Old 08-12-2017, 06:28 PM   #1
dereckbc
Default Stripped Screw Hole in Wood
I have an engine cowl tab I stripped the screw hole out. Not an option to move it. With larger and real wood I know how to fix with wooden pegs and wood glue. The Tab is made of plywood that looks to be about 3/32" thick.
How do you fix it?
dereckbc is online now
Old 08-12-2017, 09:45 PM   #2
1kW
Friends: (7)
Either a toothpick glued into the hole and re-bored or another piece of wood behind it would be my solution.
I don't have a short temper. I just have a quick reaction to B.S.
Rob
birdDog is online now
Old 08-13-2017, 02:14 AM   #3
pmullen503
Scratchbuilders Award
Can you glue a scrap of plywood behind the stripped hole and screw into that?
pmullen503 is offline
Old 08-13-2017, 10:54 AM   #4
View mclarkson's Gallery26
Friends: (8)
Yeah - what kind of access do you have?
Old 08-13-2017, 04:15 PM   #5
dereckbc
Yep I ended up glueing a piece popsicle stick to the Tab and will drill pilot hole later today.
Old 08-17-2017, 05:45 AM   #6
F22trainer
Sometimes wicking a little CA in the hole will restore the 'bite'. But wait for it to dry or you'll never get it out.
F22trainer is online now
Old 08-17-2017, 08:10 PM   #7
Friends: (17)
If I can get behind .... I drill out and insert a blind nut.
You can also get inserts that go in from front ... as you screw bolt in - expands and bites ...
Old 08-17-2017, 10:31 PM   #8
Probably a smart decision (wood and glue) keeping weight distribution down without metal nuts and bolts changing C/G characteristics.
Folding Prop Set Screw djdobbins Hi-Performance and Sailplanes 2 08-27-2015 02:47 PM
Wood propellers? mclarkson Power Systems 19 02-20-2013 02:33 AM
Wood spars problem solved ! solentlife Scratch and Kit Built Aircraft 12 01-08-2013 06:00 AM
Fixing a screw hole Forge Scratch and Kit Built Aircraft 8 12-18-2010 03:09 AM
Page generated in 0.07312 seconds with 34 queries
