Old 03-19-2017, 04:42 PM   #1
dereckbc
Default Blue Locktite or Thick CA
On machine screws like linkages do you use Blue Locktite or Thick CA to secure the nut?
Reason I ask is I have a Edge 540 I just recently built and I used Ball Links and used Blue Locktite per the manual and because that is how I roll. Well almost had a disaster, during flight I lost an aileron linkage in flight. Fortunately got it down. FWIW my AR636 RX gyros saved my arse as it helped kept the wings level enough for me to land. Twitchy, bu tI made it down. It was my 3rd flight
Think I am going to switch to thick CA per Doc Austin.
dereckbc is offline
Old 03-19-2017, 04:59 PM   #2
Friends: (19)
I always use Blue Loctite .... never had a loose one yet.
Old 03-19-2017, 05:18 PM   #3
I've used both, depending on the size of bolt/nut, Red/Blue Locktite and thick CA. Mostly on heli's and quads where vibration can be a problem. Never had an issue with either.....Although, a little heat may be required to loosen metal to metal contact after the Loctite has cured properly to larger metal surfaces.
Old 03-19-2017, 06:23 PM   #4
raming
Ramin G
Club: HCAM Austin
Default Beware of Loctite on Plastics!
I religiously use Loctite on Linkages, provided that they all all metal construction. I put Loctite on the Steering Arm Set Screw on my PZ T28 and the Plastic Base that the set screw went into dissolved within minutes. The extremely fine print on the Loctite bottle warns users not use on Plastic.
Trust, but Verify!
raming is offline
Old 03-20-2017, 10:08 PM   #5
Rockin Robbins
Rockin Robbins's Avatar
Friends: (8)
I've used clear nail polish to great effect so far!
Registered drone offender FA377YHFNC
Rockin Robbins is offline
Old 03-21-2017, 08:47 AM   #6
suresharp
With the blue you must make sure threads are free of oil film. Clean threads with alcohal be for applying blue loctite. With using ca works well (even with oil film) but may have to use green ca remover to get threads undone (very big mess).
suresharp is offline
Old 03-21-2017, 10:29 AM   #7
Friends: (19)
Its actually a great item ... but care on certain plastics and foams as it has a solvent base ... some use Acetone ....
Its been used by people with 'slack' screws in eyeglasses for years !!
Old 03-21-2017, 11:02 AM   #8
If using Loctite I'd go for red. The blue has quite weak hold and while it's fine for most applications on small threads where there isn't much area for it to get a grip it's not so good. As already noted, don't use Loctite on plastic.
Old 03-21-2017, 11:22 AM   #9
Friends: (19)
I believe there is an intermediate colour Loctite between Blue and Red.
I don't use Red at all as its supposed to be a Permanent Threadlocking fluid.
I noted that all the mount screws on my DJI are Blue threadlock as are various other 'pre-built' items I have in modelling.
Old 03-21-2017, 03:09 PM   #10
Loctite flavors.........:
Red, Blue, Purple and Green
http://na.henkel-adhesives.com/indus...olor-14023.htm
Old 03-21-2017, 07:30 PM   #11
Red still comes away ok where you havent got much area of thread to lock, like with a tiny nut. Use with caution on threads that have long engagement though.
Old 03-21-2017, 09:32 PM   #12
dereckbc
That explains why Purple and Green are never used.
dereckbc is offline
Old 03-21-2017, 09:37 PM   #13
dereckbc
I have used that for several things other than planes. I kind or like the idea because it is fairly easy to break loose and easily cleaned with Acetone.
I think I will stick with Thick CA on this model. The servo control arms and Ball Links are plastic, horns are G10. Thick CA is easy to control and fairly easy to break off. Uses really small #2 machine screws with about 3 threads exposed after tightened up. Perfect for a drop of Thick CA.
I am grateful I had an AR636 RX in the plane when it lost the one of the Aileron Linkages. It helped me sit the plane down without a scratch. Only my 3rd or 4th flight. Anyway Doc Austin has built a lot of EF planes and gave me the Thick CA tip. Thanks Austin.
dereckbc is offline
Foam safe CA - are there secrets? nk1851 Foamies 69 08-27-2016 01:05 AM
Locktite and plastic garyp1029 General Electric Discussions 12 06-18-2016 01:33 PM
Different forms of CA hinges solentlife Scratch and Kit Built Aircraft 1 02-12-2015 11:28 AM
Blue Dow Foam Where to buy bstarkey54 Foamies 7 08-01-2011 04:18 PM
CA Glue - 3DHS ARF assembly DanWard Beginners 12 01-03-2011 10:43 PM
Page generated in 0.11587 seconds with 44 queries
