Originally Posted by enemyace19
(Post 777925)
What kind of birds are those? (laughing)
Originally Posted by degreen60
(Post 777924)
I am going to have to refinish my Sopwith Pup. Look what I found on the internet. I just have to have this one to fly.
Well the GP Electrifly Tiggy has been retired.
To replace it, I have have an RAF S.E.5.a scratchbuilt foamie in the drawing stages. I am using an existing set of plans (from Tony65x55 on RCG) which I am modifying using photos of the real plane to add scale details. I also intend on making it a bit larger... 40" WS. My biggest dilemma right now is whether to keep the undercambered wing (formed from a single thickness of foam) or doing something more adventurous... Cut a scale RAF15 airfoil from foam with my hotwire jig. I also intend on painting it with Canadian RCAF (or is it RFC? I'm not good at this history stuff) colours and markings. I've seen renderings of Billy Bishop's SE5a, this could be a possibility for something more 'distinctive': image courtesy Russell Smith Studios http://www.russellsmithart.com/Small...lumage2_LG.jpg |
1 Attachment(s)
Originally Posted by philipa_240sx
(Post 778207)
Thanks degreen60! That gives me more to work on... ;)
That blue with the maple leaf would be a great scheme to do, look forward to seeing that. I noticed the photo posted has the rounded style radiator like what my SE5 has on it. You don't see those as often. They look similar to a Bentley Car's radiator.
I'm guessing since you have a foam cutter, you probably know more than I do, but I'd think if you did a cut foam wing, you'd need some sort of a spar to go it it. Seems a scale thin profile wing in 40 inch length could be quite fragile. Would love to see it done though. |
1 Attachment(s)
Originally Posted by 7car7
(Post 778342)
I'm guessing since you have a foam cutter, you probably know more than I do, but I'd think if you did a cut foam wing, you'd need some sort of a spar to go it it. Seems a scale thin profile wing in 40 inch length could be quite fragile. Would love to see it done though. The wing has a span of 17-3/4" from the cabanes to the wingtip and a chord of 7". The RAF15 airfoil has a max thickness of 0.43" and an average of 0.35". Based on experience, it definitely needs a spar. Flying wires alone won't be enough. I am also toying with glassing the entire wing. I've done this on other builds and it makes the foam very stiff. The FG weave kinda simulates canvas too. Hmm, I need a vintage looking wood prop now... |
3 Attachment(s)
I have my Sopwith refinished. I do not know if the plane had birds painted on both sides. I put birds on both sides of the model.
(Post 778566)
Machine gun
Don't remember if I asked you before D, but how did you build that machine gun? :confused: Mine looks kinda wimpy. :oops: marty
Info source
Here's my favorite source for WWI aviation info. I have most of the collection. Great stuff here Boys. Marty
http://www.overthefront.com/ |
Degreen,
Another great job of finishing a nice example of a Sopwith Pup. The pull/pull controls should work nice. I always enjoy looking over your work. You must have a hanger full by now. **Neons** Bob |
Originally Posted by **neons**
(Post 778574)
Degreen,
Pull/pull system
BTW D how did you put those pull/pulls in? Marty
1 Attachment(s)
Originally Posted by scalercflyer
(Post 778572)
Machine gun
Thanks D! I'll tackle it this weekend when I'm in the mancave. BTW, I owe you a phone call soon. Marty
I have used a pull/pull system on my now defunct Eindekker and a couple small 3D planes. I used thin magnet wire for winding motors and speakers. The wire never changes tension like a string would with atmospheric conditions and age. On one throw for the servo I used a tiny spring like the type in ball point pens. This always helped hold tension on both the leads and acts as a servo breakage protector. Works real good.
**Neons** Bob |
(Post 778577)
(Post 778580)
I used thin magnet wire for winding motors and speakers. **Neons** Bob
(Post 778578)
I print this file on my laser printer. If you use inkjet it will need to be water proofed. .
(Post 778578)
I also have lewis, spandua, and hotchkiss gun files.
(Post 778722)
I'm interested in the Lewis gun. Sent you PM.
(Post 778722)
(Post 778749)
Just send me the plane after it crashes. LOL
1 Attachment(s)
I need help. Look what just arrived. I now have 2 WW1 planes in my rebuild barn being worked on. I must be sick, I already have a scratch built Sopwith Tripe but when I learned about this Kavan Sopwith Tripe headed for the trash I just had to save it. Now I need more servoes, receiver, ESC, ETC. Hope my wife's purse is setting unguarded so I can get some money. LOL
(Post 779046)
(Post 779046)
(Post 779052)
I just thought of something D! ;-) Maybe you should ship that wounded bird to me so I can practice fixing it! After all, we don't want you to strain yourself or anything like that, not to mention you having to explain where your wife's funds disappeared to! :p>:rolleyes::) Marty
Degreen60 your pup looks great .
I am wondering how you feel its flying is compared to your others ? You already know the pup is a favorite of mine |
Originally Posted by wattman
(Post 779068)
I am wondering how you feel its flying is compared to your others ? You already know the pup is a favorite of mine The Pup flys low and slow which I like. It flys the same as my 250 Eflite models. My Sopwith Tripe will fly low and slow but also in wind that is too much for the Pup and Eflites. I am thinking about adding ailerons to the planes without changing anything else just to see if I can then roll them. Hope it does not add too much weight. If I catch the wind just right I can roll a couple of them with rudder. Have not tried to roll the Pup. Will have to get together again and maybe fly the Pups at the sametime. |
4 inches of snow, temp just above zero, no wind, sun out. Put skis on my Eflite N9 Jenny and went flying till the wind came up.
You are the man , where is the video though ? ha ha
(Post 779426)
WOW.....DE nice job on the Pup..she looks better than when it was new....you still have my return address right??? Just remember..no UPS brown trucks..they step on things.:mad:
Would love to see her in the air...they fly so magestic....until they get shot down! Glad to see you got the snipe....Can't wait to see what your gonna do with it....BTW: How did the french bomber fly? did she? AGAIN!!! great job my friend! OOO...and I hate you ....flying with ski's..you just had to tell everyone huh!! Its going to be 14 degrees here tomorrow[popcorn] |
Originally Posted by TM4197
(Post 779455)
Would love to see her in the air...they fly so magestic....until they get shot down! Glad to see you got the snipe....Can't wait to see what your gonna do with it....BTW: How did the french bomber fly? did she? AGAIN!!! great job my friend! OOO...and I hate you ....flying with ski's..you just had to tell everyone huh!! Its going to be 14 degrees here tomorrow[popcorn] The bomber is faster than the Pup. Not as easy to fly. I found something I like to use to make bombs for it so should have it ready for a bombing run soon. Why do I need your address?? You think I might give up a WW1 plane? I know, you just want to keep me hooked. You have any idea how bad I shake just thinking about packing one? Do I need to put a stronger hex on the next pilot I send you? Tell me again what freq you fly on so I can tell my priestess. LOL |
hahahaha...Nice try! Thats why they made freq. hopping!!! been flying the WW2 warbirds when I can....just a need for speed thing right now....Spring time.....I'll break the Biplanes out!!
Guys I need help just got the new e-flight Nieuport and i need the uniform colors for a french pilot. Anyone have any colored drawings they could post or a site ? thanks Doug
1 Attachment(s)
Here is a uniform that was common, of course large leather or wool jackets would be worn over it in flight...but this is pretty original...
(Post 780795)
I understand there was no flying uniform. The pilots wore what ever they wanted to stay warm. I paint my pilots like they are wearing leather coats with fun colar. I then use acrylic black thinned over 50% with water and a couple of drops of liquid soap to coat the pilot. Gives them a dirty look as I am sure the pilots were after flying.
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
