Don, finally got around to seeing your Tommy vid, wow, wonderful plane! Seems to fly really well. Do you feel the rudder is big enough? (as in some sea planes have oversized rudders)
Originally Posted by 7car7
(Post 847358)
Good deal. Nothing like leverage. Without floats may have needed more weight.
re. your Tommy Scout
Originally Posted by degreen60
(Post 847376)
The Navy Tommie's rudder is 4 inches taller than the one built for the Army. Mine seems to fly good with the rudder I put on it. The floats made it easy to balance with that short nose. I had to add 1/4 oz weight to the front of each float.
Did you do a build log on your Tommy? I'd love to see how you did it. It looks great BTW. Dave ps. If you didn't do a build, how 'bout some pictures! |
8 Attachment(s)
Originally Posted by details
(Post 847554)
Don,
Pull/Pull
Hey D would you 'splain to us how you set up your pull/pull cable control system? I never tried one. I have just started a scratch build Fokker DVIII Peter Rake design that I would like to incorporate the system on. Marty
Mini DRI
Boys looks like Tower has gotten in the Hobbico FlyZone Fokker Dr.1 Micro EP RTF 14.1"! I just got a notice. OH BOY OH BOY!!!!:D Marty
http://www3.towerhobbies.com/cgi-bin...&I=LXBBSJ&P=ML |
Originally Posted by scalercflyer
(Post 847569)
(Post 847569)
Pull/pull system
D what do you use for cables? Carpet thread or fishing string? Marty
Pull/Pull
D I was just thinking about a trick I saw once. Someone used a straight fishing hook (sans the barb) to tie the cables to and then insert into a EZ connector on the servo arm. What do you think? marty
(Post 847571)
(Post 847576)
(Post 847575)
Carpet thread
Thanks for the answer D! I still have some that you sent me. marty
(Post 847583)
By using one thread that slides through the servo arm you can set tension without worring where the control surface is. Then you can change the control surface and the tension will not change. Makes it much easier to make trim adj.
(Post 847593)
That right there is good stuff. Very smart.
2 Attachment(s)
Have the fuselage ready for servos and controls to be installed in my Spad XI. This could be a very easy bash if someone wanted to make a very simple change to the GWS Tiger Moth. Just change the shape of the rudder and repaint. DONE.
To make it more like the Spad XI cut or sand notches in the trailing edges of wings and tail. Put paper over cockpits and cut new holes. All other changes require more work. Change motor mounting and make paper cowl. Change wing struts. Make landing gear. I think this is the easiest bash I have done. |
Your cat
Het D! Is that a picture of your cat riding a ball on the fuse sides? :D Marty
Looking good!!! Wheels will be in the mail Sat. morn.:D
(Post 847838)
Really looking good D , I am anxious for the flight video :D
Originally Posted by wattman
(Post 847862)
Looks good Don...may need to dig up the old Tiger Moth and do something like that! Been looking at my Jenny off and on for a while...hmmmm
Originally Posted by barmonkey
(Post 847876)
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
