folker power
[quote=Walt Thyng;21506]Well, here's the next to the last batch of photos of my Dr.1 build.
1: brass cottter pins used for bracing wire lugs 2: baby stroller wheels. One on right covered with Ultracoat. I poked a hole in the axle area and did not iron down the center rim until all the wrinkles were out. Looks pretty scale to me! 3. parts to make scale like hub and adapt stroller wheels to plane axle diameter. Wheel collar set screw passes thru inner axle spacer and tightens directly on plane's axle. 4. Hub. I need smaller washers and cotters. but this gave me proof of concept. 5. 3/4 front view. color registratin is poor. Actual color is ultracoat bright red. 6: side view 7. top view Weight minus power pack and aileron servos, machine guns, pilot 4.75 lbs WWI ace: see how close you came? :eek: Hi what motor and batteries do you use in that folker:cool: |
Walt, she's beautiful!!! That is probably the best looking tripe I've seen in awhile. You truly are a master!! If she flies half as good as it looks it will be perfect. I was close wasn't I?!!! Steve.
Yup. You were off by one number . This is Dr.1 404/17 flown by Lt. Adolf Ritter von Tutscheck in March of 1918. Here's the URL for my info http://www.luftfahrtgeschichte.com/dr1.htm
Walt PS anybody got a trick for building Spandaus? I keep looking for some kind of expanded or perforated material, but haven't come across anything yet and I don't know when the guy who bought out Williams Bros will actually be up and running. WT PPS saw a pair of the new DuBro 5" WWI wheels $37.00 !!!!!!! |
Spandaus
Try this on for size Walt. Allan is a good friend of mine and has some VERY light machine gun kits. I'm building a pair for my DRI (hint, hint Steve).
www.wrightbrothersrc.com/our_kits/spandau.htms |
Those guns look great Martin!!! Steve.
scalercflyer: the link didn't work. Could you post it again, please?
WT |
Spandaus
Try this Walt. Martin
http://wrightbrothersrc.com/ |
Where are you?
WWI ACE where are you? :confused: See my inquiry about the outrunner for the DRI. BTW Guys, I really enjoyed the historical guessing game we played trying to guess Walt's camo scheme. I think I'll post one myself. Maybe the winner will get something special. :D Martin
Martin. In the triplane you are building I have the same motor-gearbox combo as Nitrocharged. For the little tripe I'm getting from Aerodrome I plan to use my Eflite Park 370 outrunner that weighs 1.5ozs. Should work fine and give plenty of power. The weight will probably be okay because we all know how easy it is for tripes to get tail heavy. I would rather have the extra weight making power instead of just hanging there as dead weight. Know what I mean. I'll use my Castle Creations Phoenix 10 ESC. It works great and weighs next to nothing! For a battery I'll probably use my TP 2-cell 830mah lipoly unless I need more power. Then I'll step up to a 3-cell. Steve.
Rhonas, sory I missed your post. Power for my Dr.1 is an Astro 40G (cobalt)
on 20 P3000 NiMh. If my day works out as planned I'll be building the pack today and have some photos later on. Esc is an Astro 204D. Prop will probably be a 14/10 (scale diameter) WWI Ace: thanks for the lead on the Spandaus. They do look good. Problem is my tripe is 1/6 scale and the closest they have is 1/8. I think they'll be too small. Scalerdflyer; did you check out the Tripehound link I posted? I had so much fun building the Dr.1 that I think I'lll start on the TH next. Walt |
you guys make me want to get busy and redraw my plans of the 61" 1919 Fokker, C1, 2 passenger model. mine was complete ready for motor installation, but Hurricane Katrina took all of the models , plans along with the house and 3 shops. now getting back in business in new location. had posted fotos on RCU, Vintage, but can't find them. just dumb thumbs, computor wise. dick stamm
Welcome!!! We're happy to have you. Dust that thing off and let's get started!!! Steve.
Welcome indeed!
Dick, you are most welcome here! Boy, that hurricane was a raw deal, but you can always start over! Nothing can take your flying skill away. Hang in there. If there is anything I can do for you, let me know, and welcome again!. Martin
Walt!! Did you fly the tripe yet? Steve.
Steve,
no flight yet. Been very busy with work. All conrols now functional and template for power pack laid out (one 12 cell and one 8cell in semi-circle) should complete the pack Wednesday, then it'll be a waiot for weather which doesn't look good for at least a week. Walt |
Latest pics
Walt got any pics of the completed tripe? I would love to see it. Martin
Martin, latest photos are in Post #374. Next set will be of building the power pack and installation. I'm still trying to solve the spandau problem and don't have a pilot (too cheap to spend the money for pre-painted and no Williams Bros available).
Walt |
checkout iron aces pilots....they rock.
7 Attachment(s)
here's a batch of photos on building the custom battery pack for my Dr.1. A quick finger check indicates that the balance is very close.
1. tinning the brass connector straps 2. tinning the cells 3. using cowl as jig, bottom straps 4. top straps 5. test fit of completed pack 6. pack with rubber band restraints (I CAN do a neater job!) 7. pack with cowl in place. Once I add 4 dummy cylinders you won't be able to see much of it. Next photos:building dummy cylinders and (maybe) Spandaus Walt |
Batteries
WOW! :eek: Those are some serious batteries Walt! Can't wait for the flight report. Martin
3 Attachment(s)
some progress....some....
I hate guys with neat workbenches (-:
Walt |
I doubt it looked like that while he was building. He cleaned it before the picture!!! How could you ever find what your looking for if it's that neat? Steve.
Workbench
Gee Guys I don't know what you are talking about!! My workbench is ALWAYS neat and clean !! :D Martin
Found a really cool (and cheap) way to simulate Oberursel engine. Photos soon.
Walt |
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
