Old 05-12-2007, 12:08 AM   #1
Jon The Buddha
E-Flight Virgin
Default NiMh: Charged vs Discharged Voltage
I use a couple of Electrifly 8.4V - 3000mah NiMh batteries to run my Electristar. My questions is about the voltages I am seeing.
The last time I flew, I made sure I ran the plane until the engine cut off. Is this considered to be the point the battery is roughly 'fully' discharged? I measured the voltage out of both batteries and (I am going from memory here) I think they were approximately 8.5 volts. I have also read the voltage on the batteries after what I think is the proper charging time (36 minutes, charging at 5 amps on a basic Hobbico 900 timed charger). I think the reading was around 9.8 volts.
Do these numbers sound feasible? I am concerned about two issues...that I am running the battery down sufficiently enough between charges, and that, when charged, I am not exceeding some max voltage requirement. Until I can get a proper charger, I want to make the best use of the one I have and NOT damage my batteries.
Thanks gang...I am trying to learn this 'magical' battery stuff, but sometimes I get lost in all the info from the many posts and links to battery basics websites!
Jon The Buddha is offline
Old 05-12-2007, 02:22 AM   #2
Matt Kirsch
Matt Kirsch's Avatar
Technically speaking, fully discharged is considered to be .9 to 1.0 Volts per cell on a NiMH. Fully charged is between 1.3 and 1.4 Volts per cell. Unfortunately, you can't tell the state of charge on a NiMH by looking just at its voltage. The no-load voltage will be near full-charge voltage until the battery is almost empty. At 8.5V yours are on the steep slope to becoming completely empty, and do not contain more than a single-digit percentage of their total capacity.
Continue as you are until you can get yourself a nice peak charger, just monitor the battery's temperature. It should not get more than comfortably warm to the touch. Given a sane charge rate (5 Amps is pushing things a little bit, but it's not a totally crazy rate once the batteries have been cycled a few times) once the battery becomes warm, it's charged.
Matt Kirsch is offline
NIMH Rejuvenation - Low voltage cbatters Batteries & Chargers 6 01-13-2008 08:13 PM
LiPo Voltage when fully charged? Lieutenant Loughead Batteries & Chargers 8 11-01-2007 11:02 PM
Wall Charger - Current/Voltage drop when charging NiMH Tom_Pilot Batteries & Chargers 2 10-21-2007 11:02 AM
Which Charger for multiple pack charging (and have voltage monitoring) lipo,nimh mark11233 Batteries & Chargers 11 05-16-2006 03:24 AM
Measured voltages on Fully charged vs Discharged Vendetta Batteries & Chargers 7 02-13-2006 04:15 AM
Page generated in 0.07525 seconds with 21 queries
