Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > 3D Flying
Old 08-10-2017, 07:59 PM   #1
Default Prop Diameter for 3D
OK things are slow here now, so here is something to do. OK I have a "48" Extreme Flight 540 EDGE EXP have have been using 3S cells and 14 x 7 , and 13 x 6.5 E Props from APC. Happy Happy. However I just purchased a few 4S cells which requires a smaller less aggressive prop. The manual says 12 x 6 but as I run Calculations, a 13 x 4 is a better fit. Uses less power and develops more thrust than the 12 x 6.
OK I know a 13 x 4 will not the air speed a 12 x 6 pitch. Not concerned about speed. What I do not know which is better for 3D flying a larger or smaller diameter prop? My gut tells me bigger is better as it will produce a wider column of air over the control surfaces. Only down side I can see is the larger prop will have more P Factor Torque.
dereckbc is online now
Old 08-10-2017, 08:56 PM   #2
1kW
Friends: (7)
I enjoy 13x4 (wood) on the suggested Torque motor. Less top end but amazing pull out authority. Try it, it may suit your taste in flying. Yes, bigger is more suitable post stall. I have friends running 14x7s on the Xpwr 3910 and they love it. I just don't feel like buying another motor.
Rob
birdDog is online now
Welcome New Members to Wattflyer - We ONLY do electric flight here! admin General Electric Discussions 5358 08-08-2017 04:50 AM
100+ MPH Club CHELLIE Hi-Performance and Sailplanes 1994 05-09-2016 03:05 AM
3mm prop adapter impossible? Prop saver issue? mclarkson General Electric Discussions 12 11-26-2011 10:09 PM
Page generated in 0.11881 seconds with 23 queries
