Old 05-17-2017, 02:09 PM   #1
jmrpb
jmrpb's Avatar
Cool Eurofighter Typhoon Aerobatic
Eurofighter Typhoon
This is my aerobatic Eurofighter Typhoon.
It has a simple way of vectorial thrust, like some of other pusher planes. It’s very aerobatic with very good vertical performance and, of course, it is also very forgiven and stable if you want to. Most of the times, I catch it by hand on landings. It has KF airfoil number 4 (up and down symmetric for Acrobatics), and It works great!!
It has got a very good flight envelope between slow speed and high angle of attack (AoA) and very fast acceleration and speed. This is because of the delta wing configuration (37º degree swept-back angle) and the 9” 6” propeller, which is perfect for acceleration from slow speed and high AoA to fast speed.
It’s known that a conventional tail (with tail feathers) is better for pitch maneuvers and loops. Nevertheless, with this delta configuration I can still make loops and very sharp turns. At present time it has fixed canards. I have tried it with movable canards but, in my opinion, the advantages, if there were any, are perfectly neglectable, and didn’t compensate the complexity and the weight penalty.
The specifications are:
- Length: 101 cm;
- WingSpan: 70 cm;
- Leading hedge sweep-back angle (wing): 37º;
- KF Airfoil number 4 (up and down symmetric for aerobatics);
- Motor: SunnySky 2212 / 980KV;
- Speed Controller: Rapid Fire 12A (10 grams);
- Propeller: Graupner 9” * 6” Slim Cam (perfect for acceleration from low speed and for AoA);
- Battery: #1 LIPO 3S / 1300 mA/h with 35C (flight times between 6 and 7 minutes with aerobatics);
- Servos: #3 Hitec HS-55;
- The tip of the wing (outer far part of the wing is): 10 cm (with ailerons);
- Dimensions of rudder: 23 cm tall by 25 cm wide (at the widest point in the bottom);
- Weight: between 390 and 440 grams / 13,8 oz to ~ 15,5 oz range (it depends on the battery you use) ready to fly;
- Landing: Hand catch
The front part of the Eurofighter is made of grey ‘polypropylene’ and from one inch of white foam sanded into shape and glued in each side of the fuselage that makes it almost, and I say ALMOST, indestructible.
I hope that this brief description helps.
I will post a video as soon as possible.
It does have KF airfoil number 4 for aerobatics.
It looks great in the air and it’s guaranteed that you’ll receive all the attention of other RC fellow pilots!
Check out the photos below.
Follow your dreams and fly like there is no tomorrow!
José Bernardo
Lisbon, Portugal, Europe
jmrpb is offline
Old 05-17-2017, 02:12 PM   #2
jmrpb
jmrpb's Avatar
These are some still pictures of the 'fleet':
jmrpb is offline
Old 05-17-2017, 02:14 PM   #3
jmrpb
jmrpb's Avatar
... And this is the video performing some aerobatics
http://www.youtube.com/watch?v=x6-YMtOfTv4
jmrpb is offline
Old 05-18-2017, 02:46 AM   #4
View Don Sims's Gallery114
WAA-08 Pilot  Globetrotter Pilot
Friends: (40)
Cool plane and great video!
Take care and thanks for posting at WattFlyer!!
Don
Old 05-23-2017, 10:46 PM   #5
jmrpb
jmrpb's Avatar
Talking
Thanks!
Bernardo
jmrpb is offline
Old 06-11-2017, 01:46 PM   #6
jmrpb
jmrpb's Avatar
Here are some advantages Versus disadvantages of this type of Delta Wing:
Pros:
- Very fast speed and acceleration;
- Unlimited vertical performance;
- Slow speed and high AoA;
- Very fast roll rate;
- Very good sharp turn rate;
- The single and central rudder gives him very precise directional control;
- Very stable inverted flight.
Cons:
- It doesn’t like to make tight loops (waterfalls). Nevertheless, it makes perfect normal loops (positive - inside loops and negative - outside loops).
José Bernardo
jmrpb is offline
Old 06-12-2017, 05:54 PM   #7
Cezzna
Saw a real one at a museum in England once.
Pretty impressive airplane
Cezzna is offline
Old 06-12-2017, 07:14 PM   #8
Friends: (18)
You saying the Eurofighter is an antique relic ??
Old 06-12-2017, 09:14 PM   #9
Well now you come to mention it... The British Aerospace EAP technology demonstrator that went on to be developed into the Eurofighter Typhoon first flew in 1986.. it's 31 years old. So the general Eurofighter airframe design is already older than the Sopwith Camel was at the dawn of the jet age
I guess this illustrated how slowly modern aircraft are developing compared to the early days of aviation.
Old 06-13-2017, 07:58 AM   #10
Friends: (18)
Yes - the EAP development version was retired many years ago ....
I was just having a little bit of fun about a Euro fighter being a museum piece !
Old 06-18-2017, 09:55 PM   #11
jmrpb
jmrpb's Avatar
Dear 'Cezzna',
The real airplane is indeed very impressive. This one has the advantage that can fit in the back of the car and you can ‘fly it like you have stolen it’, and if you crash - Don’t worry! Just pick up all the pieces and glue it all together with epoxy. In less than a week you will be flying back again and you can be the terror of all the pigeons and small birds of your local airfield .
Bernardo
jmrpb is offline
Tags
delta wing , eurofighter , eurofighter typhoon
NEW Avios Zazzy Sport Aerobatic model from HobbyKing ditchit Sport Planes (Formerly I/C & Gas Conversion) 0 09-20-2016 12:04 PM
Good sport - aerobatic plane stanz358 ParkFlyers 22 06-30-2016 03:44 PM
Inrunner substitute motor for Typhoon 3D zawaprz ParkFlyers 2 08-18-2012 05:10 PM
Parkzone typhoon 3d maiden flight skyhawke 3D Flying 2 08-11-2012 09:02 PM
Page generated in 0.49854 seconds with 49 queries
