-   WWI Era (https://www.wattflyer.com/forums/forumdisplay.php?f=70)
-   -   WWI planes (https://www.wattflyer.com/forums/showthread.php?t=259)
Percyflyer 01-16-2009 05:51 AM
http://store.polkshobby.com/scripts/...0080&conum=002
try this one
esm2002 01-16-2009 08:57 AM
Originally Posted by luc (Post 2494)
here is the GP DR1 I have...
It is very nice!:tc:
I'm just new here,just want to learn something about the RC models.:)
FlyingMonkey 01-16-2009 11:49 AM
Welcome to Wattflyer esm!
If learning about the hobby is your interest, you might check out some of the threads over in the Beginners forum...
http://www.wattflyer.com/forums/forumdisplay.php?f=7
There are some guys over there that do an excellent job of describing the basics on up through some more involved aspects of the hobby.
There's even a section dedicated to aerodynamics, if that's you thing...
http://www.wattflyer.com/forums/forumdisplay.php?f=33
And then, if you're tired of the sanity and sense found in other threads? Want a break from reality? Join us today... HERE! Go right to the end and say hello, the previous 23K+ really have no bearing on what's being said right now...
There's a little something for everyone here, hope you find it to your liking.
degreen60 01-16-2009 07:41 PM
Comet DR1
2 Attachment(s)
Here are a couple more pictures of my Comet Superstars Fokker DR1. It is almost ready for first crash test, oops, test flight. If it flys good then it will get painted and other finishing touches. It amost blances at the COG shown on the plans without the battery installed. I should be able to get good COG without adding extra weight. If anyone already has this plane flying let me know where you have the COG.
The SE5a is back together and waiting to crash, oops fly again.
If your afaird to crash them don't fly them.
I still have 2 crash victims to repair, one from receiver failing and other from that dumb pilot that just don't seem to learn that he can't land in trees. HAHA
dbcisco 01-16-2009 07:57 PM
I see you like to mix foam and balsa. I am thinking of doing foam wings for my SE5 for flying and the covered balsa wings for show (or until I can fly it decently). I already did the meat tray tail feathers. Any thoughts anyone?
degreen60 01-16-2009 10:00 PM
I like the built up wings cause I think they are a lot stiffer than foam. The foam I use as tail and controls is very stiff pink foam. I also use the pink foam to make wheels with paper spoke covers. The pink wing sub wing between the wheel is to see if it will hold up to landings or if it has to be replace often. If it holds up I will make a built up sub wing to replace it.
I need to make a new top wing for my DVII. I am going to use balsa for the spar, leading and trailing edges, and wing tips. I am going to see if I can use thin foam for the ribs.
floss 01-16-2009 11:32 PM
2 Attachment(s)
d60
Here is a couple of pics of a Dr1 with foam ribs etc, nice mix. I saved them to study and give it a go some day, the foam was from meat trays. A guy on RC groups built it, flew well too.
degreen60 01-17-2009 12:10 AM
Originally Posted by floss (Post 545862)
d60
I see he uses sheet foam for tail and ailerons same as I did. I need to look through foam scraps and find foam about 1/16 inch thick cause the leading and trailing edge parts are notched for 1/16 inch ribs.
WWI Ace 01-17-2009 12:13 AM
You guys are the KINGS of foam usage Degreen!!! Steve
degreen60 01-17-2009 02:02 AM
Not sure that I am, wait till after crash test. HAHA
7car7 01-19-2009 08:59 PM
Rudder mixing
This last saturday I had the absolute JOY of flying all 4 of my planes in one morning. Never done that before.
GWS Tiger Moth
Eflite Jenny (ailerons)
GP SE5a
Albatros (scratch build)
I got a brand new radio with dual rates, expo, and mixing. I really enjoyed flying with the rudder mixing. Did this to all 3 of the aileron planes. What a difference. I had been using my left thumb to add rudder for coordinated turns, but having it automatic was an amazing difference.
The Albatros was especially nice to fly this way.
It makes me wonder if I should take out some differential, especially the SE5 - so I could have a more axial roll rate. (the mixing can be turned off by the flick of a switch).
Just makes me wonder, if the real biplanes ALWAYS use rudder to coordinate, or if it's an option. The planes were looking so scale, and slow flight was so much more stable and safe feeling. I'd sure recomend it to anyone with a WWI plane.
I'd be interested to hear others thoughts on rudder mixing.
Chris.
Biplane Murphy 01-19-2009 09:30 PM
Originally Posted by WWI Ace (Post 545044)
Alright gentlemen, one of our club guys just bought a 1/6th Balsa USA Sopwith Pup and I want a 40 size German slimer to dogfight him with!! I would like to get a Fokker triplane. A kit would be best. Anybody know of anything? Steve
Here's an ARF..... http://www.rcuniverse.com/product_gu...fm?kit_id=2643
I know I saw one designed for an OS .70 four stroke....a .40 size 2 stroke would be comparable. But I can't remember where. It was a kit though.
EDIT!!!!!
Found it!!!!!!!!!
A Proctor Kit
http://www.proctor-enterprises.com/p...vk/dr1/dr1.htm
I want this one...I have an OS .70 four stroke that needs a plane to be in.
WWI Ace 01-19-2009 11:53 PM
Oh Murph!!! You're a genius!!! I'd forgotten about this one!! Now if "MOMMY DEAREST" doesn't beat me with a wire hangar I'm in great shape!!! Steve
scalercflyer 01-20-2009 12:11 AM
VK tripe
Chris, Steve you don't want that Proctor kit (VK) believe me! I owned this kit at one time as well as the built up plane. The kit was a lumber yard and DIFFICULT to build (over engineered). The plane was very fragile and easily broken. Buy the ARF instead. Martin
Biplane Murphy 01-20-2009 01:13 AM
Hi Marty......Thanks for bursting my bubble....hahahhahaha
So.......That kit isn't the best around huh?
At $209 you would think it was a decent one.
Please tell me more about it, because it is one I have had on my wish list for about 18 months.
Thanks...Chris.
walterk 01-20-2009 02:05 PM
Aerodrome SPAD VII
2 Attachment(s)
:silly:
Here are a few pictures of the Aerodrome SPADVII that I finally completed. I have not yet flown it. It has a Rimfire 28-30-1250 for power.
Walt
Attachment 91152
Attachment 91153
7car7 01-20-2009 04:08 PM
Walt, that's gorgeous! Very good job. Looking forward to hear how it flys. How much does it weigh with battery?
This is killing me. I really want a Spad as my next plane, but I can't decide between yours, or Great Planes, or a scratch build. If scratch build, it would be a 2 seater Spad XI. Really don't have the time for a scratch build, so that may have to be another time.
I really like the tan schemes for some reason, so that's what's making me shy away from the GP ARF.
walterk 01-21-2009 01:57 PM
Aerodrome SPAD VII
My SPAD VII weighs about 25oz with battery. It was a short kit. An early version and had some errors and incosistencies that I understand have been worked out. I wanted a SPAD XIII but at the time they did not offer a kit at the time. I plan to get the GP SPAD XII but I still may build one.
Walt
rhino 01-21-2009 06:03 PM
That is a good looking spad, Walterk, thanks for showing us!
scalercflyer 01-22-2009 12:26 AM
Spad
DITO! Keep up the good work!
degreen60 01-22-2009 10:44 PM
1 Attachment(s)
Here is a picture of my rebuild of top wing on my Fokker DVII using foam for the ribs. I cut the ribs out of the egg carton lids. They are the easiest ribs I have ever made and FREE. I had an old plywood master rib that I just laid on the foam and used a shart knife to cut around. No grain to worry about spliting. Next built up scratch I build will have all foam formers. I usally end up braking some of my formers along the grain when building my planes. Foam does not have that problem. A build up plane using foam and balsa should be strong.
floss 01-23-2009 05:59 AM
3 Attachment(s)
I've gotta try one of those wings, looks nice and simple.
Using a mix of materials works best for me. Here is my scratch DIII being built with balsa, foam and ply from packing cases at work. You are so right with your comment on the grain, foam has none and is easy to work with, sands well too.
FlyingMonkey 01-23-2009 03:03 PM
WWI fans!
This month in Air Classics they have an excellent article on the DR1
Sorry guys, it's NOT RED!!!
scalercflyer 01-23-2009 11:52 PM
Albatros
Excellent work Floss! The Albatros DIII is a wonderful subject to model. BTW, what plans are you using? I have 2 sets of plans for a DVa, small and large (1/4 scale!!). How did you manage the sheeting on the fuse? I like the use of foam bulkheads. I think I'll try it too. Keep us up to date on your build and please share with us your building techniques. Martin
scalercflyer 01-23-2009 11:54 PM
Red again!!!
Don't even go there flying monkey! Martin
FlyingMonkey 01-24-2009 12:58 AM
Originally Posted by scalercflyer (Post 550768)
DON'T EVEN GO THERE FLYING MONKEY! mARTIN
I was confused.
There on the front of the magazine, was this three winged plane.
It had the black German crosses on it.
But I couldn't place it.
It was a sort of stripped green pattern on it.
It looked for all the world like a DR1, but it wasn't red.
When I read the cover, it claimed there was a story about the DR1 in the magazine. So I quickly flipped the pages to find this story.
When I got to the page it indicated, the DR1 was nowhere to be found, but here was this beautiful three winged plane, obviously german, but completely the wrong color.
They wrote the article with the images, as if they were talking about the DR1, but it just didn't ring true.
I did write a letter to the editor, letting them know, they either had the wrong plane pictured, or the images they had were ruined, and the colors were horribly off.
Everyone knows, every DR1 produced, was RED!
Cookie 01-24-2009 01:03 AM
Yah. What's wrong with those guys? They must be color blind.
scalercflyer 01-24-2009 01:57 AM
Full of lead
FM I'm gonna fill your furry tail full of lead! Cookie, you're not helping here! :mad::eek::D Martin
Bub Steve 01-24-2009 02:02 AM
Bub steve
http://farm4.static.flickr.com/3089/...b6c14d6072.jpg
FlyingMonkey 01-24-2009 08:57 AM
you'd have to get behind me first
:D
scalercflyer 01-24-2009 10:54 AM
Never fear!
Never fear! My superior flying skills will win the day and rid the world of the evil Flying Monkey and his minions! :eek::D:) Martin
degreen60 01-24-2009 11:47 AM
I just don't understand some of the articals I read about the DR1. Some of them claim when the plane was shipped to the front line it was painted a streaked green, now we all know this is wrong, they were all red.
degreen60 01-24-2009 12:01 PM
One thing I do read about the DR1 that I think is a false claim it how great of an airplane it was. By the time it was built the Sopwith Tripe had been pulled from the front lines as obsolite. There were only 320 DR1 built cause they were obsolite when built. The DR1 is famous for getting the Red Baron killed, maybe if he had been flying his DVII that day he would have lived to the end of the war and the DR1 would be just another model of WW1 plane that not many were built. Over 2500 DVII were built.
FlyingMonkey 01-24-2009 12:01 PM
http://www.independentfilmsdirect.co...t/view/346/48/
this should hold you over until I find what I am searching for...
FlyingMonkey 01-24-2009 12:18 PM
here we are...
http://www.geocities.com/derostwind/
The best part, the "American" in the final film, was originally a character named Wilber, a flying monkey.
My first name, even though I use my middle name of Fred, is Wilbur.
What a coincidence, huh?
http://www.geocities.com/derostwind/...ual/wilber.jpg
http://www.geocities.com/derostwind/.../wilber1.5.jpg
http://www.geocities.com/derostwind/...al/wilber2.jpg
http://www.geocities.com/derostwind/...al/wilber3.jpg
http://www.geocities.com/derostwind/...al/wilber5.jpg
http://www.geocities.com/derostwind/...ual/planes.jpg
http://www.geocities.com/derostwind/...ter/wilber.jpg
[media]http://www.geocities.com/derostwind/animation/zeplin1.gif[/media]
[media]http://www.geocities.com/derostwind/animation/spyglass.gif[/media]
scalercflyer 01-24-2009 09:37 PM
FM's post
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Wow! Martin
FlyingMonkey 01-24-2009 09:45 PM
I'm afraid to ask, was that a good wow, in regards to this video game,
or a response of shock at the fact america's children are being lied to about colors of the great planes of WWI?
scalercflyer 01-25-2009 12:57 AM
Response
It's a WoW response to your last posting..... and none of the children are being lied to.. :rolleyes: .. just subjected to false and misleading information (ie, all WWI planes a red). :mad: My airplane is not red.. BTW, which one of the pictures you posted is you? :D Martin
FlyingMonkey 01-25-2009 01:03 AM
the guy with the monkey...
:D
degreen60 01-25-2009 01:07 AM
:D
Your the monkey. Right?
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
Page generated in 0.09490 seconds with 7 queries
