Go Back   WattFlyer RC Electric Flight Forums - Discuss radio control eflight > Electric R/C Airplanes > WWI Era
Old 02-12-2017, 10:34 PM   #1
Griff Murphey
Default DPCM repro Guillows DH-4
Hello all, Dave has released his laser cut 27" span repro of the original. He offers it in original and in lightweight. I have mine all framed up and almost ready to cover. Dave left out one frame part from the rudder but this was easily replaced. There are some minor discrepancies in the fit of the struts but I believe this is just the way Guillow made it. I used the Spektrum 7.4 V brick and an outrunner 180. Battery will load from the underside with a magnet retained access hatch. Upper cowl, which I separated and covered in 1/32 sheet balsa, is also to be magnet retained to allow full access to the engine compartment. Comes in handy after faceplants and if you have to adjust the thrust angles.
As always Dave replaces the vacuform parts with balsa, this is a survivability plus particularly re the cowl.
Griff Murphey is offline
Old 02-21-2017, 03:48 AM   #2
Griff Murphey
So I am looking at the wings and the seem a little fragile. I am wondering if I need to add a hardwood 1/16" top spar? These wings flex a lot. Dave calls this the lightweight - uses 1/16" x 3/16" instead of 1/8" x 3/16" spars. There are two soars for the upper wing but only one fir the lower. My experience with biplanes is that the lower wing is the one that gets whanged the hardest and most often. Your opinions?
Top photo - lower wing on the left
Bottom photo is the lower wing.
Old 04-17-2017, 03:56 AM   #3
Griff Murphey
Default Almost ready to put wings, struts, and undercart on
Making up some details like vac form Easy Bilt pilots and guns, the US ones used a weird Marlin MG. It's a pure flying model I am not going nuts on details - I may even leave off the aft twin Lewis guns.
May cut the pilot and gunner down get the heads lower.
Can you suggest a paint that might stick to an orange plastic GWS EP Orange plastic prop? Maybe Testors enamel thinned with lacquer thinner.. or rustoleum out of a can?
Old 04-17-2017, 08:11 PM   #4
Nice work there Griff!
Any paint with lacquer thinners should probably be avoided on plastic parts, but maybe if you put it on in light coats it would be ok, it might 'self etch' to the surface!
Old 04-18-2017, 12:33 AM   #5
Griff Murphey
Thanks... I want to get a "wooden" appearance... Def. not an orange plastic look!
Old 05-19-2017, 04:04 PM   #6
Griff Murphey
Default Nearing Completion
Just about to put her together. Purists will note I did not do all the small stuff I could have to make it a more accurate US type "Liberty Plane." I used the Easy Bilt vacuform pilots, did the fleece collars with white glue sprinkled with balsa sawdust. The Lewis guns are the nice laser cut wooden receivers with plastic tubing for barrel and gas tube. No ring mount just a little bar with a couple of spikes in it to hold the guns. I can pinch the wire to remove before flight if I wish.
Old 05-19-2017, 06:00 PM   #7
Griff Murphey
Pilot and Lewis guns
Guillows Stearman Bill G Scratch and Kit Built Aircraft 45 01-14-2017 03:08 PM
Guillows 24" Beaver Bill G Seaplanes E-Powered 8 08-14-2016 01:02 AM
3rd Times a Charm, Ain't No Chance of Being Tail Heavy, Guillows 16.5" FW190 Bill G Scratch and Kit Built Aircraft 17 03-23-2012 01:42 AM
Page generated in 0.54624 seconds with 43 queries
