Old 12-22-2010, 12:14 AM   #26
Dennis V
4kW  Outstanding Contributor Award  3kW  2kW
Friends: (21)
Originally Posted by starfire73 View Post
I tried it with a 6x4 prop today. That sucked. It totally changed the motor performance.
It went down to drawing 13 amps, and 160 watts at WOT. Which is right were I wanted it... however, the plane flew like a dog! Hardly any power at all. Terrible vertical climb.
I think I'm going to put the 7x5 back on and run it a little hotter.
Ah Ha
You've found just how critical these new fangled electric motors are, as to the propeller selection used
What used to be a minor prop change on those old noisy power plants can make an electric model go from pulling to much power out of the motor/ESC/Battery, to a model that won't fly.
Programs such as www.motocalc.com, or use of a good meter such as the whattmeter (or both) by Astroflight are worth their cost in motors to make certain you are running your power system at its best without burning something up!
Old 12-22-2010, 03:19 AM   #27
starfire73
Yeah... my wattmeter is showing that going from a 6x4 to a 7x5, doubled the amp and watt draw.
I'm going to run it with the 7x5 and just keep an eye on the motor temp. It's not doing me any good with such low thrust as the 6x4 produced. Even with the 7x5 it's staying within the battery and ESC specs, so I may burn out a $15 motor before it's time... no big deal.
I'm hoping that keeping the motor temp. as close to 150 F (or less) as I can, will be enough, regardless of the motor's ratings, etc.
starfire73 is offline
Old 12-22-2010, 03:46 AM   #28
View CHELLIE's Gallery13
Scratchbuilders Award  Scratchbuilders Award  Ambassador Award  100mph Speed Demon
Friends: (326)
On your next plane, use a motor thats almost twice the size/power that you need Really, most people try to use a motor that will just fly the plane but it wont have any performance at all, then they but a larger prop on it and the motor is taxed to the limit, not good, so start out with a motor that 2x bigger than whats needed, all the extra power is fun too thats what i do and have never regreted doing that, just my 2 cents worth, Have fun, Chellie
Old 12-22-2010, 05:54 AM   #29
Dennis V
Friends: (21)
If you burn that motor up, you might consider going to a higher performance motor. I've got 7 Hacker motors, all perform per their ratings, and run cool while doing it. Mine run about 15-20 degrees F above ambient after a flight, as measured by a thermocouple type thermometer on a Fluke 87V multimeter.
Take a look at the Hacker A30-12M motor. www.motocalc.com predicts with your 3 cell Lipo, this motor will pull 22 Amps while turning a 7-6 prop at 14,000 RPM, or 32 Amps while turning a 8-6 prop at 13,200 RPM. These type motors are quite efficient, and put more of the battery "horsepower" into the propeller, and less of the battery "horsepower" into making the motor hot.
Hacker has a number of different winds for the same core motor size. These motors are not cheap, the A30-12M goes for about $60.
Many other motors are also out there, check them out. If you've not done so, check out www.motocalc.com, that program, or other similar programs will give you an idea of how different motors, props, and battery packs will perform on your model. Motocalc is free for 30 days, then its $39.00
Old 03-16-2017, 12:51 AM   #30
d0uglas
Gotta say, you guys raise the bar when it comes to knowledge and willingness to share it, at least compared to another forum I've grown used to. Really, it's impressive. Thanks for the information, this thread alone has been quite helpful.
Doug
d0uglas is offline
Old 03-16-2017, 02:28 AM   #31
Dennis V
Friends: (21)
Doug
This thread is 7 years old!
FYI, I'm still flying every Hacker motor I've ever bought
DennyV
Old 03-16-2017, 04:09 PM   #32
d0uglas
Having spent my share of time on RCG threads, I'm quite glad to have discovered wattflyer. It's now as if I am at my club where everyone knows more than I do and is willing to teach me, a wealth of knowledge, and an element of courteousness and general levelheadedness that until now, online, has been somewhat foreign to me.
So, I offer my compliments, and a thank you for welcoming me.
Good to know about the Hacker motors. I'm the motor-tinkering type. Are there any HeadsUp-like resellers that ship fast from the States?
Doug
d0uglas is offline
Old 03-16-2017, 04:31 PM   #33
Friends: (18)
Wattflyer plays a level game and rarely gets naughty. We have our moments but nothing like RCGroups for example. If you really want to see some 'bare-knuckle' stuff ... go look at the Drone Forums !!
We do actually try to steer clear of too many 'black' references as it tends to spoil a good chat.
The biggest thing you will notice is that if someone is wrong on WF ... we accept and don't make a big song and dance of it. I am wrong and I accept. Simple.
The moderators here also are PRO-active ... not reactive as others ... so things are not allowed to get out of hand.
A thoroughly good place to be. Without WF - I think I would go nuts !!
Old 03-17-2017, 06:14 PM   #34
Rockin Robbins
Rockin Robbins's Avatar
Friends: (8)
Which leads me to wonder why more people don't frequent Wattflyer. The culture is absolutely superior to other RC forums. As a result I spend more time over at RCG than I'd like to. You have to have a thick skin and be willing to dish it out a bit over there as in order not to be squished you have to match the intensity of the turbulence with your stick inputs.
Then you come back here and find yourself having to adjust your transmitter to allow for a fine group of people who respect each other and give each other the benefit of the doubt. Posting on a forum need not be a full contact sport! Wattflyer rocks.
Registered drone offender FA377YHFNC
Rockin Robbins is offline
Old 03-17-2017, 06:42 PM   #35
Friends: (18)
I think WF is nice and good to be in because it does not have so many 'members' as RCG. As numbers increase - the overall tone and character changes accommodating the rough and the smooth. Pity because WF needs more members and input. But we don't want the place to change !
Its funny because I once read a post over on RCG that claimed WF was only for old fogies who liked to stick bits of wood together . scratchbuild etc. That WF didn't have 'modern day' modellers !!
Old 03-17-2017, 07:24 PM   #36
View dahawk's Gallery6
Club: 114th RC Aero Squadron
Friends: (21)
Considering that you're an antique, they are correct ! LOL Just kidding.
Old 03-17-2017, 07:40 PM   #37
Friends: (18)
And I was going to add you to my Xmas Card list !!
Old 03-17-2017, 08:06 PM   #38
hayofstacks
hayofstacks's Avatar
Friends: (5)
Doug
I really like heads up rc. I have never been disappointed. I've gotten shipments in about 24 hours before on standard shipping. From Florida to utah, that's pretty good.
Also he takes all the guess work out of picking out a motor.
slow stock prop reversal. it flies! easily! 543 watt dual motor bipe slow stick. push-me-pull-you. 242 watt 3 channel slow stick. 365 watt mini ultra stick. 415 watt mini contender. 810 watt ultra stick .25e. 220 watt alpha 450 sport (retired).
hayofstacks is offline
Old 03-19-2017, 01:06 AM   #39
Rockin Robbins
Friends: (8)
1000% agree. They are my default place to buy RC stuff. Just bought an Eflite UMX Waco BL and they didn't have appropriate batteries. I was heartbroken.
Great prices. Great products. Knowledgeable people. Incredibly cheap and quick shipping.
Normally a motor's watt rating represents the sales department's impossibly optimistic advertising claim. With Heads Up it represents their personal test of what the motor can safely deliver with a specific battery and propeller.That alone is justification for buying from them first.
Old 03-19-2017, 02:14 AM   #40
Dennis V
Friends: (21)
Doug
Hacker motors have always been near the top in quality and performance. But, they are a lot of $$$$. There are a number of lower cost motors now days that also perform quite well. My Hackers run from an A30, two A40's, three A50's, and two A60's.
I've got a Rimfire 50cc motor that is running trouble free at 4500 Watts in one of my models.
Here is one supplier of Hacker motors in the USA.
http://www.espritmodel.com/hacker-out-runners.aspx
DennyV
Old 03-24-2017, 09:29 PM   #41
Rockin Robbins
Friends: (8)
And Hacker is one of the very few motor manufacturers that if you run the motor all day at their rated wattage, you won't burn the motor out or even stress it in any way. Hacker's ratings for their motors can be relied on.
Motor kv Rating iFLYrc_Vic Power Systems 2 01-15-2010 08:48 PM
Wanted Brushless motor with ESC rating 25AMP or more. High_Flyer_360 Motors and Speed Controllers for sale & WTB 0 09-25-2008 12:30 AM
best motor for the Watt-Age PowerFan 400/6 EDF ea01bg Electric Ducted Fan Jets 13 02-26-2007 02:14 AM
what does the RSS stand for or represent? cyclops2 RCU RSS Feed 3 11-08-2006 12:22 AM
Motor voltage rating vs power? jb48 Power Systems 0 07-02-2006 01:24 PM
Page generated in 0.48749 seconds with 52 queries
