SUPER Quick Delta Scratch Build
Old 11-09-2010, 03:56 AM
  #851
Originally Posted by mclarkson View Post
I'm planning on working one of these up. I've gone thru the threads and pieced together what I think are all the final dimensions. I've laid it out to take maximum advantage of factory-cut straight edges. If anyone sees anything missing or wrong, please let me know.
Where did the center of gravity finally end up?
the vertical stab does not to be so long on the bottom, cut it down to about 8" from 15", to allow sliding the lipo around for your CG adjustment, this delta requires 20 oz of thrust to fly right so a 2408-21 with a 7x6 or a 8x4 prop, 3 cell lipo 1000 to 1300mah 20C is good, with a 25 amp ESC, use a prop saver, a cg of 6" is a great place to start at, then fine tune it from there to find a sweet spot that you like dont forget to add the CF tube for strength hope that helps, Chellie
Old 11-09-2010, 04:20 AM
  #852
Chellie. Thanks!
Have you changed the design since the original pictures were posted? That stab has got to be at least 13" in the photos. Not that I'm disputing you on your design, understand; just trying to match up my measurements from the photos. 8" would only bring it to the front of the squared-off at the rear of the wing.
Old 11-09-2010, 04:37 AM
  #853
Chellie. Thanks!
just use the TLAR method That, Looks, About, Right, LOL if was found later that the longer thin stab towards the front was not needed and only got in the way of the lipo and CG adjustment, so the rudder rear section was used, your delta is looking great. BTW with a 7x6 prop, they Haul Buns
Old 11-09-2010, 04:55 AM
  #854
So the angle stays the same, but you just chop off the front about where that unlabeled down arrow is? Or slope down at a sharper angle?
Old 11-09-2010, 05:06 AM
  #855
where the arrow is at is about right, and cut the stab anyway you like what ever looks good to you, these measurements are only a starting point, and a basic size, be creative take care and have fun, Chellie
Old 11-09-2010, 05:31 AM
  #856
Ha-ha! I've updated my drawings, just to spite you.
"Whatever looks right" works better when you've built 100 planes. My mom is the same way with cooking.
ME: Mom, how much salt do you put in?
MOM: Put some in until it tastes like it's got enough salt.
ME: Mom, how much flour do I need?
MOM: Just add flour until it looks right.
Old 11-09-2010, 05:49 AM
  #857
PERFECT See, Now your already an Aircraft Designer Take care and have fun, Chellie
Old 11-10-2010, 03:23 AM
  #858
I'm planning on putting an EMAX CF2805 motor on this, along with 4G servos and a 30a ESC (cuz that's what I have.) How small a battery can I get away with?
Old 11-10-2010, 06:23 AM
  #859
whats the KV on your motor 1600 or 2840 if its the 1600kv your in luck, if its the 2840kv motor, you might not have enough thrust, and it will be a Lawn dart, I need to know what the kv on the motor is, before i can recomend a lipo and prop.
http://www.rcgroups.com/forums/showthread.php?t=762172
http://www.google.com/#hl=en&expIds=...3eeabb4c23868d
Old 11-10-2010, 09:22 AM
  #860
Hi, Chellie.
Headsup says: the Emax CF2805 is a 0.9 ounce, 2800KV direct drive outrunner.
Jeff recommended a 6x4 prop with it (tho that was for a slightly different project.) Since that was a 24" wing, I was hoping the same setup might work for this plane.
Old 11-10-2010, 09:35 AM
  #861
if its the 2800kv motor it wont work, you cant turn a big enough prop with it to get any thrust. and this delta basicly flies on thrust rather than lift. it requires 20 oz of thrust. get the 2812 motor from heads up rc, and you will be fine. also a 1000 to 1300mah 3 cell lipo is what is needed, also a prop saver, a 6x4 or 7x4 sf prop will work the best.
Oct 25, 2007, 10:42 AM #2 Dr Kiwi
Registered User
5"-6" sounds okay for small motors of ~1600Kv... I doubt you could use more than a 3"-4" prop on a small 2840Kv.
If the motors are bigger, then the rules change.
What is the size/weight of those motors? E-max has changed nomenclature and some of the small ones I tested as 22xx are now labeled as 28xx.
Old 11-10-2010, 09:40 AM
  #862
Now I need to either
A) buy a new motor etc.
B) find a new project to consume my leftover parts.
p.s. Don't you ever sleep?
Old 11-10-2010, 09:44 AM
  #863
sometimes get a new motor, you will be able to do more with a lower KV motor, as you can turn a bigger prop for more thrust, the 2800kv motor is going to limit what you can build,
Old 11-10-2010, 10:57 AM
  #864
I'll find something to do with that motor.
Old 05-17-2011, 09:22 PM
  #865
computerman0219
Hi Everyone I got a little more done, It will be a ARF before I go to bed tonight or this morning, here is what was done so far, I taped the elevators on to the body, I used a New Tape from Scotch, NOTE FOUND OUT IT DOES NOT WORK VERY WELL IN WARM WEATHER, it got to 88 degrees here and it was too spongy, OH Well, I TRIED IT, I tape the body to elevator with a 1/4" gap, then press the tape together at the middle/seam, that makes for a nice tight hinge, thats very flexable, I also I cut a 6" lenght of 3/8" X 3/8" bass wood to the front body for the motor mount, I left it sticking out about 1" so I can slide a stick motor mount to it, and I added a piece of carbon rod to the rear of the rudder to give it some strength, I need to cut the rod to length after the Epoxy dries, in 5 mins here are a few more pics, Take care, Chellie
What's the best way for putting on the tape hinge? I know you have leave a gap for the elevons so it will have room to move but I didnt know how much?
computerman0219 is offline
Old 05-17-2011, 09:43 PM
  #866
Wrench66
Ya' need to use mo rudda!
Wrench66's Avatar
Hi Computerman
The elevons are done with the age old "that looks about right" gap......LOL, as long as there is enough gap to make contact with both sides of tape (top and bottom, tape touching right along the seam) you'll be good to go. There are plenty other more complicated ways to go about hinging these controls but none as easy and strong.
Good luck
--Ray
Wrench66 is offline
Old 05-17-2011, 09:52 PM
  #867
computerman0219
Duh I see it now in the quote...sorry my mistake! Thanks!
Old 05-17-2011, 09:55 PM
  #868
computerman0219
On the vertical stab. Are you keeping the rear of it flush with the elevons still or are you flushing it with the main fuse? I'm using your new shortened stab btw. 8in. Long.
Old 05-17-2011, 10:00 PM
  #869
Wrench66
Wrench66's Avatar
Not quite sure whatcha mean?.....if you you are asking where to end the lower part of the vert stab then just cut it off where the fuse plate ends, no need to extend it back into the elevons.
Wrench66 is offline
Old 05-17-2011, 10:22 PM
  #870
computerman0219
Hi Everyone Making the bottom skid, from foam, with foam board, you have to sand the paper with rough sand paper to take off the shine on the paper, so when you soak it, in the bath tub like i do, the water will get into the paper quicker, and it will peel off, the paper adds a lot of weight, so its better to remove it, the foam is soaking right now, so its time for a glass of wine ok lets make it a tall glass of wine Chellie
When you soak in the water what temperature do you use (hot or cold or warm)?
Old 05-17-2011, 10:26 PM
  #871
Wrench66
Wrench66's Avatar
Either is fine, although the warmer water feels nicer....haha.
Wrench66 is offline
Old 05-17-2011, 10:50 PM
  #872
computerman0219
lol thanks Wrench!
Old 05-17-2011, 11:39 PM
  #873
computerman0219
Btw how long does it typically take to soak in water?
Old 05-18-2011, 03:33 AM
  #874
Wrench66
Wrench66's Avatar
Give it at least 20min, done right the paper may even float off the foam with little effort. The foam won't suck up the water so leaving it in there for a bit longer will only do you good.
After the paper is gone take a good look at the bare foam since a lot of times you'll see/feel a little of the adhesive still sitting on the foam.....just roll it off with your fingers while it's still wet You'll be amazed what that paper weighs compared to the bare foam!
Wrench66 is offline
Old 05-18-2011, 04:27 AM
  #875
computerman0219
Ok great! Thanks Wrench! I have the delta cut out but still have to soak it. I hope to get around to it tomorrow or Thursday. As mentioned I am building Chellie's delta model, but I have a question regarding the skid plate and vertical stab. is it just epoxied in? To me that just don't seem tough enough. One good flip over in the grass and it would seem like it would break off. Has anyone else built one? Did you use something down the side of the vertical stab to reenforce it? Thanks in advance!
Page generated in 0.13449 seconds with 11 queries
