: A Clear Area
There are many different shapes and sizes of drone, so you need to ensure the fly room before take-off. Large vast fields are recommended, but that doesn’t mean you can’t take-off from your backyard, permitted it has enough space.
5: Return Home Location Setting
Before flying, please ensure that you have a strong GPS signal and note whether your drone has a lock on its current take-off position. This can be set up within the mobile application.From personal drone flight experience, I also recommend programming your drone first to ascend to its maximum altitude before returning home.
Gens_Tattu is offline
Old 02-24-2016, 11:34 AM
You left off the most important safety rules...
The operator MUST ensure that his aircraft will not interfere with full scale aviation in any shape manner or form.
In case of potential conflict with full scale, the drone must give way, even if this means destruction of the drone in order to avoid the full scale aircraft.
The only way to ensure compliance with this is to operate the drone within line of sight.
If operating FPV it is highly recommended to have someone watching the drone and the sky to ensure there is no conflict in case of the approach of a full scale aircraft.
Operation in the immediate vicinity of any airport or within the takeoff or landing patterns is not allowed without coordination with the airport operator and communications to ensure avoidance of conflict with full scale aircraft.
Old 02-24-2016, 01:20 PM
Bald Paul
Bald Paul's Avatar
Absolutely! It doesn't matter what your definition of "drone" may be - your craft (quad, heli, fixed wing) is a model, and is much less important than any life.
Bald Paul is offline
liff
05-07-2015 07:37 PM
02-27-2014 01:24 PM
frenchstan
Events, Shows and Fun Fly's - Electric Airplanes
12-21-2013 04:36 PM
04-09-2012 12:57 PM
Old Tin Man
09-10-2011 11:12 PM
Quick Reply: Safety Guides for Your Drone Before Flying
Page generated in 0.08972 seconds with 13 queries
